Old 04-05-2014, 10:29 PM   #1
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Vacuum Leak??
I am having what I think is a vacuum leak. Trouble is, I can't find it.
I can hear a very loud sucking (vacuum) coming from directly next to the intake/throttle. The car runs waaaaay lean at idle (19s+). I step on the gas and it gets better.
I initially assumed I blew a vacuum line off, as I have done this before and it was easy to see. This time I don't see anything. I am at a complete loss as to what it could be.
I am hoping there is some hidden line that came undone..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 04-05-2014, 10:38 PM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
check the hose that is under intake manifold, behind AC compressor
Old 04-05-2014, 10:38 PM   #3
mike the snake
There's that one vacum line that's under the intake manifold that awlays pops off on FI cars.
It popped off on mine, it's common on FI cars and you just need to put a clamp on it and you're good to go.
Do a search too, there's a bit of info here about this.
Old 04-05-2014, 10:42 PM   #4
woode
Boosted Member
woode's Avatar
I'm searching and not finding anything.. maybe I am retarded.
Anyone have any pictures? I swear I checked every one.. I would love you forever if you have a picture.
The Following User Says Thank You to woode For This Useful Post:
Frs300 (04-05-2014)
Old 04-05-2014, 10:48 PM   #5
Frs300
Frs300's Avatar
Drives: Pile of junk
try this
http://www.ft86club.com/forums/showt...light=vac+leak
Frs300 is offline   Reply With Quote
The Following 2 Users Say Thank You to Frs300 For This Useful Post:
Sportsguy83 (04-05-2014), woode (04-05-2014)
Old 04-05-2014, 10:49 PM   #6
woode
Boosted Member
woode's Avatar
Originally Posted by Frs300 View Post
I love you (if this is the one)
IDK how I couldn't find this in my search..
That is the area that it sounds like it's coming from.
Old 04-05-2014, 10:54 PM   #7
Frs300
Frs300's Avatar
took me like 10 min to find it lol.
The Following User Says Thank You to Frs300 For This Useful Post:
Old 04-05-2014, 11:04 PM   #8
ahausheer
Re-member
Drives: Toyota camry
Get a cigar, take a massive puff, pull off a vacuum line and blow the smoke in it. See if/where it comes out. Might need to plug the exhaust with a rag. If you dont see anything you could still have a leak and just not be seeing the smoke, but worst case, you now have an excuse to smoke a cigar.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 04-05-2014, 11:10 PM   #9
woode
Boosted Member
woode's Avatar
Are these the lines you are referring to? Because they appear to be connected.
Or are there more lines that can't be seen at all unless the compressor is taken off?
Old 04-05-2014, 11:16 PM   #10
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I'll go take a photo of mine. They tend to blow off above 14psi without clamps and ties, and are a B!t@# to get to.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
Old 04-05-2014, 11:20 PM   #11
woode
Boosted Member
woode's Avatar
Well right before this happened I was boosting about 18psi.
Old 04-05-2014, 11:26 PM   #12
Frs300
Frs300's Avatar
@Sportsguy83 might have more pics
Old 04-05-2014, 11:29 PM   #13
Hawaiian
That guy
Hawaiian's Avatar
Ok, I burnt my hand a few times because I just got home after a 45 minute drive home, and wasn't able to get a picture... BUT I did remember that Gmookher filmed a video of this exact issue. I'll try to search for that while the engine cools.
The line isn't in any of those photos. It is a braid covered line that runs under the manifold. If you stand at the front of your car and face the TB it's on the right side, under the manifold running towards the driver side before ducking under. If you follow it with your hand the braid ends and you can find the line behind it.
Ultramarine mt FR-S
P&L stage 1 turbo
The Following User Says Thank You to Hawaiian For This Useful Post:
woode (04-05-2014)
Old 04-05-2014, 11:31 PM   #14
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You will not be able to see them. If you don't remove the AC compressor, you will need to feel your way in. Move the compressor out of the way and will see them. (Still hard to see, but you will).
The EVAP solenoid is more towards the back of the intake manifold. The line connects to the intake manifold just behind the throttle on the drivers side.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
woode (04-05-2014)
Affordable vacuum? swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 04-02-2014 06:21 PM
vacuum at idle/decel jamesm Engine, Exhaust, Transmission 7 09-07-2013 07:04 PM
Innovate Install Help - Vacuum Routing swift996 Forced Induction 36 07-15-2013 07:47 PM
Vacuum help! Scalzo Forced Induction 6 06-26-2013 02:12 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
