Old 04-05-2014, 09:59 PM   #687
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Who knows the sizes of the oil fitting that goes into the fuel pump and connects to the long braided oil line that plugs into the oil reservoir? AVO sent me one that is about 1/2x too small (the side that threads into the oil line) Totally f*** up my install today.
Old 04-05-2014, 10:11 PM   #688
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by spitfire481 View Post
A full 3" would help slightly but yeah, it's going to die off no matter what
I'm running a full 3" with similar numbers, but at 13psi, so I do think it helps.
gdrider77 is offline   Reply With Quote
Old 04-06-2014, 08:39 AM   #689
onzippy
Drives: 2014 FRS
Originally Posted by SkAsphalt View Post
Who knows the sizes of the oil fitting that goes into the fuel pump and connects to the long braided oil line....
You mean the oil pump right ? The 90degree hose fitting is sized for a 3/4" wrench so in my dealings with hydraulics, that's an AN-06 fitting.
The fitting that threads into the pump housing might be a NPT 3/8" - AN6 adapter.
onzippy is offline   Reply With Quote
The Following User Says Thank You to onzippy For This Useful Post:
SkAsphalt (04-06-2014)
Old 04-10-2014, 03:42 PM   #690
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Took mine for a rip last night and my boost gauge is saying about 7psi under full load in a higher gear.
I currently have a Delicious e-tune on my car for 5psi. Any suggestions on what I should do? Am I fine to drive around with a 5psi map with it boosting to 7psi until Bill sends me an updated map? Or should I adjust the wastegate actuator to turn it down to 5psi.
edit: Map 2 on my tune is an 8-9psi tune. Should I just run that one?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 04-10-2014, 03:43 PM   #691
protpibe
protpibe's Avatar
I should add that my AFR is seemingly fine at about 11.5ish
Old 04-10-2014, 03:48 PM   #692
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
That would definitely be a question for Bill. We don't know what your map is configured like.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 04-10-2014, 03:48 PM   #693
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Should be fine. Are you just on the original 5psi actuator?
brz2013 is offline   Reply With Quote
Old 04-10-2014, 03:59 PM   #694
protpibe
protpibe's Avatar
Yeah, it's the stage 1 5psi actuator. I'm assuming it's adjusted out to 7psi, so I guess I could back it off if I had to.
I'm just wondering if there's something I'm missing by thinking that if it hits 7psi and the AFR is solid, does it matter all that much until I get my map tweaked? I'm obviously waiting to hear from Bill for the verdict on this one, but my original plan was to run around 7-8ish PSI anyways.
deuce: The map is the Delicious 91 octane. My assumption is that companies have an "off the shelf" type of map for certain kits that they tweak based on someones mods and revise them as logs come in.
Old 04-10-2014, 04:01 PM   #695
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
There is no way to tell you what to do without seeing logs. AFR is only half of the puzzle with the other being ignition timing and knock. As long as your logs look good, then keep running the 7 psi and enjoy it. Just because you have a 5 psi actuator doesn't mean you will get exactly 5 psi.
protpibe (04-10-2014)
Old 04-10-2014, 04:08 PM   #696
brz2013
brz2013's Avatar
^^^^ exactly. Mines the opposite...if I turn of my boost controller I only get 3-4 psi so idk what's wrong with it but I have the 8psi one going on soon
Old 04-10-2014, 04:11 PM   #697
protpibe
protpibe's Avatar
That makes sense, thanks for the info.
Old 04-10-2014, 05:07 PM   #698
AVOturboworld
First-gen turbocharger kits had a 5psi actuator, and around the 3rd gen we moved to 6psi actuators as the base when long-term testing over multiple vehicles confirmed that would be safe enough on 91 octane of reasonable quality.
A 6psi actuator can easily have it at 7psi if it's screwed in a little tight on the pre-load and under high load. It should not be an issue if the tune is good and if the gas quality is ok. IAM may drop a bit if the gas is dodgy, though.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
protpibe (04-10-2014), SkAsphalt (04-11-2014)
Old 04-10-2014, 05:09 PM   #699
protpibe
protpibe's Avatar
Thanks for the info Paul!
Old 04-10-2014, 10:22 PM   #700
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Got a shipment from @AVOturboworld , can't wait to get these parts installed. Thanks again for the speedy shipment. Can't wait to get it on the Dyno at the end of the month.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
