Old 03-26-2014, 07:57 PM   #799
itzmik3
DBC Racing
itzmik3's Avatar
out of curiosity how many clutch plates are per side?
#194 SM
itzmik3 is offline   Reply With Quote
Old 04-01-2014, 07:46 AM   #800
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
no idea.. thats something you would have to talk to Matt on.. I know the lockup rate and the decel rate.. and that I can definitely feel the difference ...
Car is ready to go for the 2014 season with some new goodies and also refining the old stuff.
New: Guard Transmission Rear LSD
As well as new Adj rear Lower Control Arms :
Tweeked the alignment settings a bit..
and....oh yeah.. installed the 'Claw'... Latest Revision Ceramic coated goodness from Nameless Performance and tune.
thats pretty much the update... not much left to do as-per the STX Ruleset.
now its just a matter of tweaking.. and getting comfortable with the new setup.
Put in my Race Seat.. 5pt next....
Ok.. I ended up with a Corbeau FX1.. I used the stock sliders with Custom side rails. and stock seat belt mount. Very happy..
Here are the pics. I have some tinkering to do. but for the most part, Done
my motto for the whole build has been to : "Completely take away the car from the equation and concentrate on driving".. Now that the car is pretty much to the letter of the rules.. I can completely concentrate on driving and learning the new setup . I do have a surprise or two left in the goody bag.. especially with tire choice...
Thanks for the interest
Bill
Scooby South is offline   Reply With Quote
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
chanomatik (04-17-2014), forwallblakmail (04-20-2014)
Old 04-01-2014, 10:08 AM   #801
was385
Drives: MT WRB BRZ Limited, 2007 911s
So jealous of this awesome build. One day when this thing isn't my DD I'll be using this thread as a guide. Good luck this season. Can't wait to hear some of your impressions on the new setup.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
Scooby South (04-01-2014)
Old 04-03-2014, 11:13 AM   #802
Scooby South
Conedancer
Bill
Forgot to mention.. corner balancing here soon too . not many options left to do for a FULL STX Build. just some minor things.
Enjoy. Season for the car starts Next weekend at Wilmington Match tour in Wilmington Ohio where a number of Twins is pre-registered...Look forward to to
Bill
chanomatik (04-17-2014), fstlane (04-03-2014)
Old 04-07-2014, 06:15 PM   #803
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
So, I'm imagining that the lockup under acceleration in the new diff is intended to be more progressive than stock (to keep power oversteer in check), and with little to no lockup on deceleration for better turn-in?
Also that you intend to take out some of the excess negative camber out of the rear?
neurokinetik is offline   Reply With Quote
Old 04-07-2014, 07:16 PM   #804
Scooby South
Conedancer
Correct.. on all accounts.. Should be able to get to the gas a bit quicker and stay on it longer.. before turnin..
Bill
chanomatik (04-17-2014), neurokinetik (04-08-2014)
Old 04-17-2014, 07:20 PM   #805
Scooby South
Conedancer
Fastest Run At Wilmington 66.1. Good enough for 3 bonus rounds. on Sunday. Car felt awesome.. Federal RSR 595 Tires. Made some adjustments on the front ride height..and soem rebound/compression adjustments on the back. still has a bit of push on exit.. more adjustment to do.. This was good enough for 7th place a 1/10th out of the trophies.. It felt good to drive my own car and for it to be competitive..
[ame]http://youtu.be/4eaTfluuIWQ[/ame]
[ame="http://youtu.be/hP0o5_Ws3AI"][/ame]
The Following 3 Users Say Thank You to Scooby South For This Useful Post:
brz7400 (04-17-2014), chanomatik (04-17-2014), Shankenstein (04-23-2014)
Old 04-17-2014, 09:24 PM   #806
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Why are you staying with the Federals?
I don't think they would be my 1st choice.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-18-2014, 10:26 AM   #807
Scooby South
Conedancer
Simmons
on Asphalt.. they ROCK. I put them on par with Toyo's.. .. on Concrete.. they were faster than Dunlaps.. .. trying something different this year.. so far its working..
Bill
Old 04-18-2014, 10:31 AM   #808
Scooby South
Conedancer
oh.. it was also the first time the car had been out this season and I think it did pretty well with all the new changes I did over the winter make the car faster.. so now its up to me, the driver...taking the car out of the equation.
Bill
chanomatik (04-18-2014), FastWhite (04-18-2014)
Old 04-22-2014, 10:22 AM   #809
Scooby South
Conedancer
Car is getting closer and closer to being completely dialed in.. Car Took 1st and 3rd on index at our first local event in Milwaukee..
[ame="http://www.youtube.com/watch?v=qJ5W7qLQ-9s&feature=share&list=UUJ91sP-zsNPiHXLa4E8rklg&index=1"]Milwaukee SCCA opener 042013 Fast run 48.7 - YouTube[/ame]
The Following 4 Users Say Thank You to Scooby South For This Useful Post:
brz7400 (04-22-2014), chanomatik (05-02-2014), MTCRX (04-24-2014), Shankenstein (04-23-2014)
Old 04-26-2014, 08:24 PM   #810
Scooby South
Conedancer
Figured I would update my Mod lost
Full National STX Build
2013 Subaru BRZ limited , Satin White Pearl, 6 spd manual
Engine:
-DIY intake with K&N filter, Sound Generator Delete, Gold Wrapped intake tube and Gold stock Air box
-Kartboy Oilcap
-Kartboy LW Engine Pully
-Nameless Ecutek Tune , 8k redline, Flat Foot Shift, Launch control
-Mobil 1 0-20 oil
-Ballistic 3.5lb lithium ion Battery 500CCA.
Exhaust:
-Nameless Lastest Generation Long tube ceramic coated Header
-Nameless 2.5 in stainless with Overpipe with Cat and hemholtz Resinator.
-Nameless 5in stainless Muffler axleback
Suspension:
-KW Var 3 coilovers with 7k front and rear springs
-Front Camber plates
-Truhart rear adj lower control arms
-Whiteline Steering Rack Bushings
-Whiteline Rear Diff Bushings
-Whiteline Cradle Bushings
-Whiteline Front 20-22 adj front Sway bar
-Whiteline front adj swaybar endlinks
-Whiteline Front control arm offset bushings
-Subaru OEM STi rear sway bar
-Kartboy Rear swaybar endlinks.
Drivetrain:
-Kartboy Short Shifter
-Kartboy Trannymount insert
-Cusco Engine Mounts
-Guard Transmission LSD
-Stoptech front BBK with aluminum hatted rotors
-OEM Subaru rear 2 pot brakes
-Stoptech Stainless Brake lines
-Motul RBF 5.1 brakefluid
Interior:
-JPM Coachworks double thick Alcantera Steering wheel
-Corbeau FX1 Drivers fixed back seat with custom mounts
Misc:
-Generic hood Struts
-11lb hidden rear trailer hitch
-Center console armrest
-Valentine 1
-Garmin with traffic control
-30% tint
Rims/tires:
-Rota 17x9*42 Titan with 255/40/17 Dunlop Z2
-Rota 17x9*42 DPT with 255/40/17 Federal 595 RSR
chanomatik (05-02-2014), finch1750 (05-02-2014), fstlane (04-26-2014)
Old 05-02-2014, 02:52 PM   #811
Scooby South
Conedancer
Welcome Aboard... #FT-86 SpeedFactory... Look forward to 2014
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
Old 05-04-2014, 11:30 PM   #812
Scooby South
Conedancer
Wheew...what a great day. Car ended up 2nd and 7th overall .. Fun Fun course
[ame]http://youtu.be/cG4SuAfYqs8[/ame]
Bill
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
