Old 04-04-2014, 09:03 PM   #449
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by DarkSunrise View Post
I've been wanting to push a Boss 302 on the track, just haven't had the opportunity. How would you say the handling compared with the FR-S or S2000?
I would say it is hard to give a fair comparison as the FRS felt ligther in the corner with a much sharper turn in but the grip levels on the HPs hinder it when comparing to the 302 cause I felt way more confident that the tires would hold the speed better. I was just shocked at how stable the car was when doing quick transitions. I feel the FRS rear end wants to come around a bit too easily without TC on however I'm a novice so my driving isn't pretty meh
I only had a couple hours behind the wheel of a s2k and never at the track so kind of hard to say
Originally Posted by f0rge View Post
A thousand times yes. People on the internet get WAY too wrapped up in specs and with "numbers cars". Anyone who's actually driven both can almost instantly tell why one is worth way more than the other.
The reason is refinement, the BMW has it, the Ford has much less of it.
Deff agree with this. Its kind of shocking how in some circles the muscle cars still don't get that much respect tho.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-04-2014, 09:47 PM   #450
fatoni
its almost exactly how people try to compare a scion to a cayman though. which happens constantly here without much counterpoint
Old 04-05-2014, 09:52 AM   #451
DarkSunrise
DarkSunrise's Avatar
Got it, thanks. I've driven a Mustang GT track pack on the road and wasn't too impressed with the subjective handling or feel. I hear people say the Boss 302 (or Mustang GT w/handling mods) feels much lighter on its feet, so I was curious to hear what you thought as a fellow FR-S owner who's driven both on the track.
From what you're saying, I guess a Boss 302 won't ever feel as light as an FR-S or turn in as sharply, but is less prone to oversteer. That was sort of what I was expecting to hear. From what I can tell, Mustangs are actually pretty reliable track cars. Just wish Ford could keep the powertrain, but cut the overall weight by about 500 lbs. I think that would be enough for me to get one.
2022 BRZ Build
2013 FR-S Build
Old 04-07-2014, 10:39 AM   #452
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Most people here compare it to the Cayman - but not favourably.
I think most 86 owners will readily admit that, given the choice (and without the practicality issues), the Cayman would be their pick.
The point of the comparison is that Toyota/Subaru have taken a relatively inexpensive car, and imbued it with driving feel which is in the spirit (if not the same league) as the more expensive, midengined Cayman.
At least I don't think very many people are saying that the FRS > Cayman....
daiheadjai is offline   Reply With Quote
Old 04-07-2014, 12:26 PM   #453
DarkSunrise
Originally Posted by LSxJunkie View Post
Having both Track Pack and Laguna Seca suspension under my car, I can tell you that the Track Pack shocks are way too soft, especially rear rebound. The car would nosedive like crazy when you got hard on the brakes. Not fun in most situations However, the car would come together when pushed harder through some corners. You could develop a rhythm with the body movement. The LS suspension is a whole different world. It's stiff and tight and the turn in is good and the car just seems more controlled but at the same time, more animated. I switch between having the shocks cranked all the way up (which is awful over these NY roads right now. Thanks winter) and having them set to 2 all around for a great balance of control and comfort. However, even turned down the car is infinitely more controlled than with the stock suspension.
Great, that is very helpful information. Is there a specific car you would say the Mustang w/LS suspension feels similar to on the track?
Also how much did the LS suspension set you back, and is there a comparable aftermarket option (like Roush or Ford performance?) Thanks for the information, much appreciated.
2022 BRZ Build
2013 FR-S Build
Old 04-07-2014, 02:13 PM   #454
DarkSunrise
I can't compare it to anything I've driven in a while. However, I got the shocks and springs as takeoffs for 500 bucks. Tbh, the ford racing shocks and koni yellows are better shocks. Most people pair then with ford racing springs or steedas. When these shocks are done I'm going to do yellows with boss springs. The boss springs are linear, the frpp springs are not. Also, I don't want to go any lower. The rear sway bar was like 80 bucks. It improves the turn in, but eventually I'm going to swap them both for stiffer bars.
Thanks. I might replace my 350z with a Mustang GT, hence the questions.
