Old 04-08-2014, 06:22 PM   #281
uncivilised
Drives: 86 GT
I had this noise with the stg2 e85 OFT tune. Now with the 4-1 EL catless header and matching overpipe i just installed, i cant hear the noise anymore. running the stock exhaust from the overpipe back so my car is not loud at all.
something to do with the acoustics in the factory header?
im no expert on this.
uncivilised is offline   Reply With Quote
Old 04-08-2014, 06:25 PM   #282
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by uncivilised View Post
I had this noise with the stg2 e85 OFT tune. Now with the 4-1 el catless header and matching overpipe i just installed, i cant hear the noise anymore. running the stock exhaust from the overpipe back so my car is not loud at all.
Is that an EL or UEL exhaust?
Luckrider is offline   Reply With Quote
Old 04-08-2014, 06:28 PM   #283
uncivilised
Drives: 86 GT
EL header.
Old 04-09-2014, 08:23 AM   #284
Pistol
Drives: 86
i got EL header
made the sound worse !!!!
Pistol is offline   Reply With Quote
Old 04-09-2014, 06:36 PM   #285
uncivilised
Drives: 86 GT
which header do you have? i have the mx performance 4-1 EL header from sydney
Old 04-12-2014, 03:13 PM   #286
Pistol
Drives: 86
nameless performance
Old 04-12-2014, 06:20 PM   #287
steve99
Drives: FT86
Originally Posted by Pistol View Post
i got EL header
When you installed headers you probably ran the stage 2 tune for el headers? This tune runs more timing advance and that probaably made yourknock worse. If you did not change tune catless headers will generally make you run a bit leaner again possibly increasing knock as the tune for headers also adds fuel . In Oz run 100 octane RON or pull some timing or both for low rpm high load knock
Old 04-12-2014, 10:45 PM   #288
Pistol
Drives: 86
yeah as you said I ran the stage 2 EL tune
however, i was using that same tune before the nameless header was installed
also, i have been using e85
before header and after
the mettallic sound makes me cry
Old 04-12-2014, 11:16 PM   #289
steve99
Drives: FT86
QUOTE=Pistol;1668785]yeah as you said I ran the stage 2 EL tune
the mettallic sound makes me cry[/QUOTE]
Gees knock on E85, can you see it in the logs as knock correction or drop in kc learned ?, if no sign of knock in logs then it might be something physicaly loose or hitting on exhaust, heat shields?
Old 04-23-2014, 04:50 PM   #290
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Originally Posted by Dezoris View Post
Trying to get dyno done and more logging in the next week of two will post back.
Updates?
Amadeus is offline   Reply With Quote
Old 04-24-2014, 12:56 AM   #291
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by Amadeus View Post
Updates?
The problem with this on is you would have to drive x number of miles with an aggressive vvt tune, pull the cams and mic them. Nobodies going to do that.
I can say going from A00C to B01C calibration eliminated the noise under load at 5k rpm. I was convinced the noise was just a resonance but the drastic difference in factory tunes has changed my mind.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-24-2014, 01:45 AM   #292
Dezoris
Dezoris's Avatar
Updates?
Still on list to get dynos done. Bad couple of weeks.
Old 04-28-2014, 10:23 AM   #293
sprintamx
Interesting change here: I've been running the OFT / OTS Stage 2 EL 91-93 oct tune for about 2 months (prototype catless EL header; 93 Octane all the time). The timing/valve/knock noise was very pronounced at 4K +/- rpm, and the motor seemed more "noisy" overall than when I was running the basic Stage 1 OTS tune.
I just loaded the OTS Stage 2 EL E85 tune (1.59 bin) and ran the car for the first time this morning. The 4K mechanical noises do not seem to be present and the engine "seems" more quiet and smoother overall. I doubt that the fuel system is entirely purged of the 93 octane gas just yet, and have only run the car about 4 miles / 20 minutes since the new tune. But my experience seems to be somewhat the reverse of what's being expressed in this thread . . .?
Is this just the result of the difference in the E85 vs 91/93 octane tunes? Admittedly, I have not researched this particular difference or really followed the threads.
sprintamx is offline   Reply With Quote
Old 04-28-2014, 10:51 AM   #294
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
More likely Shiv is aware of, and has read, this thread and has made changes in the cam phasing to reduce this effect.
Maybe @shiv@vishnu can respond when he returns from his honeymoon.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 05:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
