Old 04-11-2014, 07:48 AM   #1
cslntuee
Drives: Subaru BRZ Limited
shock questions
HI All,
I plan to buy the pink STI spring for my BRZ.
I have some questions as below.
1. What's different (road quality, handling..etc) between using the stock
shock and aftermarket one (ex. Bilstein B8)?
ps. 1. STI spring only have minor drop (15 mm) on both from and rear.
2. I am a daily driver without any track or autocross.
I hope can make the car more comfortable and also improve
some handling.
2. I saw the picture from Subaru BRZ Sti ts
http://www.ft86club.com/forums/showp...3&postcount=53
Did they also use Bilstein B8?
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 04-11-2014, 12:37 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Aftermarket shocks will have a different range of optimal damping. For example, the Bilstein B6's are used for non lowering springs. The B8's on the other hand should be used with lowering springs like RCE yellows. The valving is different for each.
2)
More comfortable but improving handling is a tough one with just springs. Since Koni have adjustable dampers, a set of those with some RCE yellows or B8's with Swifts would be a good setup. You can substitute the STI Pinks for those springs. I'm unsure if the B8's are adjustable or not.
The Following User Says Thank You to cdrazic93 For This Useful Post:
cslntuee (04-11-2014)
Old 04-11-2014, 06:01 PM   #3
cslntuee
Originally Posted by cdrazic93 View Post
1)
2)
Why you suggest using other spring (RCE,Swifts...etc) instead of STI?
Thanks again.
Old 04-12-2014, 03:15 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thanks again.
Simply because I have heard more about those than the STi Pinks, that's all
Old 04-12-2014, 03:52 PM   #5
CSG David
CSG David's Avatar
Recommend Swift as a lowering spring, but definitely not optimal.
Old 04-12-2014, 03:57 PM   #6
ayau
Drives: Some rust bucket
1)
2)
B6 and B8 have the same valving. You can Google B6 and B8 differences. Only difference is B8 is meant for lowering springs and B6 is meant for OEM springs.
The Following User Says Thank You to ayau For This Useful Post:
CSG David (04-12-2014)
Old 04-12-2014, 05:04 PM   #7
Racecomp Engineering
I don't think that's always true....
I realize there's lots of stuff on the web that says so but I don't think its definitive.
- Andy
Old 04-12-2014, 05:28 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
"The BILSTEIN B6 Sport is a mono-tube gas pressure shock absorber designed to dampen wide-ranging vibrations very precisely. Where an oil shock absorber produces an oily foam and creates a spongy driving feeling after a very short distance, the BILSTEIN B6 Sport remains constant, precise and stable. The BILSTEIN B8 Sprint is a mono-tube gas pressure shock absorber specifically designed to be used with lowered vehicles with shorter stroke. It also offers the same advantages as the BILSTEIN B6 Sport shock absorber."
From the Bilstein website. My thinking that they have different valving is becuase the B8s are designed for a shorter stroke, rather than the B6, which would require more aggressive valving...I could be wrong.
Old 04-13-2014, 01:14 AM   #9
cslntuee
HI All,
What kinds of different drive feeling that I should expect compare using
STI pink spring (or other) on stock shock and Bilstein B8?
Thanks again.
Old 04-13-2014, 03:06 AM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Stock shock vs B8, or B6, a Bilstein Monotube, is going to be the difference between the stock liquid filled shock and a nitrogen gas Monotube. The B6/8 wi be more sensitive valving. Liquid filled dampers will feel soft and spongy, where as gas filled shocks will feel like new everyday.
Lowering springs will make stock shocks ride a bit firmer, the B6/B8 are probably more comofortable with a lowering spring than the stickers with a spring
cslntuee (04-13-2014)
Old 04-13-2014, 09:10 AM   #11
cslntuee
HI,
Which setup (Stock or B8) you will suggest for the daily driver with mile drop (less than one inch ex. STI, TRD, Tanable, Swift..ect)?
ps. Compared with liquid filled and nitrogen gas stock, which has
longer lifetime?
Thanks.
Old 04-13-2014, 11:27 AM   #12
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I just ordered the Swift Spec R springs, the car is a DD with no track time?
thoughts?
Jmonty is offline   Reply With Quote
Old 04-13-2014, 12:43 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
HI,
longer lifetime?
Thanks.
Oh dear, longer lifetime? I would consult @CSG David about that one. That's as far as I can go lol. I would suggest some B8s with a spring of your choosing. A lot of people have had great success with RCE yellows, RCE Tarmacs or Swift. If you want to adjust the shock, than the Koni damper is the way to go.
Old 04-13-2014, 01:02 PM   #14
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Remember folks, if you put lowering springs on stock struts/shocks you will reduce their lifespan since they are not meant to operate in the range you are looking at with the lowering springs. RCE makes a set of springs that offer marginal lowering which will work with OEM Shocks/Struts.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
Bilstein Shock B6-B8 Victor Draken Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-22-2014 10:46 AM
WTB: Rear OEM Shock taimysho0 Want-To-Buy Requests 2 09-12-2013 11:23 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 11:00 AM
