Old 04-02-2014, 09:25 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Datalogging 2nd gear pull?
Hi all,
I know it's been said that best data is typically a 3rd gear pull but for those that want to respect the speed limit as best as they can, how off would a 2nd gear pull be?
1Cor10:23 is offline   Reply With Quote
Old 04-02-2014, 09:40 PM   #2
Lytheum
Drives: 2013 BRZ Premium 6MT
3rd or 4th gear gives you a lot more data to look at because they take longer to run out. You'll get the same data, but a smaller sample size.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
1Cor10:23 (04-02-2014)
Old 04-03-2014, 02:21 PM   #3
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Note, you can't just do the run at lower throttle to get more data because it needs to be a WOT pull.
Luckrider is offline   Reply With Quote
Old 04-03-2014, 02:32 PM   #4
1Cor10:23
1Cor10:23's Avatar
Yes of course, haha. That much, I get.
Old 04-03-2014, 02:41 PM   #5
jamesm
you'll want to do runs in 3rd gear, so that the ramp rate allows sufficient time to gather data, especially with lower sampling rates (anything less than 16-18hz). i have to do my pulls in 4th for high boost now because it just spins all the way through 3rd, so i know what you mean about high speed being a bad thing. it gets hairy sometimes .
also i believe you're na, but for anyone with FI you'll want to remember to turn traction control off before the pulls. it will close the throttle and ruin your run.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
1Cor10:23 (04-03-2014), Sportsguy83 (04-03-2014)
Old 04-03-2014, 02:45 PM   #6
Luckrider
Luckrider's Avatar
You need more grip too though. My 245/40R17s would probably do you nicely.
Old 04-03-2014, 02:59 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
LOL... 265's Michelin PSS are not enough already...
Any other tire with noticeably more grip= unsafe for street/rain conditions.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (04-03-2014)
Old 04-03-2014, 03:00 PM   #8
jamesm
yeah it's pretty hopeless. we have the same problems on the cars with stickier rubber, just to a lesser degree. The only hope for traction (without killing power) with any reasonable street tire at high boost is custom map based traction control. it also has the happy side effect of cool noises.
The Following User Says Thank You to jamesm For This Useful Post:
Old 04-03-2014, 03:02 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
I've found that I'm able to get sampling rates of up to 16hz by cutting back on the parameters that are logged when using my new laptop from work (HP ProBook). What kind of rates have you been seeing?
Old 04-03-2014, 03:09 PM   #10
jamesm
anywhere from 16-32hz with the new windows laptop (cheap acer from best buy). depends upon not only the number of channels, but which channels you are sampling. some channels cost you nothing at all, where others cost 2-3hz by themselves. i think it's the obd channels that slow it down, but i'm not really sure. i know logging the ecutek-specific stuff is fast (custom map results, sd stuff and what not).
xjohnx (04-03-2014)
Old 04-04-2014, 12:02 AM   #11
steve99
Drives: FT86
found the same with Tactrix logging
Reading direct RAM address = fast 20Hz or so
Reading OBD parameters = slow
Old 04-04-2014, 01:42 AM   #12
1Cor10:23
1Cor10:23's Avatar
So I did the 3rd gear pull and wow, my IAM was screwed up , and this was on vpower 91 (1.5 gallon remaining - immediately topped up with 94 E10) - started at .57 and slowly went up to .86 at end of drive.
I've documented my issues here on this thread if any of you would like to chime in, would greatly appreciate it!
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 06:12 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
F.I Pull. How many miles do you have on boost! NickFRS Forced Induction 24 02-06-2014 06:24 AM
OpenFlash Tablet Datalogging Suggestions Shiv@Openflash Forced Induction 12 02-05-2014 02:31 AM
EcuTek Datalogging Question xxscaxx Engine, Exhaust, Transmission 8 05-24-2013 12:31 AM
