Old 04-03-2014, 10:30 AM   #15
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
Do all of you drive like grandmothers? Seriously I'm looking at my dash right now I'm idling at 900 rpms so you touch the gas and you immediatley shift up, how?
ProjectGT86 is offline   Reply With Quote
The Following User Says Thank You to ProjectGT86 For This Useful Post:
DoomsdayJesus (04-03-2014)
Old 04-03-2014, 10:37 AM   #16
PSORngr
Drives: FR-S 10 Series
Originally Posted by 2nd Gen Scion View Post
This. 1.5-2k to get into first gear. I don't know what you others are doing...
Thirded. I can keep it down near 1k which is just above idle if I'm on level ground and don't care whatsoever how quickly I start (so basically only if I'm pulling out of my driveway or a parking lot if I have just turned the car off since it idles at 1.5k at start up). I'll occasionally start without touching the gas, but then I really have to be dreading wherever I'm headed to....
PSORngr is offline   Reply With Quote
The Following 2 Users Say Thank You to PSORngr For This Useful Post:
2isballer (04-03-2014), Prog (04-03-2014)
Old 04-03-2014, 10:39 AM   #17
PSORngr
Originally Posted by ProjectGT86 View Post
how are you guys revving so low, idle is about half those RPMs the car likes to rev, dont you bring it to 5k ever?
side note: during normal driving and traffic i do rev at about about 2500-3000 rpms, i always considered that normal
This is just to begin moving from a stop. 2500-3000 rpms while moving is normal. 2500-3000 rpms while stopped to start moving I would say is not normal. I'd think that would wear out the clutch pretty quick. I try to keep mine below 2000 when starting to roll.
The Following User Says Thank You to PSORngr For This Useful Post:
Old 04-03-2014, 10:58 AM   #18
Smoke Destructer
Drives: 2013 Whiteout FRS
Hang on, what exactly is OP asking? Are you wondering how much you should rev to get started from a stop, or at around what revs you should be shifting into second gear after getting moving?
Smoke Destructer is offline   Reply With Quote
The Following User Says Thank You to Smoke Destructer For This Useful Post:
Purdue FR-S (07-28-2015)
Old 04-03-2014, 11:00 AM   #19
BRZJunkie
Drives: BRZ Sportech
If I'm stuck in traffic ya 1.0-1.5k for stop and go but really 2-2.5k is more the way to go since there's no torque to speak about from dead stop. Like it's mentioned in another thread I just can't drive this car like any other car. I'm always on alert to DRIVE the thing and never really take it easy. What I hate is music during start in first gear. Hard to make it perfect when you don't hear the engine.
BRZJunkie is offline   Reply With Quote
The Following User Says Thank You to BRZJunkie For This Useful Post:
awhatzable (05-15-2015)
Old 04-03-2014, 11:05 AM   #20
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I took his question as starting from a stop, which for me, unless I am launching the car, I go pretty gently and keep the revs below 1000 until the clutch is all the way out, then when I shift all depends on how fast I want to be going.
Flat Black VW is offline   Reply With Quote
Old 04-03-2014, 11:23 AM   #21
CoupedUpSubie
Drives: 2013 BRZ Limited
I say ignore the guys saying that taking off at less then 1500 rpm is slow, chances are they are riding the clutch way too much when they try. Also some may be trolling.
A 1500 rpm start in an FR-S/BRZ is plenty to take off and throw the rear end out sideway with TC off. The only cars I would teach someone to bring the rpms up to 1500-2000 are sub 150 hp front wheel drive cars.
A proper take off in a car with a manual transmission is done by feeling when the clutch grabs and rolling on the throttle slightly while rolling off the clutch. This should be done in 2-3 seconds. By learning to take off this way you will be better equipped to take off and spin the rear tires if you want to.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 04-03-2014, 11:55 AM   #22
Pekingduck
Drives: 4 wheels
I bring my car to idle rpm around 650-850 rpms and that full engage. I don't like people thinking I am racing them and also the police. Plus I have a aftermarket exhaust so I am trying to stay away from a fix-it ticket. I have driven like this for all my cars for the pass 15 years. I have never needed to get a new clutch.
Pekingduck is offline   Reply With Quote
Old 04-03-2014, 12:49 PM   #23
Euro7R
First is really to get the car going. Unless you are ripping around, then you would go crazy in first lol.
Euro7R is offline   Reply With Quote
Old 04-03-2014, 01:38 PM   #24
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I like to hear my exhaust. So I rev to 1.5-2k
Chen is offline   Reply With Quote
Old 04-03-2014, 04:38 PM   #25
2nd Gen Scion
Drives: Scion FR-S Manual Raven Monogram
This thread has made me second guess how I drive now....
2nd Gen Scion is offline   Reply With Quote
The Following 2 Users Say Thank You to 2nd Gen Scion For This Useful Post:
kpamir (07-28-2015), SVTSHC (08-03-2015)
Old 07-28-2015, 11:47 AM   #26
OctaneFRS
Drives: 2015 FR-S Raven Manual
I'm going to bring this thread back from the dead.
I had the exact concern of the OP. I tend to to rev to about 1k - 1.5k while releasing the clutch and maintain that until the clutch is released. I do feel like a grandma though. What do you guys do? Just trying to get some more input into this issue. Thanks peeps.
OctaneFRS is offline   Reply With Quote
Old 07-28-2015, 12:03 PM   #27
For normal starts, I suggest you just "drive the car" (sort of like "just fly the plane").
Slowly let the clutch out AS you push on the gas pedal. If the engine "dies" ..... push on the gas a bit more next time. If you "peel out" ...... push on the gas less next time. If you smell "burning clutch" ..... let the clutch out quicker next time.........
kch (07-28-2015), strat61caster (07-28-2015)
Old 07-28-2015, 01:21 PM   #28
Hotrodheart
Hotrodheart's Avatar
Mine's an automatic, so I guess I don't belong in this thread.
Hotrodheart is offline   Reply With Quote
The Following 5 Users Say Thank You to Hotrodheart For This Useful Post:
drewbot (08-01-2015), soulreapersteve (07-29-2015), sprintertrueno86 (07-28-2015), SVTSHC (08-03-2015), Tcoat (07-28-2015)
Starting in 2nd Gear? Manic Scion FR-S / Toyota 86 GT86 General Forum 61 11-03-2013 02:55 PM
starting in second gear cantaloupe BRZ First-Gen (2012+) — General Topics 38 03-11-2013 06:18 PM
Another way of starting from 1st gear..help tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 32 09-24-2012 12:14 AM
Where are your RPMS Dragon86 CANADA 13 07-26-2012 10:43 AM
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 09:51 AM
