#57 |
Drives: Galaxy Blue Silica BRZ 2013
#58 |
blowhard
Drives: frs, project forester
Any drone, partial throttle loudness I.e. Up a hill while cruising, etc?
I was running 3" perrin resonated, and their over pipe and 3" catted fp, ended up removing the catback cause of the partial throttle noise |
#59 | |
#60 |
Drives: 2013 BRZ Limited AT
You guys really need to stop putting your cameras on the ground directly behind the car. Get about 20-30 feet back and off to the side a bit about 4-5' off the ground, like a normal person. Putting the camera so close overpowers the mic and no one lies down in that position to hear a car rev.
#61 |
Drives: 2013 Red Subaru BRZ MT
This will be my first post. Ordered my full 3in nameless exhaust(with stock header) back in december and it was worth the wait as far as sound is concerned. Installed last thurs night/ friday morning. Sounds ridiculous(awesome). My setup includes everything you could add on the DP/overpipe combo,midpipe, and 5inch axelback all in 3in. The header bolt closest to the header heat shield is a pain with almost no clearance to properly seat any socket/wrench between the 3inch piping and the nut. Even now i still smell a bit of exhaust. However, that is not what worries me. Whenever accelerating from a stop i hear a banging noise almost as if the engine is knocking coming from the front right of vehicle. I also believe i hear it at other times when already moving and accelerating but i cannot confirm. Whenever installing this was a tight fit especially at DP Mount point and where 5inch muffler touches flex piping on midpipe.
[IMG] [/IMG]EDIT: Loosening everything and adjusting it a bit fixed it. When i retightened the bolts to the stock header, i used an axle nut socket to jack up the flange to provide maximum clearance and then tightened it down. Got rid of my jack hammer noise. Thanks all and thank you nameless performance for making something badass. EDIT #2 After a weekend of autocross and four hours of driving on interstate the exhaust rattles alot again. It seems i have to take the covers off and readjust again. It is rattling at front subframe under accel and at rear subframe all the time. I suspect that the midpipe may be about a half inch too long. It forces the left muffler into the poly exhaust hanger they provided melting it a little, That exhaust tip comes out further than other side. This issue was not there whenever i had just the catback. Last edited by VroomVroom; 04-21-2014 at 12:53 PM. Reason: added picture |
#62 |
#63 | |
[/IMG]
#64 | |
Drives: DGM BRZ Prem AT
#65 | |
You might have to turn your volume up to hear the exhaust. But like I said its really not too loud. Also, just so you know I also have the perrin 3" intake bigmaf. Which is the growl that you hear. Sometimes I almost thing the intake is louder that my exhaust system. I want to say about 5 mins in is when I closed my windows but I can't remember. [ame="http://youtu.be/IHlA4cQj9Uk"]http://youtu.be/IHlA4cQj9Uk[/ame] |
#66 | |
#67 |
Drives: 2013 MT Asphalt FRS
What trick are u guys doing to get the op/fp out?
#68 |
Grip>Slip
#69 |
#70 |
Fanboy
Drives: 2013 ultramarine frs
Take off the heat shields yet?
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
| Nameless Performance Overpipe/Downpipe Combo | Jason@Nameless | Engine, Exhaust, Transmission | 277 | 04-04-2018 12:37 AM |
| 3" Perrin Resonated Cat-back w/ 3" Nameless Catted Downpipe | Kevstra | Engine, Exhaust, Transmission | 28 | 05-20-2016 08:38 PM |
| Resonated or Unresonated on Nameless Overpipe/downpipe ?? | ScionFR-S | Engine, Exhaust, Transmission | 9 | 12-11-2013 05:04 PM |
| WTB: Nameless Frontpipe/overpipe + Helmholtz combo | LeeMaster | Engine, Exhaust, Bolt-Ons | 4 | 04-11-2013 04:42 AM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
