go_a_way1
Old 04-04-2014, 07:17 PM   #477
allmotorrex
allmotorrex's Avatar
Drives: 08 4x4 offroad tacoma/ raven fr-s
What if you had 12 blowouts? Hahaha sorry, no bad carma.
allmotorrex is offline   Reply With Quote
Old 04-06-2014, 12:41 AM   #478
tapsumbongfrs
drift on budget
tapsumbongfrs's Avatar
Drives: Scion FR-S
Had fun!
[ame]http://youtu.be/wvfzQfz-e5w[/ame]
tapsumbongfrs is offline   Reply With Quote
The Following 3 Users Say Thank You to tapsumbongfrs For This Useful Post:
diss7 (04-06-2014), MAKK (04-07-2014), OAKOS Automotive (04-08-2014)
Old 04-06-2014, 12:01 PM   #479
MAKK
MAKK's Avatar
Drives: SWP BRZ
Might as well post mine too ^ First time connecting the track, but unfortunately my last run as well for the day
[ame]http://youtu.be/Im34X54GPxU[/ame]
Originally Posted by RavSpec View Post
This is an art, just enjoy ur creation and brush off the negative one.
MAKK is offline   Reply With Quote
The Following 3 Users Say Thank You to MAKK For This Useful Post:
diss7 (04-06-2014), OAKOS Automotive (04-08-2014), tapsumbongfrs (04-07-2014)
Old 04-06-2014, 06:24 PM   #480
diss7
Drives: AE86, 2x GT86, TE27
Some quick comments on my drift day on Saturday:
1. Dont use scissor jacks
2. Hardrace tierods are deece. Lots more lock. My lock is now limited by the fact my tyre is rubbing against the inside.
3. Solid subframe makes the car MUCH more predictable. Its also easier to initiate, althought this was being held back by my poor alignment settings, see below.
4. Rollcentre correction and whiteline sways have eliminated all of my body roll (good thing)
5. I tried -0.5deg camber on the back, in the hope tyres would last longer. And they did. Much more smokey too (assume because much more tyre contact patch) But WAY to much grip on stock 86 power. I couldn't link sections that 3 days earlier I could. It couldn't keep 3rd going at all, despite rapey clutch kicking. Revs just continue to die. Where as before it would keep 3rd going quite happily. FYI I was on -2.5deg camber before. Tyre wear was very even on -0.5 though; when I have more power, this is definitely what I'll be running.
Going to do some work on the front now. Want to increase track, for more room for more lock. Will flip top hat to positive camber setting, this gives about 30mm more up top, then will pump out the bottom via a new LCA 40-45mm or so (either side). I dont like any of the current front lower control arms currently available, (they're not made for drifters IMO, not enough track width adjustment) so am going to develop my own. I've taken some quick measurements, and even with this track increase my volks will still sneak under the guard (has to be to be street legal here) But my Meisters definitely won't anymore
My volks are 17x7.5 + 48. But with what I'm planning, they'll sit about 5mm further out (but with slightly more camber) than my 18x9 +35 Meisters currently do.
I'll also need to come up with a custom tie rod and rod end solution to suit the extra track. I really want to keep the stock rack and knuckles (Well I have to, as both are forbidden to be modified in our drift series' in NZ) Will be interesting to see how much more the stock rack has to use. If its not much more than it is with my current setup, I might only increase track 20mm either side. Will do that by just setting tophat to central, and pump out bottom 20mm. Then I can probably still run Meisters, may need that 10mm wider fender.
So really need to take some measurements of stock rack actual range first.
Will keep you informed.
diss7 is offline   Reply With Quote
The Following 3 Users Say Thank You to diss7 For This Useful Post:
Chase Bays (04-07-2014), OAKOS Automotive (04-08-2014), tapsumbongfrs (04-07-2014)
Old 04-07-2014, 06:50 AM   #481
diss7
Quick video from the weekend
The Following 2 Users Say Thank You to diss7 For This Useful Post:
Chase Bays (04-09-2014), MAKK (04-07-2014)
Old 04-07-2014, 12:37 PM   #482
namdoog
Drives: Crystal Black Silica BRZ
Originally Posted by tapsumbongfrs View Post
Had fun!
Good to have some fellow CL drivers on board! I sadly won't be out until Freedom Moves I think
IG @andrewgoodman
I take real pictures sometimes too http://flickr.com/photos/andrewegoodman
namdoog is offline   Reply With Quote
Old 04-07-2014, 02:23 PM   #483
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
@diss7
What tires were you running on the rear in that video? What psi? Also, what RLCAs are you running.
I have toe links on the way and between the two, I should be able to get the camber down by quite a bit. Just curious what you're running.
