#254 |
Speed Chaser Thrill Seekr
Drives: 2014 Asphalt Monogram FR-S 6MT
Wow, check this out! A Vortech SC was able to hit 300WHP at the wheels.
http://www.ft86club.com/forums/showthread.php?t=62270 You think we can get these numbers with JRSC?
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint My Build |
#255 |
Drives: 2014 Scion FR-S|Whiteout
^this
Doesn't look like he had any fuel mods either. Just exhaust mods...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#256 |
Drives: WRB JR BRZED
He had to go to 8000 rpm to do it
Sent from my Nexus 5 using Tapatalk |
#257 |
That Vortech car did 266 with Just the kit. I'm curious as to his baseline NA.
#258 |
Drives: Toyota 86
#259 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk
#260 |
#261 |
Drives: Toyota 86
On stock injectors and pump, afr was leaning out past 7000 rpms. So, my rev limitter had to have a 6800 cutt off.
Im now on 700cc DW injectors and 265 l/hr fuel pump. |
#262 |
I maxed the maf with only a catback (both cats in place) on the jrsc kit I tuned. It was hitting 5v almost exactly at redline on the first run.
#263 |
Drives: Asphalt FR-S
So this may be a silly question but when I get this kit will I need an better maf? If so where or what should I be getting?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
#264 | |
Just a dude
Drives: Scion FR-S 2013
Obviously these kits work, there are some work arounds to but... Was this just an oversight by both Rotrex kit makers or ...?
#265 | |
Yeah, I am super confused now... What's the BEST way to get this done the first time? I am looking to pick this kit up in the next few months and now I'm not sure what I'll need.
#266 | |||
That Guy
Drives: 2013 asphalt FRS MT
The reason for the issue is the size of the MAF housing. The MAF sensor, to my knowledge, doesn't actually measure the total mass of the air but the air's velocity. The size of the tube the MAF sensor is in allows the mass of the air to be extrapolated from that velocity.Using a larger housing allows for a larger maximum mass air flow because the flow velocity is lower for the same volume or mass of air per unit time, thanit would be for a smaller housing. The only change that would be required to fix this is a larger MAF housing, and ensure the air doesn't become too turbulent as it enter and exits the new sized housing. One of the work arounds for the time being is to limit air velocity so the sensor doesn't go out of range. (you should never be at the limit of a sensor as A you don't know if the actual system has exceeded the maximum output of the sensor, and B most sensors lose a lot of accuracy in the last 10%ish of their range) The other work around is to use a mass air flow/manifold absolute pressure hybrid tune. Basically the system uses both systems, but relies on one or the other in the air flow ranges where those systems work best, in this setup. Last edited by Calum; 04-03-2014 at 07:55 PM. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
