Old 03-25-2014, 10:00 AM   #29
sirisvirus
Drives:
Originally Posted by Blackrsx View Post
They look like the correct ones.
Now where can I find the bulbs for the hvac in blue?
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 03-29-2014, 01:26 AM   #30
RacerX
Drives: Subaru BRZ
You guys do know that the voltage drop for red LEDs is usually around 1.7V and White LEDs are around 3.3V! That could be why the BRZ and FRS LED clusters have different numbers of LEDs.
Depending on how their wired, doing this might cause damage. I guess nobody has had any issues, but I would definitely have probed the voltage rail and included resistors for proper current limiting. You don't want to overload any LEDs or voltage regulators.
BTW, my speedo is off by +1mph when compared to the digital. Never messed with my cluster so thats from the factory.
RacerX is offline   Reply With Quote
Old 03-29-2014, 02:16 AM   #31
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
I can speak with some authority on this subject. Swapping blue LEDs for red is not a problem.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-29-2014, 02:19 AM   #32
RacerX
Drives: Subaru BRZ
That is good to know. Must be a constant current source then.
Old 03-29-2014, 11:21 AM   #33
sshole
I didn't pay much attention during my circuits course for my mechanical engineering degree.
sshole is offline   Reply With Quote
Old 03-30-2014, 01:53 AM   #34
RacerX
Drives: Subaru BRZ
LOL. My EE professors like to make fun of MEs.
The Following 2 Users Say Thank You to RacerX For This Useful Post:
Acree (03-30-2014), sshole (03-30-2014)
Old 03-30-2014, 02:27 PM   #35
Acree
Acree's Avatar
I would recommend staying far away from eBay when sourcing electronic components.
Try these: Link
The Following User Says Thank You to Acree For This Useful Post:
sshole (04-03-2014)
Old 03-30-2014, 02:32 PM   #36
Acree
Acree's Avatar
And nope, it's just a simple resistor LED series string. But the LEDs draw enough current to put out plenty of light. There's no reason to change the resistor in this particular application when going from red to blue. If you were going from blue to red, I would recommend changing resistors.
Old 04-03-2014, 07:47 AM   #37
Mooseknuckle44
Mooseknuckle44's Avatar
Great DIY!! I like the look of the darker red for the end result.
Off topic question-sort of.
Never soldered anything before. Any recommendations for a good place to learn besides trial and error?
Mooseknuckle44 is offline   Reply With Quote
Old 04-03-2014, 08:08 AM   #38
sshole
Find something that has surface mounted components and start soldering away. Learn how to desolder components - this is especially useful when working in the gauge cluster.
The Following User Says Thank You to sshole For This Useful Post:
Mooseknuckle44 (04-03-2014)
Old 04-03-2014, 08:09 AM   #39
sshole
Try these: Link
My ebay LEDs, while not the best quality, have been working 100% since however many years ago that I ordered them. I think it was 3 or 4 years ago.
But yes. Agreed. Don't buy ebay electronic components. They're terrible and you'll have at least 10% dead on arrival.
Acree (04-03-2014)
Old 04-03-2014, 08:10 AM   #40
Mooseknuckle44
I'm assuming one soldering tool is just as good as the next? Or is there a Walmart version and a Snap On version?
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Old 04-03-2014, 08:32 AM   #41
sshole
Sort of, not really.
Yes.
I've been getting by with crappy throw-away $10 RadioShack soldering irons for the past 10+ years. I've seen no need to upgrade to the $50+ units from the "Snap-On" brands.
Old 04-03-2014, 02:23 PM   #42
Acree
Acree's Avatar
At a minimum, I would recommend a Weller unit such as [ame="http://www.amazon.com/Weller-WES51-Analog-Soldering-Station/dp/B000BRC2XU"]this.[/ame]
But food for thought, a soldering iron really is a tool that will last you 15-20 years if taken care of correctly. My personal recommendation would be an entry level constant temperature station, like [ame="http://www.amazon.com/Weller-WTCPT-Temperature-Controlled-Soldering/dp/B00004W463"]this.[/ame]
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
