Old 04-11-2014, 02:13 PM   #1
suaveflooder
The many colors of whiteout (the matching problem)
I feel like there has been a few threads on this lately, and I've run into it as well on my own car with newly painted parts, so I did a little research. I'll add more as I find more information, but this kind of stuff is interesting to me, so i figured that I would share.
We all know the whole "plastic vs metal" idea, but there is actually a LOT to getting a pearl color to match.
My own car:
Color is actually a pretty dead on match…..
Off the car in the sun for color check
Shade
And night pics with flash
And 'da whole booty!
But add a little angle and some artificial light (fluorescent bulbs in the garage)
(even factory parts go off a little)
And here's the reason why
So why do the car manufacturers have so many variances? Most car manufacturers have three major paint suppliers. The manufacturer decides on a standard color for production and submits a painted sample to their suppliers. The paint manufacturer then produces a formula for the “standard sample” and is allowed a tolerance of plus or minus 5% when they deliver the paint.
This is the first problem because the plant in the east coast may be getting a 5% shade greener on a blue metallic standard and the plant in the west coast may be getting a 5% shade violet on the same blue metallic standard. When compared side by side, they look like a completely different color. This is the reason the paint manufacturers usually have the standard formula followed by two alternates. If the alternates are not available, the painter in the body shop usually mixes the standard formula and tints it accordingly.
The second reason for variances in paint colors is the metallic color applications. The metallic colors are now classified in 7 categories. Extra fine, fine, medium, medium coarse, coarse, and extra coarse. The metallic colors control the value (lightness and darkness) of the color similar to what white does in a pastel color.
Metallic colors will cause variances in color when applied. Temperature, paint film thickness, flash off time between coats, fluid tip sizes, speed of the spray gun, surface type (Plastic or Metal) and humidity will all cause the color to shift lighter or darker.
The rule of thumb: the longer it takes to dry, the darker the color will change as it dries. This is caused by pigment floatation. The metallic flakes will settle down to the bottom of the paint film and push the pigment up causing the color to shift darker.
The reasons above only mention the variables at the car manufacturers level. So what happens to a color after three years of sunshine? Many people think that colors do not change, but they do, and I will prove it. If you own a car that is at least three years old and has been out in the sun most of the time, remove a pinstripe and you will see the original color when you bought the car.
The sunlight has ultra-violet, and has absorbed some of the pigments. Blue metallic colors sometimes shift to a greener shade, and reds will turn pinkish or more orange. The auto body shop has to deal with matching an oxidized color in addition to new OEM colors. The new paint to be applied will look brighter and cleaner but the rest of the car looks dead even if you polish it.
Auto Body Shops today have a greater challenge than just color match. The texture or (Orange Peel) also has to match the original finish in order for it to look pre-accident condition. This can be accomplished by using the proper spray gun, polishing equipment and experience.
How do you explain the bumper color change to the customer? Plastic bumpers will always change color especially in metallic colors. The plastic has a static charge and the metallic paint will settle different than on the sheet metal parts, causing pigment floatation that will shift the color darker or lighter. The other reason is surface temperature, if the sheet metal is colder, the bumper will look lighter, if the sheet metal is hotter than the bumper, the color on the bumper will look darker. The third reason is flex additive. If the clearcoat is applied on the bumper with a flex additive, it will shift the color slightly.
1. Know how the color you’re creating will reflect in the sunlight: Since pearl paint uniquely reflects light, you must be careful about what colors and amounts to select. When using white as a base coat for the pearl paint job, remember that any red-based paint will have a tendency to gleam pink in the sunlight. The best colors to stick to when going with a white base coat are blue, silver, gold, orange, and violet.
When using a black base coat, it’s very important to remember that if you use too much of the pearl paint, it will force the color to take on more of the pearl, and render the use of a black base pretty much useless. To achieve the right color, the ratio of the pearl should be one teaspoon per quart of base. Once the ratio is right, the paint job will take on a midnight, color-changing effect.
If the base coat that you are using is red, orange, or burgundy then the most recommended pearl coat is gold. Other options are red, blue, or violet pearls. When using a blue base, stick with gold, violet, or green pearl. A yellow base coat tends to look best with a green or gold pearl paint. Orange, red, and gold typically turn out great on a green base. A pink base will look very nice with silver or even red as the pearl paint. The purple base paint goes well with silver, green, or red pearl paint.
The final step, applied after the base and pearl coats is a clear coat. It is important to note that the clear coat should only be placed over custom paint and not over faux finish, gel coating, or powder coating.
I actually had this wing repainted after I got it back the first time because it was darker than the bumpers (which are also off, which is "normal"). I specifically remember the painter saying that he was going to change bases and go with a blue base. As far as the paint is concerned me matched it to the "standard sample" The chips he used had both a subaru and toyota variance. He mentioned they they were the exact same so for the 6 color chips he showed me there was really only 3 different colors, I assume the plus or minus 5%.
Hopefully this helps anyone who is as picky as I am as far at match. I was ready to take the wing back again for a 3rd time to have it redone, but after researching, it's time to stop being so picky and just enjoy.
