Old 04-04-2014, 02:31 PM   #29
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by dwx View Post
I think every bit of spool and responsiveness is better, but there are probably diminishing returns from a money perspective. I saw people go twin-scroll on other Subaru engines and the differences weren't really that great versus the cost and complexity. You could simply use a slightly smaller turbo or more advanced single-scroll turbo like a GTX or EFR.
Also on a street driven car with limited traction I'm not sure how much you want a huge torque hit, then when you add stickier tires to the equation, then other stuff starts breaking.
Not many people here agree with that...
Apparently having max torque at 2100 rpm is a thing.
I guess people line up to race each other and slip the clutch out at 1,000 rpm, when the car starts moving they hit the gas and see who has more power from 1,000+ rpm to redline. Cause that's how people race. #sarcasm
Ironsquid is offline   Reply With Quote
Old 04-04-2014, 02:32 PM   #30
wparsons
wparsons's Avatar
I would rather have more instant throttle response (shorter charge pipes, etc) than a ton of torque way down low.
flickr
Old 04-04-2014, 02:36 PM   #31
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Short route piping, VGT, liquid-air IC for less internal volume.
Someone make this, and ITBs.
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
cdrazic93 (04-04-2014), wparsons (04-04-2014)
Old 04-04-2014, 03:46 PM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Sounds like the new S55B30 in the M3/M4, but it is twin scroll as well.
Old 04-04-2014, 03:48 PM   #33
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I'm still not convinced the complexity/price is worth the gain for twin scroll.
Old 04-05-2014, 06:00 AM   #34
Boxer486
Drives: small
Not that I'm a BMW fan or anything, but what do you think BMW's reasoning was if you think that's the case. Too much money in their coffers?
Apparently the only thing people like the Fiat bomb in the back of the 4C is the massive torque available from 2100 on, at least till it falls off a cliff.
Boxer486 is offline   Reply With Quote
Old 04-05-2014, 12:18 PM   #35
xwd
In an everyday car where people are using automatics and typically driving in the 2K-5K range having the faster spool is great and they demand the power down low. People hate turbo lag. BMW is also an OEM designing their own mass-produced manifolds and turbine housings. It's not like a single scroll setup is going to be a ton cheaper than a twin-scroll for them. In BMWs case I think they went to a twin scroll versus a twin-turbo setup, so it was cheaper for them to go with the twin-scroll single turbo.
In our case for the most part people are tacking a turbo onto a 12.5:1 NA motor which is way different.
The Following User Says Thank You to xwd For This Useful Post:
andrew20195 (04-16-2014)
Old 04-06-2014, 09:15 AM   #36
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Cost and familiarity. Aftermarket vendors and shops need to keep cost down to maintain their profit margin on limited quantities. Sticking with what they know keeps cost down too. Realistically, the only major difference between single and twin scroll is the manifold. 4-2 instead of 4-2-1/4-1 and either dual or shared wastegate. After that, I'm sure tuning is more delicate building boost faster at lower rpm.
Mobius357 is offline   Reply With Quote
The Following User Says Thank You to Mobius357 For This Useful Post:
Crawford Performance (04-06-2014)
Old 04-06-2014, 11:02 AM   #37
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I had an Evo X, didnt notice twin scroll. Didn't make any power either. I woulda rather had a larger turbo and less MSRP.
Just because something is new and innovative doesn't make it end all be all, or that much better than everything else. You get more from retarding exhaust cam for spool than you get from twin setup, that's my point.
Old 04-06-2014, 07:39 PM   #38
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by Rosticles View Post
Is there not an additional benefit of twin scroll when using cams with more overlap? With the segregation of the exhaust manifold wouldn't you better protect yourself from the negative effects. Longer duration = Higher RPM's, yes?
There are benefits to having the pulses divided and preventing reversion. However, twin scroll housings tend to be rather restrictive compared to their single-scroll counterparts. I flowbenched a .78 divided T3 housing vs a .63 open housing. Although I don't have the exact figures, the .63 flowed significantly more. The 1.06ar divided housing was STILL slightly less than the open .63 housing. Both twin scroll housings caused a loss of power on the higher rpm ranges over 7500rpm. The .63 open housing didn't have the transient response, but still made more peak power even while using the divided manifold with the divided flange.
Although I do believe that the supposed 240wtq at 2100rpm is a great attribute, I have to think that there is more at play here than simply using a twin-scroll housing/manifold setup. EVOs use a twinscroll factory, as well as countless other cars and none of them have those kind of results. NONE. Even with aftermarket tuning and modification.
Coheed is offline   Reply With Quote
The Following 2 Users Say Thank You to Coheed For This Useful Post:
Lee@JDLAutoDesign (04-07-2014), Rosticles (04-07-2014)
Old 04-06-2014, 09:39 PM   #39
Boxer486
Drives: small
Cool. I just have no idea how what you said relates to anything in my post.
Old 04-07-2014, 09:05 AM   #40
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
That's easy, you're insinuating that BMW didn't include twin scroll because they wanted their customers to pay more.
My point is that, if you have the money and don't give flying fuck, 1-5% better spool for 2k-4k more cost in research and development, go ahead. I can think of much better more efficient ways to get better spool.
And if you think having power at 2100 is really worth something then you must be re-living the 80's when V8's had a 5k redline.
Old 04-07-2014, 09:26 AM   #41
Lee@JDLAutoDesign
Lee@JDLAutoDesign's Avatar
Drives: Corrado
This sounds interesting. Do you have any pictures/details of how you did this? I'd be curious to spot some of your test points on a turbine map...
Lee@JDLAutoDesign is offline   Reply With Quote
Old 04-07-2014, 11:52 AM   #42
xwd
Have you seen the dyno plot? It's running a lot of boost on E85 on a relatively tiny turbo (VF37) on a 12.5:1 CR engine. Peak HP happens at like 5600 RPM and torque drops at like a 45 degree angle from its peak under 4K. Now it's still making 250ft-lbs near redline and I'm sure it's a ton of fun to drive on the street, but the recipe is really twin-scroll+small turbo+E85.
JDL 5130 Twin Scroll Turbo Kit JDLAutoDesign Forced Induction 390 05-27-2021 12:14 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
Centrifugal or Twin-scroll? What Ever You Choose FR SPORT Has it for Your ZN6 Car! FRSport.com Forced Induction 0 09-27-2013 08:15 PM
Any Twin Scroll Kits? Tiz Forced Induction 18 12-19-2012 07:43 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
