Old 04-02-2014, 11:10 PM   #1
2isballer
Drives: 2014 Scion FR-S
how many rpms do you rev at starting off first gear?
I'm kinda new to driving stick shift and it's a blast to drive. I still feel like I struggle a little bit with first gear. I was wondering how many RPM's do you rev at to get the car moving on first gear for NORMAL driving. I usually rev to about 1750 to 2300 rpm. I am not sure if that's too high and cause premature clutch wear. If you have any tips, it would be much appreciated. Thanks for your input.
2isballer is offline   Reply With Quote
Old 04-02-2014, 11:14 PM   #2
illicitstylz
Drives: 2014 FRS - Whiteout - 6spd MT
no more than 1100 and that's a bad start too.
illicitstylz is offline   Reply With Quote
Old 04-02-2014, 11:16 PM   #3
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
I engage at <1K, and fully off clutch pedal before 1.5K
1Cor10:23 is offline   Reply With Quote
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
2isballer (04-03-2014)
Old 04-02-2014, 11:17 PM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
I would say that's pretty normal, especially since you're newer at manual. The key to avoiding excess clutch wear is to not ride the clutch and let it out smoothly and fairly quick.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Old 04-02-2014, 11:22 PM   #5
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Figured this out as I started driving manual more, gently start releasing the clutch until you feel it start to grab. You'll feel the car start moving a little then you give it some gas and accelerate. Practice makes perfect. Hope that makes sence and helps.
DavidBob is offline   Reply With Quote
The Following User Says Thank You to DavidBob For This Useful Post:
Old 04-03-2014, 12:02 AM   #6
Wyattkb
Drives: 2014 Whiteout FRS
I usually rev to 4-5k then drop the clutch.
Wyattkb is offline   Reply With Quote
The Following 19 Users Say Thank You to Wyattkb For This Useful Post:
8R6 (04-03-2014), Alabang 86 (04-03-2014), Aztec (07-28-2015), Chad11491 (07-31-2015), chaoskaze (07-28-2015), CrispyCheddar (07-28-2015), DAEMANO (07-28-2015), DigitalFootprint (07-31-2023), Harjotdhanota (08-29-2017), idario (04-03-2014), Jolt182 (08-02-2015), mandi_brz (07-28-2015), Pat.Thornton (07-29-2015), Porcupint (07-28-2015), ProjectGT86 (04-03-2014), Silver Ignition (04-03-2014), SlammedSilly (08-03-2015), soulreapersteve (07-29-2015), SVTSHC (08-03-2015)
Old 04-03-2014, 12:40 AM   #7
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Usually around 15,000 RPM.
[ame="https://www.youtube.com/watch?v=Yu34Kw490Ws"]F1 Belgium 2013 - Fernando Alonso Onboard Start + First Laps - YouTube[/ame]
But seriously... just give it enough power to not bog it down. As others have said, you'll eventually get the feel for what's right.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following 5 Users Say Thank You to Bristecom For This Useful Post:
2isballer (04-03-2014), Alabang 86 (04-03-2014), JB86'd (04-03-2014), Jrryjms07 (04-03-2014), wtrxprs007 (04-03-2014)
Old 04-03-2014, 04:09 AM   #8
Cycotech
Cycotech's Avatar
Drives: 2014 FR-S Monogram Hot Lava 6MT
Someone likes to launch their car.
I usually rev and engage at 1.2K-1.5K.
<-Click the picture for my journal thread!
Cycotech is offline   Reply With Quote
Old 04-03-2014, 07:41 AM   #9
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
wow you guys are low. I rev to at least 2k and I've been driving manual for 20+ years. Usually in a hurry to get to the next stop light tho
dirtymax is offline   Reply With Quote
The Following 4 Users Say Thank You to dirtymax For This Useful Post:
86-tundra (04-03-2014), Alabang 86 (04-03-2014), Njnickd (07-28-2015), steeloyangster (07-29-2015)
Old 04-03-2014, 09:20 AM   #10
DarkSunrise
DarkSunrise's Avatar
Have you worn your clutches out quickly that way? I'll do that when I'm aggressively driving through the city, but always wondered how my clutch would fare if I did that constantly for 5+ yrs.
2022 BRZ Build
2013 FR-S Build
Old 04-03-2014, 09:27 AM   #11
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
how are you guys revving so low, idle is about half those RPMs the car likes to rev, dont you bring it to 5k ever?
side note: during normal driving and traffic i do rev at about about 2500-3000 rpms, i always considered that normal
ProjectGT86 is offline   Reply With Quote
The Following User Says Thank You to ProjectGT86 For This Useful Post:
Old 04-03-2014, 09:44 AM   #12
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I give it just enough to start moving. Flat ground is either <1k or letting out the clutch, even if I'm in a hurry. Hills require a little higher rpms (~1-1.5k) and a bit more finesse with the clutch. Around town, sometimes I shift between gears without the clutch
Propaganda is offline   Reply With Quote
The Following User Says Thank You to Propaganda For This Useful Post:
Flat Black VW (04-03-2014)
Old 04-03-2014, 10:48 AM   #13
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I rev to like 1.5-2k. Our clutches are so damn heavy that if I don't do that, I get in the habit of revving lower and end up stalling. I rarely - if ever - stalled my last car.
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
awhatzable (06-10-2015)
Old 04-03-2014, 11:01 AM   #14
2nd Gen Scion
Drives: Scion FR-S Manual Raven Monogram
This. 1.5-2k to get into first gear. I don't know what you others are doing...
2nd Gen Scion is offline   Reply With Quote
The Following 2 Users Say Thank You to 2nd Gen Scion For This Useful Post:
awhatzable (06-10-2015), Prog (04-03-2014)
Starting in 2nd Gear? Manic Scion FR-S / Toyota 86 GT86 General Forum 61 11-03-2013 03:55 PM
starting in second gear cantaloupe BRZ First-Gen (2012+) — General Topics 38 03-11-2013 07:18 PM
Another way of starting from 1st gear..help tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 32 09-24-2012 01:14 AM
Where are your RPMS Dragon86 CANADA 13 07-26-2012 11:43 AM
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 10:51 AM
