Old 04-08-2014, 02:55 AM   #295
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by *LongFella View Post
Correct. I never replaced or removed anything. I simply added the metal one that came with the kit to the location ensuring it is faced/positioned the right way. Your just removing the hose, cutting at the specific location, placing the metal PVC valve, making sure it blocks air from the correct side when blowing into it, and re-installing it...
We need to get a check valve into your PCV line.
@mkivsoopra
The Following User Says Thank You to sw20kosh For This Useful Post:
mkivsoopra (04-08-2014)
Old 04-08-2014, 07:50 PM   #296
gbrz
what aftermarket radiators/setups is everyone using? and is it track tested?
gbrz is offline   Reply With Quote
Old 04-08-2014, 08:15 PM   #297
CSG David
CSG David's Avatar
Stock radiator is fine for tracking. Aftermarket is a nice to have but not necessary. We have sufficient data for that.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
gbrz (04-08-2014), sklimo (04-09-2014), SuperDave (04-08-2014)
Old 04-08-2014, 08:41 PM   #298
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thanks for not posting the typical party line and trying to sell unnecessary products.
Old 04-08-2014, 09:36 PM   #299
sw20kosh
Originally Posted by normancw View Post
Sorry, I have have to say every time I drive now, I'm like ... and my passenger is like
Congrats! This platform is meant to be enjoyed like that! Too bad it didn't come with this much fun from toyobaru...
sklimo (04-09-2014)
Old 04-08-2014, 09:48 PM   #300
gbrz
Thanks Dave - besides the oil cooler, do you think there are any other parts that ARE necessary for tracking? such as a catch can?
Old 04-08-2014, 11:01 PM   #301
CSG Mike
CSG Mike's Avatar
A baffled catch can should be used if you're cornering while under boost. Also, keep a close eye on your oil level.
Old 04-08-2014, 11:28 PM   #302
dp1
driving smoother faster
Drives: Sold
Does Crawford AOS work as well as a baffled catch can for cornering under boost?
dp1 is offline   Reply With Quote
Old 04-08-2014, 11:32 PM   #303
CSG Mike
CSG Mike's Avatar
The Crawford AOS is a catch can with a fancy name
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
DC2R (04-08-2014), dp1 (04-08-2014), sklimo (04-09-2014)
Old 04-08-2014, 11:41 PM   #304
dp1
Drives: Sold
Point taken . Hope it's also baffled...I believe I read that internals are little mystique...if you happen to know...
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (04-09-2014)
Old 04-09-2014, 08:59 AM   #305
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Hey Mike, I'm looking at going with an oil cooler that will work with either the JR or KW kit, which I won't be buying for a little while; but would rather buy a oil cooler that I don't have to change out when I go with either kit. I know the JR oil cooler kit is made specifically to work with the JR SC kit, but WILL it work without the SC kit? Is there something in the JR oil cooler kit that only allows it to work with the JR SC? I'm not worried about how it looks (offset mounting to make room for the Rotrex cooler).
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 04-09-2014, 11:16 AM   #306
djdnz
1337
Drives: 2013 BRZ WRB S/C
I'd be more concerned about whether or not the JR oil cooler will fit with a KW kit. The KW kit has trouble with most oil coolers given the proximity of the gear train for the supercharger.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
smbstyle (04-09-2014)
Old 04-09-2014, 11:38 AM   #307
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
This. The enormous KW SC mounting bracket completely blocks the traditional Mocal type sandwich adapters and lines for oil coolers. KW has a specially designed adapter that brings the connections back behind all that. As far as I know there is no other way to run an oil cooler with the KW kit other than their proprietary Skunk2 adapter. Here is a pic of what I'm talking about. Not sure if it's thermostatic, I'm guessing it's not.
Old 04-09-2014, 01:37 PM   #308
CSG Mike
CSG Mike's Avatar
Yes, it will work as a stand-alone unit; please specify when you order and it'll come with a different bracket that centers the oil cooler
It is ultimately a universal oil cooler kit (albeit, a much higher capacity cooler than most on the market), that happens to work with the Jackson Racing supercharger. Both the supercharger and engine oil cooler kits were designed ground up to work independently OR together.
The Kraftwerks kit does not have any supporting brackets that will allow for an oil cooler to be mounted between the FMIC and AC Condenser. Additionally, their gear/pulley system makes putting the thermostatic Jackson Racing sandwich plate on... impossible.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
