Old 04-04-2014, 05:33 PM   #71
steve99
Drives: FT86
Originally Posted by Fizz View Post
Loaded your 98RON map to my car, and took it for a spin. Looking better now the IAM up to 0.94 at the end of the run.
What do ya think? Any particular issues? There's a number of times where the KC dropped, as low as -2.8 is that something to be concerned about?
http://datazap.me/u/fizz/98ron-map-l...0&data=1-11-12
It looks better knock wise that previous but, still getting a bit 5000-7000 I think your exhaust mods , High flow cat ect have changed things a bit , as I did this map on a stock car.
did shiv get back to you about running the stage 2 map ??
look like you might have to be much more aggressive in pulling timing on that setup
see post here
http://www.ft86club.com/forums/showp...5&postcount=18
that was on stage 2 map timing
Old 04-04-2014, 08:44 PM   #72
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
see post here
Thanks. No I haven't heard back from Shiv yet. I'll keep monitoring things over weekend and hope he responds with a fix
Fizz is offline   Reply With Quote
Old 04-05-2014, 06:56 AM   #73
s2d4
s2d4's Avatar
For what its worth, here are my findings:
1. As @arghx7 said, fuel quality hasn't helped, nor has butchering timing for the low rpm/high load condition for FBKC. I can reproduce it every time but that is driving like an idiot in 4th gear loading up from~1500-3000rpm, so driving normally or at the track won't happen.
2. As @Fizz mentioned, ambient temperature is definitely a factor. Now that temperature has dropped to mid 20s instead of 35-40 degrees celsius, it doesn't happen as often or severe. I've even added all the timing back and it is way better now than butchered timing during hot conditions.
3. With suggestions from @steve99, switching from 98 to 100 has definitely helped with FLKC, only -.35 in a couple of cells and IAM stays solid at 1.
Thanks guys, keep up the good work as we've definitely learnt a lot on this forum.
The Following User Says Thank You to s2d4 For This Useful Post:
steve99 (04-05-2014)
Old 04-05-2014, 07:12 AM   #74
DEK186
DEK186's Avatar
Drives: 86 GT MT Velocity Orange
Has anyone got the RR xml file for the 700I rom? Doesn't seem to be in with all the rest of them.
DEK186 is offline   Reply With Quote
Old 04-05-2014, 08:03 AM   #75
troek
troek's Avatar
Drives: 2012 Toyota 86
i see this too in japan, but its so rare i havnt been able to nail it down yet. i can blast around a track all day and have zero issues, but ill be idling in traffic and notice it drop to .86 or a little higher
troek is offline   Reply With Quote
Old 04-05-2014, 08:08 AM   #76
steve99
Drives: FT86
Try the timing changes in the 100RON map only timing pulled is 0.35 2000-3000 rpm nothing up top end, will stop the iam drop in traffic and not effect top end, you fuel probably better than ours, but check for flkc 5000-7000.
troek (04-05-2014)
Old 04-05-2014, 08:11 AM   #77
steve99
Drives: FT86
If you have OFT pretty sure map it will load is based on later Rom updates, if you have tactrix just load later rom
Old 04-05-2014, 09:28 AM   #78
troek
troek's Avatar
im gona be switching to stage 2 soon, so im not gona bother till then( cause im too lazy, lol). but if i still see that issue ill give it a try. seems like the ticket though.
Old 04-05-2014, 10:05 AM   #79
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you guys have been experiencing the knock due to high IAT, you could always adjust the IAT timing compensation. Then you won't have to adjust your maps seasonally. Most of the ECU calculations seem to base normal IAT at 20c.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-05-2014, 06:36 PM   #80
steve99
Drives: FT86
I did most of my testing at night (less traffic & to avoid IAT compensations) so it was around 20-25C ,but something to think about thanks. In traffic IAT's here can get 40C+ where ecu starts to pull timing due temps.
Old 04-09-2014, 07:34 AM   #81
DEK186
DEK186's Avatar
Just trying to load the 700I & A00I maps into RomRaider for editing, but no definition files are available for these roms on the OFT website. Is there another location I should be searching for them??
Also, the OFT website is missing maps for the A00I rom. How hard is it to compile these once you have access to the RR definition file?
Old 04-09-2014, 07:42 AM   #82
steve99
Drives: FT86
If the structure of the ROM is the same, ie same tables and the ROM update was just a calibration update ie they changed some values in the tables not the structure. Then you should be able to just changes all the references to A01I to A001 with a text editor and make a definition file.
but I am not going to guarantee your success.
Are you trying to edit your original ROM or the OFT rOM ?? , usually the OFT ROM is based on the later update probably A01I so you should use that definition.
Old 04-09-2014, 07:57 AM   #83
DEK186
DEK186's Avatar
There are some new OFT users in the 86/BRZ club in Brisbane - one has a 700I ECU for which we dont have a def file for (to be able to modify the available OFT maps), and one guy has an A00I ecu for which we don't have a def file or OFT maps
Old 04-09-2014, 08:03 AM   #84
steve99
Drives: FT86
So these guys have read their original rom's into oft and flashed an OFT tune to their cars ??
The ECU's are the same its just the firmware (ROM) that changes, you can flash a 700I with A00I or A01I
If the oft has flashed it it will likely be a A01I spec ROM in the cars now.
So just edit the Stage 1 A01I ROM load it up to OFT and flash it.
If the OFT won't flash it then talk to Shiv at vishnu and he will sort it out
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 11:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 09:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 04:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
