Old 04-11-2014, 08:09 PM   #23479
Crooksandkevin
Crooksandkevin's Avatar
Originally Posted by Celadrielas View Post
I wanna trade out my fin for a beatsonic V2... How hard was it to get the VG off and how'd you do it?
That was me!
Crooksandkevin is offline   Reply With Quote
Old 04-11-2014, 08:10 PM   #23480
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
Originally Posted by Crooksandkevin View Post
That was me!
Awesome, mind sending me a link where you got them from?
Old 04-11-2014, 08:17 PM   #23481
Crooksandkevin
I got them from discount tire. When they ordered them I had to asap cuz they said styluz only had 3 sets left and they were discontinuing that color.
Old 04-11-2014, 08:21 PM   #23482
Lischynski
Weendog
Lischynski's Avatar
Ah okay. Do you have a model number? Are they M575?
Old 04-11-2014, 08:22 PM   #23483
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
I was able to just pull it off. The only problem is that the adhesive is stronger than the foam strip itself, so I ended up with a tape ring going around my antenna base. Was a pain to pick it all off, but luckily the base of the V2 is bigger so it should help to hide anything you miss.
Sent from my SCH-I545 using Tapatalk
amaciose is offline   Reply With Quote
Old 04-11-2014, 08:23 PM   #23484
Cross
It's the Mad Cow
Cross's Avatar
Hey @Cross, could you PM me your cell number? I'll send you a text tonight.
Of course I hadn't realized I had not done so already.
The Following User Says Thank You to Cross For This Useful Post:
Lischynski (04-11-2014)
Old 04-11-2014, 08:29 PM   #23485
martin86
Rabble Rabble Rabble
martin86's Avatar
Drives: 2013 Subaru BRZ
Welp never mind looks like this 12 hour shift just got longer. At least I get paid hourly....
martin86 is offline   Reply With Quote
Old 04-11-2014, 09:12 PM   #23486
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Got them done today
TwoFourFive is offline   Reply With Quote
Old 04-11-2014, 09:18 PM   #23487
Cross
It's the Mad Cow
Cross's Avatar
Alright leaving work... finally. But I have a tune update so that's always nice.
Old 04-11-2014, 09:28 PM   #23488
TwoFourFive
Drives: 13 HOT LAVA
Coils a bit noisy at slow speeds. Would an alignment help?
Old 04-11-2014, 09:48 PM   #23489
jeffsides
AZ FRS 86
jeffsides's Avatar
I was asked to help spread the word. Meet on the west side Name:  ImageUploadedByTapatalk1397267316.281019.jpg
Sent from ARIZONA86 HQ
@AZFRS86
The Following 2 Users Say Thank You to jeffsides For This Useful Post:
bignrichlll (04-11-2014), J. O'Grimm (04-12-2014)
Old 04-12-2014, 01:39 AM   #23490
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Originally Posted by norcalpb View Post
Heys guys,
Quick question do any of you have any specific mechanics in Phoenix/Tempe you trust with your oil changes? Looking for a mechanic who knows whats up with these Subaru motors.
Thanks!
If you want to come to the west side my shop is in glendale, 51st ave and camelback, Ramsey Auto Center, my shop is expensive but good quality work. probably looking little under 90$ for a full synthetic 0w20 oil change after tax's out the door.
JesseE is offline   Reply With Quote
Old 04-12-2014, 01:42 AM   #23491
JesseE
JesseE's Avatar
alignment has nothing to do with noise... if its noisy something is wrong or not assembled correctly what type of noise... if its knocking noises over bumps most of the time its the top bearing plate not tight, could be other things like loose bolts, worn sway bar links, but the strut mount with bearing is common.
What type of coilovers do you have? do they have pre load helper springs? or when your car is in the air does the spring flop around?
Old 04-12-2014, 01:47 AM   #23492
Cross
It's the Mad Cow
Cross's Avatar
Tucson BWW group
Sent from Spaceball 1
The Following 2 Users Say Thank You to Cross For This Useful Post:
amaciose (04-12-2014), Gusha0426 (04-12-2014)
