Old 04-12-2014, 06:58 AM   #1
Kodename47
Kodename47's Avatar
Drives: UK GT86
Perrin CAI MAF Scale
I know that the 3in intake scaling can be found here:
http://perrinperformance.com/i-14448...-fr-s-brz.html
Does anyone have a basic scale for Perrin's normal intake or is it close enough to stock scale that the basis can be done from that? I've tried looking but no success.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-12-2014, 07:18 AM   #2
carlitosway6891
Drives: white out project fr-s
http://www.ft86club.com/forums/showt...t=59409&page=2
it would be the last post on that page or post #44
carlitosway6891 is offline   Reply With Quote
Old 04-12-2014, 11:08 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thank you very much!!
.: Stealth 86 :.
Kodename 47 DJ:
carlitosway6891 (04-12-2014)
Old 04-12-2014, 11:17 AM   #4
phrosty
I'll be curious to see what results you get. I scaled mine and am running a little lean.
phrosty is offline   Reply With Quote
Old 04-12-2014, 11:38 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Cheers for the heads up. I will bump up the scale by a couple of % so that it's running richer and then reduce it if needed.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-14-2014, 06:15 PM   #6
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I posted this somewhere else, if you guys make a different MAF curve that seems to be working better, send it to us to test out, we'd like to see it, thanks!
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
phrosty (04-14-2014)
Old 04-16-2014, 08:26 AM   #7
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Here are my torque logs for the past two days using the scaling provided by Perrin for the 2.5" Intake. I think the MAF looks ok, but please let me know if you think anythings off.
File Type: zip Torque Logs Perrin 2.5 Intake Scaling.zip (325.8 KB, 236 views)
milhouse is offline   Reply With Quote
Old 04-16-2014, 04:55 PM   #8
PERRIN_Chris
Is there a way to record throttle input, fuel trim short, and fuel trim long? That's what we'd need to see to make sure it's running right.
Is the highest sample rate really one per second? If it is, it might help to delete the some of the line items that aren't needed, GPS time, the G x, y, and z.
Old 04-16-2014, 05:18 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
@moto-mike just finished tuning my 3" perrin CAI for my Innovate SC. not sure if this is something that would be beneficial for him to share though.
Old 04-16-2014, 11:59 PM   #10
milhouse
Because Racecar
milhouse's Avatar
I will log those tomorrow and re-send. Not if I'm running the fastest sample rate or not...
Old 04-17-2014, 08:33 AM   #11
milhouse
Because Racecar
milhouse's Avatar
Here is the requested data at .1 seconds (increased from 1 second). If its missing anything, let me know and I will connect my OFT to log it.
File Type: zip Torque Data 2 - Perrin 2.5 MAF Scaling.zip (725.9 KB, 254 views)
Old 04-17-2014, 03:49 PM   #12
PERRIN_Chris
Milhouse, the log looks good to me. Just normal fuel learning in there, and no high trim levels, so looks like you're good.
Old 04-17-2014, 04:55 PM   #13
milhouse
Because Racecar
milhouse's Avatar
Great. If you want my Romraider file to copy the MAF scaling, let me know. No other changes in it.
And thanks!
Old 11-12-2015, 01:06 PM   #14
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@Kodename47 did you ever end up doing your own scaling? Going to do some scaling with VGI tool next spring before hitting the track
1Cor10:23 is offline   Reply With Quote
Scale models The359 Other Vehicles & General Automotive Discussions 1 06-09-2013 04:10 PM
Navigation Scale Kyle106 BRZ First-Gen (2012+) — General Topics 3 04-11-2013 04:14 PM
Racing on a smaller scale... SteveH Off-Topic Lounge [WARNING: NO POLITICS] 2 02-27-2013 12:30 AM
Scale FR-S Sloober Scion FR-S / Toyota 86 GT86 General Forum 9 11-04-2012 06:50 PM
What about the HPI Racing scale models? Davyator Scion FR-S / Toyota 86 GT86 General Forum 16 08-28-2012 05:47 PM
