Old 04-02-2014, 11:45 PM   #4467
BoostinIX
Gettin SIKKY sideways
BoostinIX's Avatar
Drives: '97 S14.5 / '13 BRZ
Send a message via AIM to BoostinIX Send a message via Yahoo to BoostinIX
[ame="http://www.youtube.com/watch?v=1m8iP7BmqCI"]Dai Yoshihara Subaru BRZ Formula DRIFT - Test Day 01 - YouTube[/ame]
Instagram: BoostinIX
BoostinIX is offline   Reply With Quote
The Following User Says Thank You to BoostinIX For This Useful Post:
kanundrum (04-03-2014)
Old 04-03-2014, 12:12 PM   #4468
kanundrum
Drives: 2013 Whiteout FR-S
[ame="https://www.youtube.com/watch?v=4NOFF-SEzDk"]Powerslides with the D1 Drifters - Top Gear - Series 6 - BBC - YouTube[/ame]
Old 04-03-2014, 07:11 PM   #4469
BoostinIX
BoostinIX's Avatar
Old 04-03-2014, 08:23 PM   #4470
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Wow. Thats missing the rear bumper
I am very insecure. I have no friends. I want people to love me
Old 04-04-2014, 09:42 AM   #4471
BoostinIX
BoostinIX's Avatar
Hehe it'll be fixed by today, qualifying starts livestreaming at 3.
Old 04-04-2014, 10:45 AM   #4472
FRSure
Drives: Toyota
off topic:
Does T-Tap Connector splice the wire (cut wire in half), or does it cut only far enough to get through the wire insulation to reach the wires?
FRSure is offline   Reply With Quote
Old 04-04-2014, 11:00 AM   #4473
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
Originally Posted by FRSure View Post
off topic:
It cuts it enough to just get through the insulation to reach the wiring inside.
What are you looking to tap into?
This is a good way to "access" a wiring path without having to cut/strip/solder factory wiring.
AdamBomb518 is offline   Reply With Quote
Old 04-04-2014, 11:30 AM   #4474
sshole
off topic:
Be careful with vampire taps. If you don't know what you're doing, you could easily cut through the wire you're trying to tap. Make sure you know what size wire you are tapping into and buy the correct T-tap size accordingly.
sshole is offline   Reply With Quote
Old 04-04-2014, 11:30 AM   #4475
Events@Ptuning
Events@Ptuning's Avatar
Drives: 2013 Scion FRS
Hope to See a lot of Familiar Faces tomorrow. We have Beer, Food, Great Weather (Compared to the past few months) Raffles Supporting a good Cause and most importantly all of you folks!
Events@Ptuning is offline   Reply With Quote
Old 04-04-2014, 11:46 AM   #4476
FRSure
Drives: Toyota
Actually I have the diode dynamic foglight installed. I was just wondering if the TTap connector cut the wires in half or just cut enough to cut through the insulation. I didn't want the t tap connector to fail and end up with a broken wire that is split in half.
Just to conclude, the t tap connector only cut enough to go through the insulation and not cut the wire in half right?
Old 04-04-2014, 11:49 AM   #4477
AdamBomb518
Stealth ***e
Correct. When I did remote starters back in the day, that's all we used. The shop still uses them for their installs to this day. They're reliable (as long as crimped down properly). My parents have had their starter in their truck for nearly 10 years now this way and not a single issue.
The Following User Says Thank You to AdamBomb518 For This Useful Post:
FRSure (04-04-2014)
Old 04-04-2014, 11:52 AM   #4478
FRSure
Drives: Toyota
Cool. I was just worried if weather and vibration will loosen them.
Currently, I have them t tapped to my headlights.
I was thinking putting electrical tape over the TTap connectors.
Old 04-04-2014, 11:57 AM   #4479
AdamBomb518
Stealth ***e
Electrical tape is messy when taking off, but definitely a good idea for anything that could potentially see any "weather". Heat shrink would be ideal but it's difficult to do on those kinds of "T" connections.
Old 04-04-2014, 12:32 PM   #4480
Ross
Drives: 85 corolla gts
I have fixed multiple issues on cars do to those splices, from poor connection and week signal to corrosion build up and damaged harnesses / broken wires. I always recommend not to use them. but good luck with your project.
Ross is offline   Reply With Quote
Mid-Atlantic spotting thread OMNOM Mid-Atlantic 7400 08-27-2021 08:30 PM
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
Its The Mid Week Chat! vividracing Off-Topic Lounge [WARNING: NO POLITICS] 17 07-09-2012 01:31 AM
#ft86club chat room ayau Off-Topic Lounge [WARNING: NO POLITICS] 1 03-02-2012 10:53 PM
FT86Club IIRC Chat Zaku Off-Topic Lounge [WARNING: NO POLITICS] 2 12-12-2011 09:36 PM