Old 04-07-2014, 05:39 PM   #484
diss7
Originally Posted by TylerLieberman View Post
@diss7
See further up. Racefab arms.
In that video I was running 205/40/17 Linglong Crosswind's. I find they give okay grip, but most importantly they dont delam/explode.
I was running 30psi cold front, 50psi cold rear. Alignment I'm around zero toe -2 camber up front; zerp toe -0.5 camber rear. Not certain though, they were just what we 'eye'ligned before this track day. We did use levels and tapes etc so we'd be pretty close.
I don't recommend -0.5 camber in the rear. Car can't keep third going. You can hear me clutch kicking it in the video just to make the corner. But the tyres wore very very well.
I don't like running such different grip levels front and back. Which as a result of my different tyre pressures I am. I find that the front digs/grips in while under a 4 wheels slide, and the car wants to spin. But I have to run the setup that I do because of lack of power.
When I put the turbo on, I'll run this alignment but with 30psi front and back. Only want to run ~7psi boost so I can still rape/limit bash the motor, so 205's should still be okay. If not I'll go to a 225 or 235. Want to try Federals next. But have a dozen new linglongs to get through. Mind you, I could sell them. IDK.
Tyler, if you're looking to reduce camber, get UCA's not LCA's. Alot of LCA's can only INCREASE camber. That was the case with the racefab arms, and I know some others are the same. (When the new LCA is wound in, its the same length as the OEM LCA. So the new LCA can only get longer, therefore only increase camber.)
Plus, UCA's are better because they don't change the toe when you adjust them, unlike the LCA.
My UCA had adjustment either way compared to the OEM UCA. So could increase or decrease camber.
The Following User Says Thank You to diss7 For This Useful Post:
JordanWho (04-22-2014)
Old 04-07-2014, 11:51 PM   #485
diss7
Seems to be a need for a place for drift orientated 86 owners to talk about a common interest. Not intending on taking away from any traffic here (and yes got Admin approval before posting this here) Just looking to invite others that have a similar mind set about their 86. Page/group is called GT86 Drift club.
Here's the description/rules...
Toyota GT86 Drift club.
Don't join if you:
Think the driving aids are necessary
Don't want to see skids
Think street drifting is bad
Want to talk about fuel mileage
Want to talk about plasti-dipping your wheels/intake/tampon
Think that your Auto 86 is awesome
Want to discuss group buys of sharkfins.
Cannot take banter.
Two rules
1: If you want to join, you need to provide an action picture/video of your 86 drifting, or at the very least, doing something impressive.
2: Anything shared within the club is done so for club members viewing only. No sharing of material posted within.
FullTuneZN6 (04-21-2014), JordanWho (04-20-2014), Skidrcn (04-08-2014)
Old 04-07-2014, 11:57 PM   #486
tapsumbongfrs
drift on budget
Drives: Scion FR-S
clean and smooth surface track! jelly @diss7
Old 04-08-2014, 12:39 AM   #487
diss7
Yeah we're quite lucky. Christchurch used to have massive street drifting scene. Still sort of does. But the local car club are making their track available for us more often, so we're getting a heap of time.
Just recently,
March 19: Drift practise day
April 1: Drift practise day
April 5th: Regional drift comp day (Driftsouth)
April 15th : Drift practise day
April 19th/20th: National drift comp round at our track (D1NZ)
April 23rd: Drift practise day
May 19th: Drift practise day
Old 04-08-2014, 12:56 AM   #488
TylerLieberman
Drives: '24 GR86
@diss7
Gotcha. I'm running Stance LCAs. I'm about -1.7 right now but my toe links are maxed. I have RacerX toe links on the way. With everything said and done, I'm just trying to get between -1.5 and -1. There's still a good amount of adjustment left on my LCAs too. I know I won't be able to get to -0.5 or 0 though. Definitely would need the UCAs.
I'm staying NA though. Getting the Nameless header and stuff so I think the car should be able to manage that setup pretty well.
The Following User Says Thank You to TylerLieberman For This Useful Post:
diss7 (04-08-2014)
Old 04-08-2014, 01:44 PM   #489
Skidrcn
Drives: 2013 Hot Lava FRS
@diss7 just sent a request to join the group on FB (Bryce) I do not have photos of the FRS Sliding just yet but I do have photos of my old 240 I can toss up sliding to show I am not some squid haha
Bryce
Skidrcn is offline   Reply With Quote
Old 04-08-2014, 04:39 PM   #490
diss7
Bryce
That's all good. I've actually said in there that's ok, as I accept that some are using their gt86 as a daily, while drifting something else.
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 20 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
