#71 |
Grip>Slip
#72 | |
Drives: 2013 WR Blue Limited Manual BRZ
to auto tether with my Android everytime I get in the car, and just in case, download Sygic for offline Nav, super excited. I know I'll need this to keep USB functionality: [ame="http://www.amazon.com/Axxess-AX-TOYUSB-Adaptor-Retain-Vehicles/dp/B00EAYYQDO"]Amazon.com: Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles: Car Electronics[/ame] But I don't know what AUX adapter and Antenna adapter to get (didn't even know I needed an antenna adapter )
#73 | |
Drives: Scion FR-S
You can also use the following according to what their customer service told me: HUAWEI EC150 HUAWEI E1750 ZTE-MF668A ZTE-MF637U HUAWEI E261 HUAWEI E176G ZTE-T A356 ZTE-A351 ZTE-MG3732
Andrew
2013 Scion FR-S MT (Silver) 2011 Toyota Rav4 Sport V6 4wd (Silver) |
#74 | |
Drives: Scion FR-S
[ame="http://www.amazon.com/gp/product/B004W34BBK/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]Amazon.com : Scosche LSAAB Antenna Adapter for 2002-Up Dual Lexus : Vehicle Wiring Harnesses : Car Electronics[/ame] This USB Adapter: [ame="http://www.amazon.com/Axxess-AX-TOYUSB-Adaptor-Retain-Vehicles/dp/B00EAYYQDO/"]Amazon.com: Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles: Car Electronics[/ame] This adapter for the Aux Input (you have to swap one of the pins around - i forget which) [ame="http://www.amazon.com/Axxess-AX-TOY28SWC-Steering-Controller-Connector/dp/B00BXF5A74"]Amazon.com: Axxess AX-TOY28SWC Steering Wheel Controller Add-On Harness with RCA and 28-Pin Connector for Toyota Vehicles: Car Electronics[/ame]
Andrew
#75 | |
Drives: Scion FR-S
Andrew
#76 | |
Drives: Scion FR-S
This Antenna Adapter: [ame="http://www.amazon.com/gp/product/B004W34BBK/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]Amazon.com : Scosche LSAAB Antenna Adapter for 2002-Up Dual Lexus : Vehicle Wiring Harnesses : Car Electronics[/ame] This USB Adapter: [ame="http://www.amazon.com/Axxess-AX-TOYUSB-Adaptor-Retain-Vehicles/dp/B00EAYYQDO/"]Amazon.com: Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles: Car Electronics[/ame] This adapter for the Aux Input (you have to swap one of the pins around - i forget which) [ame="http://www.amazon.com/Axxess-AX-TOY28SWC-Steering-Controller-Connector/dp/B00BXF5A74"]Amazon.com: Axxess AX-TOY28SWC Steering Wheel Controller Add-On Harness with RCA and 28-Pin Connector for Toyota Vehicles: Car Electronics[/ame]
Andrew
| The Following User Says Thank You to SHIFTER For This Useful Post: | Kinickie (08-13-2014) |
#77 | |
Drives: Scion FR-S
See my other posts above this one for the cables you need if you want aux, usb, and antenna to work
Andrew
#78 | |
Drives: Scion FR-S
My previous generation unit got held in customs for one day - but that time it only took 4 days including that. They're fast once it ships!
Andrew
#79 |
Drives: Scion FR-S
Its meant for the Rav4 - works flawlessly, just have to move one of the pins around. Once you plug it in you will see which pin it is. Works great.
Andrew
#80 |
Drives: Scion FR-S
Just a note about the USB ports on this before I forget. It has two usb ports - one that is permanently wired (you cant unplug it) and one that plugs in to the back on the same harness as the ipod connector.
The hardwired USB port is for the Modem or Wifi only. The usb port on the ipod/accessory harness is for external hard drives/thumbdrives and any other usb accessory (no idea what else works). I have the usb port for the hard drives and stuff wired into my factory usb port using the adapter harness. Great for a quick thumbdrive with music.
Andrew
#81 | |
Drives: Neptune GR86
#82 |
#83 |
| The Following User Says Thank You to Deathalo For This Useful Post: | DC2R (04-10-2014) |
#84 | |
Drives: 2014 Scion FR-S
Sent from my SM-N900T using Tapatalk |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
