#85 |
Grease Monkey
Drives: Whiteout FR-S
First of all, thank you for this thread.
I just finished replacing my transmission fluid with Red Line Gl-4 MT-85. The job was a breeze... i took my time and it took no longer than an hour. The transmission fill/drain plugs do not have crush washers, they are solid and reusable. Noticed a small difference after test driving, but i'll know for sure after about a week of driving. Anyway heres some pics: The Fluid I used ![]() Immediately after removal ![]() After a quick wipe down
R.I.P. '92 Honda Prelude you will be missed
| The Following User Says Thank You to Carban For This Useful Post: | hmong337 (03-29-2014) |
#86 |
Drives: MDX, Camry
Quick question where is the best place to buy Motul 300 gear oil? Surprised nobody asked this before.
#87 |
#88 |
Drives: 2013 BRZ Limited
I am getting ready to change all my fluids over to Amsoil, found this pump at Advance Auto Parts. It fits the Amsoil quarts nicely. It took less then 20 pumps to nearly empty each quart, the end has two barbs on each side which grab the threads holding it in the trans or differential. I bought two as they were only $6 a piece, no cross contamination.
http://shop.advanceautoparts.com/web...ump#fragment-3
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk Last edited by CoupedUpSubie; 02-15-2014 at 06:16 PM. |
| The Following 2 Users Say Thank You to CoupedUpSubie For This Useful Post: | Marx (01-13-2015), retrosmiths (04-02-2014) |
#89 |
Drives: 2005 Toyota Camry
Before/after:
![]() Just FYI washer(s) for rear diff are the same size/thickness. Cheaper of the two is part # 1215710010, just buy two of those. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | hmong337 (03-29-2014) |
#90 | |
Drives: N/A
Cheap Motul Summit Racing and Amazon
http://www.summitracing.com/parts/mtl-100118/overview/ I noticed other dealers selling and shipping it on here but not for the same price as Summit and with the free shipping and no tax you cant beat it. Kster1 posted this if you need a case its like $13 a bottle free shipping [ame="http://www.amazon.com/Motul-3178CZ-12PK-Synthetic-Differential-Lubricant/dp/B004LEWJSW/http://"]Amazon.com: Motul 3178CZ-12PK Gear 300 75W-90 100 Percent Synthetic Ester Based Racing Gearbox and Differential Lubricant - 1 Liter, (Case Pack of 12): Automotive[/ame] Just wanted to help people find a good deal
#91 |
Thanks to the OP for the great DIY.
Just finished off my trans/diff fluid swap (Motul 300) and the DIY instructions were great. My only issue was not positioning my bucket properly to catch the transmission fluid so I had a bit of a spill initially. |
#92 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
Does anyone have thoughts on motul 300 75W-90 vs motul motylgear 75w-90. All of my searches have only found info that is years and year old, and that suggested the motul motylgear 75w-90 was better.
#93 |
Sorry for any confusion, I used the Motul Gear 300, which is 75w90
Sent from my Nexus 7 using Tapatalk |
| The Following User Says Thank You to jvincent For This Useful Post: | ProjectD (05-14-2014) |
#94 | |
Drives: 2013 BRZ Limited WRB
So best of the best for a flush tranny / diff / engine oil would be what ? Motul for tranny / dif and amsoil ?
Sent from my SGH-I337M using Tapatalk
#95 |
Drives: 2014 WRB BRZ Limited
I had Motul Gear 300 put in (both trans and diff) by my local mechanic, and it definitely made cold gear changes better. It's still not perfect, but a definite improvement.
#96 |
Drives: Scion FR-S Whiteout
^ This.
2013 Scion FR-S
#97 | ||
#98 |
Kurenai Samurai
Drives: Red and manual
update part number SU003-03626 for the transmission drain and fill washer gasket is the same exact size as hondas transmission drain plug and it costs 2.27 instead of 11 bucks. save some money. hondas part number is 90471-px4-000
hope this helps guys |
| The Following 3 Users Say Thank You to driftartist For This Useful Post: |
| Tags |
| differential, diy, fluid, transmission |
| Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 02:23 PM |
| What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 08:57 PM |
| Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 05:47 AM |
| FR-S quick reference and warranty / maintenance guide is up | pkny | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-20-2012 11:33 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
