Old 04-09-2014, 03:46 PM   #575
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Originally Posted by Jive Turkey View Post
on a staggered 8/9 setup i'd run a 235/45 front and a 245/40 or 255/25 rear (dependent on brand) some tires run really wide so a 245 can fill out a 9" no problem.
Unless you're talking about 17" wheels, you need to think a bit harder about those aspect ratios. Why would you actively choose a 235/45/18 when a 235/40/18 is perfect for an 8" wheel and significantly closer to the stock tire diameter? Same question stands for 245/40 and 255/25 (WTF?).
I'm sure you're on your phone - or have some other excuse for typos - but a large percentage of members on this site follow your recommendations as if they had come from Jesus. You've got yours but don't intentionally (or otherwise) mislead others as they attempt to follow in your footsteps.
sdemo is offline   Reply With Quote
Old 04-09-2014, 03:57 PM   #576
gramicci101
Off Topic
Well, I would go 235/40 and 265/35. They're both very similar in diameter, but they're about .8 inches taller than OEM. That's why I'm leaning towards 225/40 and 255/35. Same OD, only .4 inches taller than OEM.
Old 04-09-2014, 10:19 PM   #577
Juvenile
Juvenile's Avatar
Drives: 86 GTS
yes, and if you read the title in here should be 255 AT MINIMUM.
It's not mentioned in the title.Sorry I didn't read 27pgs to ask a simple question
Old 04-10-2014, 03:04 AM   #578
car_roll
Drives: Nuisance BRZ
It may not be in the title but its in the second line of the first post in red...
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 04-10-2014, 04:09 AM   #579
Kostamojen
Its an arbitrary number for an arbitrary term. Doesn't matter.
Lets not forget some 245's are physically wider than some 245's because once again, its arbitrary even for the manufacturers
Old 04-10-2014, 04:36 AM   #580
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I'm gonna ask a simple question so hopefully a simple answer without too much rage Widest staggered without any issues on stock struts w/ STI pink (0.6 inch drop) and camber adjustability parts would be ? 235front/255rear ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 04-10-2014, 09:47 AM   #581
Amir Ghadiri
Amir Ghadiri's Avatar
You can run 265 square without any issues on stock suspension, so you should be able to go a little bigger than that. If you want to be staggered, I'd go 245/265, maybe even 255/265. 265/265 square will fit on a 18x9.5 with a 38 offset on completely stock suspension. You are lowered a little over an inch, so in the rear your natural camber is going to help tuck the 265 a bit. In the front, the natural camber just isn't there, so you'd have to go a little smaller, so 245 or 255.
Amir Ghadiri is offline   Reply With Quote
Old 04-10-2014, 09:53 AM   #582
nlamon33
nlamon33's Avatar
Drives: 2013 SWP BRZ Limited
I don't think this can be said for any 18x9.5 wheel with 265's. Before I put my coilovers on I just lined up my wheel/tire to see what it'd look like. I couldn't even get the wheel on the studs because it was hitting the stock springs. This is a +40 offset so only 2mm difference from you but it looked like I would have needed much more than that...
nlamon33 is offline   Reply With Quote
Old 04-10-2014, 01:55 PM   #583
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yes, i'm sorry it were typos for sure, i HATE tapatalk.
anyways, the things i mentioned i base off of tires looking square on a wheel and having enough sidewall. a 235/40 is decent and yeah its closer to the oem tire size, but i don't think people who go for fitment and go to a meatier tire really care about stock diameter, atleast thats what the assumption is.
i by no means try to be "a guru", just passing on knowledge i soaked up.
i also base what i know from my times with the STi.
for example it came stock with a 8.5" wheel, on it a 245/40 was square. (a 245/35 is too small a sidewall) then take the wrx which has a 7.5" wheel factory and runs a 235/45 which is square.
then bump to a 9.5" wheel and a 265/35 is square and depends on tire brand so is a 255/35.
obviously none of this is taking into account stock diameters but thats what this is for:
http://www.miata.net/garage/tirecalcold.html
however i was just responding to the question of "what will fill out XX width wheel" so a 225-245 (depending on brand) is good for an 8" and a 255-275 (depending on brand) is good for 9-10"... and so on and so forth. then throw in different brands and etc etc.
hope this clears any mix-up up. just my train of thought here...
Jive Turkey is offline   Reply With Quote
Old 04-11-2014, 09:04 PM   #584
nlamon33
nlamon33's Avatar
Posted my setup a couple weeks ago but finally got my rear lca's and an alignment done. Dropped the car quite a bit more also. Rear fenders rolled, -2° rear and -2.3° front. Front fenders not even rolled and no rubbing so far at all. Full lock still doable. Crazy how big of a difference a good alignment makes. Texas track works in fort worth is awesome if anybody is from dfw. Really nice guys.
Wheels are 18x9.5 +40 enkei nt03's
Tires are continental extreme contact dw 265/35/18.
I'll have time next week to take some good pictures and I'll post them.
Old 04-13-2014, 09:10 PM   #585
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
255/35/18 Nitto NT555 all around
Scaldy is offline   Reply With Quote
Old 04-14-2014, 12:43 AM   #586
Jive Turkey
the tuna, no crust.
some rollers a friend snapped of me today. slowly getting to where i want it to be...
18x9.5+40 265/35/18 RE-11
KW clubsports, Cusco LCA, whiteline Toe.
The Following User Says Thank You to Jive Turkey For This Useful Post:
SkAsphalt (04-14-2014)
Old 04-14-2014, 08:34 AM   #587
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Joe-G is offline   Reply With Quote
The Following User Says Thank You to Joe-G For This Useful Post:
Old 04-14-2014, 09:24 AM   #588
nlamon33
nlamon33's Avatar
Gonna have to step on my own toes a few days later. Rubbed in the front on that little part by the side marker. Random bump through a turn. :/ no damage but I want to take care of it.
Has anybody rolled that tiny part in the front by themselves? I was going to take it somewhere but I have a heat gun and honestly it's so tiny I feel like it could be folded up pretty easily. I know of the ghetto bat method but seeing how small it is I feel like it could literally just be bent upwards once the paint is heated. I have never rolled a fender before. Any insight?
The Following User Says Thank You to nlamon33 For This Useful Post:
Jive Turkey (04-14-2014)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
