Old 04-08-2014, 12:50 PM   #589
frslee
Just drive it
Drives: 13' FR-S
Not FRS/BRZ related, but my friend will be taking his WRX to track for the first time.
Since first timer, should he keep his traction control on?
His current suspension/brake/tires are
BC Coilover
HP+ front
HPS rear
Hankook Ventus V12
frslee is offline   Reply With Quote
Old 04-08-2014, 04:38 PM   #590
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I think this might be a good question:
-I am a total track n00b. Planning to start going to track days, and start off my first times/season completely stock (except pads and fluid). For the first times/season, I just basically want to learn the ins and outs, etiquette, basics of track involvement and driving (lines, braking, speeds, beginner techniques, etc., etc.). Now, my question - should I start with all aids completely off?
I had an SR powered S13 in the past with a similar torsen lsd (from a j30) from about '98-2002 or '03 (before that was an EG..but I guess that doesn't count, since it's an FF). After the S13, I got a little '04 Tacoma Prerunner Reg Cab, and still have it and drive it to this day; so an additional 10 years of DDing another rwd car that had no sort of futuristic tractions aids. So, I think I'm not totally incompetent with an analog rwd car and I think I am decently versed in taking it easy and safely balancing a rwd. I besides that, I have no experience with new traction aided cars.
So..should I start with all aids off my first hpde beginner season?
fooddude is offline   Reply With Quote
Old 04-08-2014, 04:59 PM   #591
ayau
Drives: Some rust bucket
You'll eventually want all traction control off if you want to become a better driver. You don't have to. Whatever you're more comfortable with. I feel like it's more about a comfort thing more than anything. If you're not comfortable, then it'll be difficult to learn.
How much room is there to make a mistake? I'd run VSC Sport at a minimum. Once you're comfortable, then you can disable traction.
Old 04-09-2014, 12:27 AM   #592
kavanagh
Fat on Corn Syrup
Got a track related question? I'll try to answer.
I've only done three HPDE so far (latest was this past Sunday) and I've left traction control on most of the time.
The thing is, if you're smooth, then TC has no reason to interrupt you. If your slip angle goes too high, then it'll step in. I actually found VSC sport mode more intrusive than just leaving it alone the way it is when you start the car.
Fwiw I learned to drive in 1984 in a '74 Datsun Bluebird 1800 SSS and have owned more cars without TC than with.
Eventually you'll probably prefer to have it all off. I disable it now but only for more fun.
Old 04-09-2014, 12:45 AM   #593
CSG Mike
CSG Mike's Avatar
Originally Posted by normancw View Post
Would you recommend a baffled oil pan, like the FBM or RacerX oil pans under development, to help prevent oil starvation?
I haven't seen any signs of oil starvation on the CSG car, or any other FRS/BRZ I've driven.
This includes some highly modded cars on Hoosiers...
BatStig (04-09-2014)
Old 04-09-2014, 12:45 AM   #594
CSG Mike
CSG Mike's Avatar
BC Coilover
HP+ front
HPS rear
Hankook Ventus V12
Nope.
He'll COOK his brakes if he does...
Old 04-09-2014, 12:46 AM   #595
CSG Mike
CSG Mike's Avatar
Absolutely. It sounds like you already have an idea of what the aids will be doing anyways
fooddude (04-09-2014)
Old 04-09-2014, 02:10 PM   #596
fooddude
With pedal-dance-off mode... will the "ice mode" I've read about be a problem for me during n00b hpde1 sessions?
I believe it is mostly a concern/problem with quick fast pumps, lfb, etc., during technical autox, correct? ..so is track fine?
A summary would be great about the ice-mode problem in pedal dance mode. Like.. what most likely activates it, the cause, how to avoid it, solutions, etc. What exactly is ice mode, and is it dangerous? Does it lock up the brakes or something, or cause you to understeer to the extreme locked up (like straight into the dirt)?
Also, during pedal dance mode..is the VSC/TC completely disabled and never going to just "spontaneously" kick in out of nowhere? ..even if the buttons are pushed?
I honestly wish (I'm sure most do too, especially on here, lol) all this electronic mumbo jumbo was permanently off all the time, even for DD use. Then it'd behave like my old S13 again ...analog rwd's were fine for decades..why fix something that aint broke.
..then we wouldn't have all these dangerous "ice mode" and TC/VSC aids kicking in out of nowhere and without caution... those things just seem scary and make the car really unsafe.
Old 04-09-2014, 03:10 PM   #597
Carlysh
Carlysh's Avatar
Drives: 2007 Mazda 3, New Raven FR-S 6mt
Hi @CSG Mike I have a question regarding my tire I read you tip of putting a quarter on the tire but it reach to the cheek almost at the mouth my stock tires have 14k miles with 3 autocross event so don't really need know if I should buy tires or go with the stock tires my event is in april 27 on Sebring tha ks
Carlysh is offline   Reply With Quote
Old 04-09-2014, 06:59 PM   #598
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
@CSGMike, I'm thinking of upgrading to the AP Racing Sprint BBK, my only concern is that I'm currently running OEM wheels/tires while still learning the car on the track. I did previously burn through a set of BFG Rivals but have found the abundance of OEM tires available for cheap a better choice when it comes to learning car control on the track. In my experience so far, I've was averaging about 1'32" before I finished off the Rivals and now that I'm back on OEM's, averaging 1' 35". I am having hella fun learning and want to slowly upgrade the car, biggest problem I've had is overheating the brakes. I have already replaced the fluid with stop tech STR 600, put on SS brake lines and stop tech street performance pads. After tons of reading on here, I think the Sprint Kit is the best way to go from here. My only reservation is having to run a spacer to keep using my OEM wheels. (I picked up a second set of OEM wheels/tires cheap so I can run a set of track tires eventually and want to keep this ability for the time being). The big question, is it safe to run spacers on the track and if so, do you know what size spacer I would need?
TEWwild is offline   Reply With Quote
Old 04-09-2014, 07:45 PM   #599
dp1
driving smoother faster
Drives: Sold
I got 12mm spacers from amazon and I have about 3-4mm clearance from the closest point of the rims to the Sprint caliper, with stock rims. I had read that 10mm was sufficient but wanted to be safe. Haven't used them on track yet but planning to.
[ame="http://www.amazon.com/12mm-5x100-Hubcentric-Wheel-Spacers/dp/B00A7I2TU4/ref=pd_sim_sbs_auto_9?ie=UTF8&refRID=1J9T7H83SKS8C 9FEF19T"]Amazon.com: 2pc 12mm (1/2") 5x100 Hubcentric Wheel Spacers - for Scion FRS FR-S Subaru WRX Impreza (56.1 bore): Automotive[/ame]
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
TEWwild (04-09-2014)
Old 04-09-2014, 08:14 PM   #600
CSG Mike
CSG Mike's Avatar
If it's your first event, you'll be okay
Carlysh (04-09-2014)
Old 04-09-2014, 08:15 PM   #601
CSG Mike
CSG Mike's Avatar
Ice mode is engageed when you go from gas to MASHING the brake pedal VERY quickly.
I've never engaged it under normal driving, even when I'm doing for hot/record laps. I can force it to happen, but I also need to go DEEP into ABS engagement to do so.
Correct, everything is disabled except the ABS.
Old 04-09-2014, 08:17 PM   #602
CSG Mike
CSG Mike's Avatar
Spacers are safe. You'll need 10mm spacers, open ended lug nuts, and extended studs to run them safely and clear the AP Sprint kit.
Let us know when you want to purchase
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
