Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-28-2013, 09:05 AM | #16 |
#RememberTheBuster
Drives: Firestorm FRS MT
06-29-2013, 09:38 AM | #18 |
Drives: on cruise control
07-01-2013, 09:14 AM | #19 |
I have not installed LCA's yet. Where it sits right now it doesn't appear to have affected the camber in the rear much at all. As far as ride quality I think the FR-S is pretty stiff on stock suspension and now with the coils on a lower stiffness setting it really doesn't feel to far from stock.
The Following User Says Thank You to MountainManFR-S For This Useful Post: | loogs (07-01-2013) |
07-02-2013, 02:19 AM | #21 |
Drives: FRS(sold), AP2, R35, FJC, ED9
how are you guys getting in and out of driveways that low? i'm down about 1.3" all around and with the reduced shock travel on the coilovers i end up 3 wheelin it on majority of the driveways i encounter.
07-02-2013, 03:45 AM | #22 |
Drives: 2013 Scion FR-S Argento
I installed my Invidia N1 and my BC's at the same time. I first had the car set really low, and I was scraping my NEW exhaust on everything. I ended up raising it since I didn't want to trash it.
I wish i could get the exhaust piping tucked a little further up inside. As for stiffness. I turned the knobs all the way towards the "soft" arrow. Then I dialed them up 8 clicks towards "stiff". |
03-18-2014, 01:35 PM | #23 |
Lowered Lifestyle
Drives: Scion Fr-S
Hey guys I have my BC Extreme Lows on now and I am rubbing in the front. I don't wanna add anymore camber since im trying to get as much flush I can achieve! Is adding more camber the only way to prevent the rubbing? I know where I rub at and that its rubbing the fender lining but already put a hole thru it, ahaha. Thinking of raising it just a couple MM and then getting as little camber I can in the fronts so I can tuck and be as close to the fender as possible!
04-04-2014, 05:14 PM | #24 |
Lovin' the Low Life
Drives: 2014 Scion FR-S
Are you on stock wheels? If not, what are your wheel and tire specs?
04-04-2014, 05:53 PM | #25 |
Drives: Smells like tires when I drive
If you want to be that low fender liners have to come out.
04-05-2014, 07:22 PM | #26 |
Lowered Lifestyle
Drives: Scion Fr-S
I have 18x8.75 all round. Rears are good but the fronts due rub in the fender liners which I'm deciding if I wanna take em out or just raise her up a couple cm's.
Sent from my HTC One |
04-06-2014, 06:56 PM | #27 |
Similar Threads | ||||
Coilover to Raise Ride Height | Furtive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 07-28-2014 12:57 PM |
Best Coilover Closest to Stock Ride Comfort? | taimysho0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 50 | 09-04-2013 01:19 PM |
What do you guys think of this? | Bleevin | CANADA | 5 | 02-19-2013 12:49 PM |
Guys, I'm Sorry. | dale.m | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-29-2012 10:37 AM |
What do you guys think?? | Arcangel | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-30-2009 11:06 AM |
