Old 04-04-2014, 10:13 AM   #1219
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Red FRS View Post
@nelsmar @King Tut
I am planning on driving down to Orlando to see @jamesm but first I need to install the kit and I can't drive it without a tune so I guess the best option would be to find a tuner that can send me maps.
I am sure he can send you a file with the proper MAF scaling for the Vortech to get your car running.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
jamesm (04-04-2014), Red FRS (04-04-2014)
Old 04-04-2014, 10:14 AM   #1220
jamesm
Tut is right. I can just send you a base map.
Old 04-04-2014, 10:15 AM   #1221
Red FRS
Red FRS's Avatar
Drives: 2014 Subaru BRZ
Awesome. Messaging you now.
Molded rb v1 BRZ on WCI LP1
instagram.com/seantejani
Red FRS is offline   Reply With Quote
Old 04-04-2014, 11:00 AM   #1222
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Originally Posted by bee_are_zee View Post
So I'm about due for an oil change. What weight is everybody running after going FI ?
I run 5/30 in sunny South Africa, day temps 15-35°C, works well for me.
Fish Eagle is offline   Reply With Quote
Old 04-04-2014, 11:25 AM   #1223
Bl1tzkr1eg
Drives: Toyota 86
Rob, before they started dyno tuning my car, they ran one pull on the street tune we both have. It registered a 282whp.
It very well could be the exhaust. That's the only difference I see in our cars.
Originally Posted by HRTROB View Post
Finally got my car dynoed today. Best pull was 261 hp / 173 tq @ 7,900rpm STD corrected
only about 235whp @ 7500rpm
Need to have the tune tweaked. AFR was leaning out from 4,500-7900rpm. This is already with 700cc injectors and 265lph fuel pump. Not sure if this is because of an exhaust leak somewhere, or if the fuel pump backed out and does not have enough pressure. I'll be installing an AEM wideband o2 then back to the dyno for proper tuning. The car hasn't been tuned on the dyno yet, just at the street.
Vortech 9psi stock pulley
100 RON pump gas
6MT
Borla UEL header
Milltek over pipe
Milltek front pipe
Milltek resonated catback
Deatschwerks 700cc injectors and DW65c 265lph fuel pump
tuned by Speedworks (same tuner as Blitzkrieg's 300whp Vortech 9psi)
Bl1tzkr1eg is offline   Reply With Quote
The Following User Says Thank You to Bl1tzkr1eg For This Useful Post:
Tye300 (04-04-2014)
Old 04-04-2014, 11:41 AM   #1224
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Thanks for the info Dax! It could very well be the exhaust and headers. Ryan and Leo from Speedworks were also at the shop tuning another car. Before my car was dynoed, they told me that your 3 inch exhaust setup really made a difference.
It could also be because of my headers. The Borla UEL doesn't make a lot of power in the higher rpm range as opposed to your VDS header which makes power everywhere
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
Tye300 (04-04-2014)
Old 04-04-2014, 01:47 PM   #1225
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
There have been a lot of questions about belt sizes, so I got our Engineers to supply me with the following information. I hope this helps everyone out.
Brian@Vortech is offline   Reply With Quote
The Following 4 Users Say Thank You to Brian@Vortech For This Useful Post:
AZFA20 (04-04-2014), ft86me (04-04-2014), HRTROB (04-04-2014), Tye300 (04-05-2014)
Old 04-04-2014, 05:26 PM   #1226
dvsidboy
Drives: 2013 Subaru BRZ
The current OEM AC Delete kit will not work with the out of the box Vortech S/C Kit. If you purchase this kit and have the AC Delete you have some more work in front of you.
-- Trim part of AC Delete Bracket to fit S/C Support Bracket
-- Run either smaller S/C Pulley or smaller pulley on AC Delete Kit
--- AC Delete has a 4.5" Puller and sits a bit lower than the OEM 4.25" AC Pulley
-- New Belt when will be required when downsizing AC Delete Pulley or SC Pulley
--- I will get that once I complete steps 1 & 2 with my current install.
dvsidboy is offline   Reply With Quote
Old 04-04-2014, 05:59 PM   #1227
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Damn, I really have to get Speedworks update my tune!
Tye300 is offline   Reply With Quote
Old 04-04-2014, 06:22 PM   #1228
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Talk about perfect timing even though I already knew what size I needed for the 2.87". I just killed a belt last night Took out 3 of my idler pulleys with it. Damn you plastic pulleys!! Somehow made it home with half a belt and mangled pulleys haha good times.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 04-08-2014, 02:15 PM   #1229
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Going to be running the 4TF218-124 kit engine oil fed kit. Where's the best place to tap for the oil return?
It looks like here is the spot for the feed.
Easier to just get an aftermarket oil pan?
FyeaFRS is offline   Reply With Quote
Old 04-08-2014, 05:16 PM   #1230
bfsnail
bfsnail's Avatar
I swear I just looked through this and didnt find anyone reporting any actual mpg changes.
For those of you running the kit (especially interested in the base pully size and tunes) what kind of changes (if any) in your mileage are you getting? I'm especially interested in highway cruising situations as most everyone will be getting less in day to day driving with the added boost/power.
I'm fine with loosing fuel efficiency with the added boost, but I also drive a decent amoutn and it would be tough to take a huge hit with normal driving.
Thanks!
bfsnail is offline   Reply With Quote
Old 04-08-2014, 08:52 PM   #1231
Dezoris
Dezoris's Avatar
With the new belt and smooth pulley did the belt routing change?
Old 04-09-2014, 09:06 AM   #1232
FyeaFRS
Picked up the MAP oil pan with the fitting and larger capacity.
Where are you guys mounting your oil cooler rads and what brands are you using?
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