2022 BRZ Build
2013 FR-S Build
Old 04-07-2014, 02:53 PM   #455
fatoni
well i think a lot is lost in translation. someone on this forum saying that the mustang forum thinks their car is better than the m3 is probably just as likely a conclusion as someone telling them about how we rave about our car because of that comparison. i just guess its worth mentioning that nobody here is actually saying the mustang is better than the m3 so here we are criticizing people for opinions we are projecting upon them.
Old 04-07-2014, 03:28 PM   #456
Diode Dynamics
Diode Dynamics's Avatar
I'm an active vendor on 7 Mustang forums, and I can tell you from experience that some members on those forums are 100% convinced the Mustang is a better car overall. Like you said, nobody else on here believes that to be the case from my understanding
I think 86 owners are happy with their cars because of the handling and don't need to make comparisons to justify their purchase.
But yes, it is a shame that a few owners can create a stereotype.
Our FR-S is a blast to drive IMO, I'd take that on a road course over my 2007 Mustang GT because of the driving dynamics.
My mustang feels like a boat after driving my S14 or our FR-S
Nick C.
John C.
Diode Dynamics
Old 04-07-2014, 03:38 PM   #457
fatoni
Nick C.
there is a thread here where someone believed the frs is a better car than the 458 because the trd race car went around tsukuba a tenth of a second faster
Old 04-07-2014, 03:55 PM   #458
Diode Dynamics
Haha well, everyone's an expert on the internet
Nick C.
John C.
Diode Dynamics
Old 05-23-2014, 12:12 PM   #459
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Prices
Well, sticker prices are out and all over the web - mustang6g.com is one good source I've seen.
Basically, MSRP for the 2.3 Ecoboost is just under $30k with the performance pack and Recaro's. ~$37k for the GT with similar options.
Unfortunately, still no other specs (like weight).
Personally, while the <$30k number is good, the car is just too big to be very temping to me. I do hope it provides a price 'cap' of sorts for the twins as later, hopefully improved, models get rolled out.
jdrxb9 is offline   Reply With Quote
Old 05-23-2014, 12:21 PM   #460
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
While heavier than an FRS, it's weight is still inline with most other sports cars out there. I for one wouldn't really complain about a bigger trunk/back seat. She'll be faster than an FRS for sure.
IRS and a light engine up front are good things, we'll just have to see how she dances.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 05-23-2014, 12:38 PM   #461
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
3,500 lbs isn't really a sports car is it? With the current test ride reviews journalists are basically saying the ecoboost feels the same as the outgoing V6, maybe a bit better suspension and road holding, for a car that runs close to $1k more than the '15 FRS and with the bottom of the barrel V6 only about $500 cheaper I think the Toyobaru will not take as big a hit on sales as detractors estimated.
Here's the leaked prices:
http://www.mustang6g.com/forums/show...ing-1829.html?
Honestly not bad considering how much effort seems to have been put forth but it still seems to be in a different league than the Toyobaru, not as different as what was originally promised.
ineedyourdiddly
Old 05-23-2014, 12:51 PM   #462
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Originally Posted by PRG3000 View Post
No ones talking about the Ecoboost engine? 300 projected tq and hp?
Even if it comes close to the projected power numbers, thanks to the turbo just a simple tune and exhaust setup would net you some SERIOUS power. And from a four banger with good mpg. I'm not a mustang fan so I wouldn't care about the engine sound.
I was set on an frs this year but I'm seriously considering the Stang. I'm just waiting for the MSRP announcement. All that new shit isn't going to come cheap
A 4 cylinder in a mustang is weird. Just typing that out felt weird.
MokSpeed is offline   Reply With Quote
2015, couldhavehadav8, ecoboost, ford, mustang
Mustang at it again! (Shelby GT350) FX86 Off-Topic Lounge [WARNING: NO POLITICS] 18 10-26-2016 08:46 PM
2013 Mustang GT or wait for 2015 Mustang GT or new model 370Z (390Z)...??? JayNutter Other Vehicles & General Automotive Discussions 48 01-13-2013 10:03 PM
1966 Ford Mustang T-5R Wes B. Other Vehicles & General Automotive Discussions 33 12-11-2012 09:38 PM
2011 Shelby Mustang Enhancement Detail OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 05-24-2012 06:24 PM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 10:15 AM