EDIT:
So, this is what worked on my car. Obviously it will change with the car, but this should get the painter close. I would also like to note, they did have to blend the fenders on both sides.
And the match. It truly is pretty dead on. I'll take it.
[IMG]http://i62.photobucket.com/albums/h86/suaveflooder/D429***6-FDF9-4AC5-9544-C8CA00C03E21_zpsujoweusf.jpg[/IMG]
suaveflooder is offline   Reply With Quote
The Following 3 Users Say Thank You to suaveflooder For This Useful Post:
636 (04-13-2014), BIL90 (04-11-2014), unsurety (06-05-2014)
Old 04-11-2014, 02:21 PM   #2
BIL90
BIL90's Avatar
This drives me nuts also! Whiteout looks awesome, but I kind of wish I went with a different color because of this.
BIL90 is offline   Reply With Quote
The Following User Says Thank You to BIL90 For This Useful Post:
suaveflooder (04-11-2014)
Old 04-11-2014, 02:29 PM   #3
suaveflooder
I feel you. I've been obsessing over the wing for the last couple weeks. Truly, I don't even notice it until I'm in my garage, but then it sticks out like sore thumb and pisses me off. Walking up on the car will throw the white too at a certain able (because of the angle of the stollen wing) Short of not adding any body parts onto it, it's basically what you get. BEAUTIFUL color, but I'll probably stick to solid colors from now on and skip the 3 stage paint
Just going to sit on it and enjoy the car. For such a small part, the wing adds to much for me to get rid of it….maybe, I'll just find some "natural" bulbs for my garage. It would be cheaper
Old 04-11-2014, 02:35 PM   #4
BIL90
BIL90's Avatar
The wing really does make a huge difference as far as appearance goes. I've been looking to get a wing similar to yours. Where did u get it from? I've seen them for pretty cheap on ebay, but i'm not sure on their quality.
Old 04-11-2014, 03:02 PM   #5
suaveflooder
Lol, eBay . It was used but not painted.
Old 04-11-2014, 03:13 PM   #6
funwheeldrive
This is one of the reasons I didn't go with whiteout. Normally I love white cars, but I couldn't deal with the pearl.
It's probably the reason they are changing the shade of white for the MY15 cars.
Old 04-11-2014, 03:14 PM   #7
BIL90
BIL90's Avatar
How long have u had it on? And how is it holding up?
Old 04-11-2014, 03:49 PM   #8
suaveflooder
I knew there was a change, but really the only way to get rid of it is to get rid of the pearl. Are they doing that too? That would be awesome!
Total, two weeks or so. This second paint about a week and a half. I pulled if off after three days the first time, because it was a pretty bad eye sore. At least now it doesn't draw attention to itself. I've been reading that the color will still change a touch as the gases are released over the next 30-90 days. The car spends all it's time in the garage, so it might take longer. I'm not holding my breath really. Pretty sure, it's going to stay as is, which is okay with me
Old 04-11-2014, 03:52 PM   #9
FRSHunter
Drives: Asphalt FRS
No the next White color is Crystal White Pearl. I had this color on my RX8 before. The color is really nice, but good luck matching the color. Some random hater keyed my hood and I never bothered getting it repainted because I know the paint match would have been horrible. LOVED the color though.
It also doesn't help that white is one of the harder colors to match along with it having a pearl stage paint as well.
FRSHunter is offline   Reply With Quote
The Following User Says Thank You to FRSHunter For This Useful Post:
Old 04-11-2014, 04:19 PM   #10
suaveflooder
Dang! It looks so damn good. Just really sucks to match, just like you said. I figure if I repaint the car, I'm probably leaving the pearl out. If you look at the door jams, none of them have any pearl in them. The whole car will match then
Old 04-11-2014, 04:25 PM   #11
ayau
Drives: Some rust bucket
What kind of white are they using for MY15? A more flat white?
Old 04-11-2014, 04:30 PM   #12
fang_gt86
FR Noob
fang_gt86's Avatar
That's why there's the additional charge for whiteouts. It's just that special (in a very inconvenience way). .
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
The Following User Says Thank You to fang_gt86 For This Useful Post:
Old 04-11-2014, 05:14 PM   #13
FRSHunter
Drives: Asphalt FRS
Crystal White Pearl is a brighter white color. Whiteout is a more flatter white color.
I know RX8's had them, and I believe IS250 and the Miata comes in the same color.
Old 04-12-2014, 12:31 AM   #14
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i wish my fr-s was standard white... whiteout is too pearly.
zAnSh1n is offline   Reply With Quote
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 01:03 PM
FRS colors = Prius colors? lemonspeakers Scion FR-S / Toyota 86 GT86 General Forum 21 04-11-2013 12:14 AM
Whiteout/ Pearl paint issue: Metal panels not matching plastic/ rubber panels? jbsali Scion FR-S / Toyota 86 GT86 General Forum 20 02-04-2013 10:27 PM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 05:48 PM
Color matching? the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 7 09-14-2012 12:01 PM
