Old 12-24-2013, 12:10 AM   #15
Luna
Drives: 08 Scion xB, 13 BRZ Limited
I have the honking noise too Only intermittently though and only when starting from a complete stop. You think the crickets are embarrassing...until you get the goose
I'm at 7k miles and I hadn't noticed it until recently.
Luna is offline   Reply With Quote
Old 12-24-2013, 04:45 PM   #16
Notso
Drives: Subaru BRZ
any update on this? I'm just now getting this, annoying as all hell
Notso is offline   Reply With Quote
Old 01-04-2014, 11:06 AM   #17
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Originally Posted by Burninator View Post
Just wanted to post back here with what the dealership found. After 5 days in the shop with the transmission disassembled they replaced the throwout bearing (iirc in the service ticket it was labeled as a release bearing actually) because it was "slightly deformed".
I haven't heard the noise again since I picked it up, so I guess only time will tell at this point whether or not this was truly the problem.
I'll put up a scan of the service ticket when I get home later this evening.
So was the throwout bearing definitely the culprit?
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 01-04-2014, 11:39 AM   #18
Burninator
Trogdor ftw
Burninator's Avatar
Drives: Asphalt FR-S M/T
If you are getting the same noise as in the video I linked in my first post, it seems to be the throwout bearing. I haven't had the noise come back since the dealer took the transmission apart, replaced the bearing, and put it all back together.
"Hell hath no fury like a driver stuck behind a Toyota Prius."
Burninator is offline   Reply With Quote
The Following User Says Thank You to Burninator For This Useful Post:
BRZNutt (01-04-2014)
Old 03-28-2014, 11:40 PM   #19
Boostedpro
Mine doesn't honk, it makes a whooosh sound when I shift at 4500-5000 rpm. Might have something to do with my Perrin cold air intake and tune though.
Boostedpro is offline   Reply With Quote
Old 04-08-2014, 08:49 PM   #20
Luna
Originally Posted by Monogram View Post
My car started making the honking sound when shifting from 2nd to 3rd around the 4,000rpm range.
That's how mine is too. Only from a stop, when shifting into 2nd or 3rd gear (sometimes both), and only when it's been 40-50 degrees outside. When it has been any colder or any hotter it doesn't make the noise. Normally it's only when you press the clutch in, but I actually had it make the noise when I was letting off the clutch the other day. I HATE THE FUCKING GOOSE.
Oh, and with the warm temps, the crickets are back. But really, the goose is worse.
Old 04-09-2014, 07:37 PM   #21
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Ok, so I'm not going crazy.
This is hilarious. The first day I got my brz I noticed this; I thought I had hit the horn when making a turn.
Jesse36m3 is offline   Reply With Quote
Old 04-11-2014, 07:10 PM   #22
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I thought I was going crazy, too. Just noticed it last month. Didn't know this was an actual thing haha
Propaganda is offline   Reply With Quote
The Following User Says Thank You to Propaganda For This Useful Post:
speeddemon (03-12-2015)
Old 04-14-2014, 08:44 PM   #23
8R6
8R6's Avatar
Drives: FRS
damn im not the only one either!! i thought something was wrong with the electrical wiring and causing the stupid goose honking sound. damn crickets and geese. wtf is next?! lol
8R6 is offline   Reply With Quote
Old 04-22-2014, 10:59 PM   #24
Liebot
Liebot's Avatar
I also had the faint honking sound and this is what my dealership is repairing as well.
Liebot is offline   Reply With Quote
Old 04-22-2014, 11:26 PM   #25
iniguez310
Cool Guy
Check your grounds people!
iniguez310 is offline   Reply With Quote
Old 04-23-2014, 08:57 AM   #26
Mikem53
Drives: FR-S 6MT
What? It's not an electrical problem.. It's a mechanical issue within the bell housing/clutch
Mikem53 is offline   Reply With Quote
Old 04-23-2014, 06:53 PM   #27
iniguez310
Cool Guy
Crap, i guess i shouldve read the thread first. I said that because when i first got mine i would honk the horn and it sounded faint. So i took it off sanded at the grounding point then threw it back on so it went away.
I get this sound when the clutch is fully pressed. At around an inch from the floor there is that faint honking like sound. It doesnt always do it but its starting to do it more often now.
The Following User Says Thank You to iniguez310 For This Useful Post:
Mikem53 (04-23-2014)
Old 04-23-2014, 07:40 PM   #28
Liebot
Liebot's Avatar
Well, my dealership fixed the throwout bearing and replaced the clutch...and still get THE GOOSE.
It's a mystery at this point...more details to follow tomorrow.
The Following User Says Thank You to Liebot For This Useful Post:
iniguez310 (04-23-2014)
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 03:54 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 05:17 PM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 07:03 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 02:33 AM
