#71 |
i had a bug eye back in the day (2002ish). it was fun, but the powerband sucks, it sounded like shit and the awd broke things. aside from that i loved it. i'd still rather have an evo if i were going that direction.
| The Following User Says Thank You to jamesm For This Useful Post: | newports (04-03-2014) |
#72 | |
Trust me, I'm the Doctor
/edit Before I owned the STI, I drove a WRX for over 4 years. The STI I drove for 7 months before converting to the BRZ. Comparing the WRX to the BRZ, the WRX is obviously more powerful, but it's heavier, smaller rev range, power suffers due to heat issues when it's hot out, and isn't as fuel efficient as a BRZ. It's not that much less efficient, but even with TMIC, you've got noticable turbo lag down low (not that much but it's still there). It's also simply not as much fun to drive unless you're off road in the dirt or snow (then it's obviously a blast to drive) than the 86 either. You've also got a more parasitic drive train than the BRZ. So, I'd say that you've got maybe 10-20 more whp in the WRX than in the 86, and your weight balance in the WRX isn't as nice and low as it is in the 86, nor is it as well balanced front-to-rear. That said, it's not really bad either. Just b/c the BRZ feels and handles better doesn't mean the WRX handles like crap. It doesn't. Not by a long chalk. Now you've got the new WRX with the FA20DIT motor. That could be a whole new ballgame. What you get for your money is different between the WRX and BRZ/FR-S, but the amount you get is similar, so I'd say that they both do what they do very well for their price point, but they do different things. If you're looking for a year-round daily driver and you have to deal with snow, then I'd say the WRX has a distinct advantage. However, if you can deal with more limited winter driving and you absolutely love RWD, I'd say the 86 is perfectly acceptable. In the end, you're going to have to test drive both and put them through their paces and determine which you want more.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| The Following User Says Thank You to SirBrass For This Useful Post: | newports (04-03-2014) |
#73 |
This ^^ x10. Had this happen to me back during a freak March snow/ice storm in Prescott, AZ back in 2006. Late at night, turning right in active snow/ice conditions (trying to get back to the dorms), driving an NA 2.5L 2005 Forester. Even taking it easy, I was on AS tires, and sure enough the back end kicked out fast (not hard) as I was going from mid-turn to exit. I did as I was taught and turned in the direction of the slide and applied power smoothly (it was a 4EAT transmission too, btw). Like flicking a switch the slide stopped, I had power to the wheels, I straightened the vehicle out, and continued safely back to campus (slowly. what was normally a 20 minute drive took an hour b/c there was only about 25 yrds of visibility).
| The Following 2 Users Say Thank You to SirBrass For This Useful Post: | newports (04-03-2014), shu5892001 (04-01-2014) |
#74 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
If I'm remembering the numbers right, a stock WRX puts down somewhere in the 230-240whp range, while a stock BRZ is in the 165-180 range, so the WRX puts down something like 60-70whp more than the BRZ. That isn't to say your other points aren't valid, but a stock WRX is substantially more powerful and faster in a straight line than a BRZ/FRS is.
#75 |
Nope, WRX puts down 230-240 bhp for the GD and 2008 GR, not whp. 09-14 WRX put down 265 bhp. Those #'s are for at 5500 rpm, too.
25% parasitic loss is what was the rule of thumb, iirc, on IWSTI and NASIOC, for when you wanted to guesstimate what your real world (read whp/wtq) power would be with xyz power mods. Start adding the power at the estimated factory bhp, and apply the guesstimate loss factor. The 2008 WRX was well below 200whp, despite 240bhp, due to drive train loss. Then again, that depends on which dyno you're on. The GR STI was maybe between 230-240 whp, with 305bhp. The stock drive train in the EJ Imprezas was horrifyingly power-hungry.
#76 |
Drives: small
I remember when the base WRX was loved to death with only 227 crank hp. The 86 can do that easy with bolt ons and stock has a better power to weight ratio yet people complain these days because you can get a Camry with 270hp from a V6.
Grass is always greener, people are never happy. Usually because they don't know what they want. |
| The Following User Says Thank You to Boxer486 For This Useful Post: | chrisl (03-31-2014) |
#77 |
I'm talking actual dyno numbers, not manufacturer's rated numbers (and from what I've seen, the recent WRXs put down almost as much whp as the recent STis). I'm not as familiar with the older WRXs though, so you might be right about the 08 and earlier. From everything I've seen, the recent ("265 HP") WRXs seem to be significantly underrated at the crank, and if you look at the actual acceleration times in road tests, the STi is within a tenth or so of the 0-60 of the WRX, and within a couple tenths (and 3 mph or so) of the WRX in the quarter. The BRZ on the other hand is a second and a half and 7mph behind the WRX in the quarter. That to me indicates that the WRX is putting down a lot more than 10-20whp more than the BRZ, especially given the BRZs 450 pound weight advantage.
#78 |
The Angry Brit
Drives: 1991 E30 318iS
| The Following 3 Users Say Thank You to VacantSky For This Useful Post: |
#79 |
CHECK ENGINE
Drives: 2004 STi
I kinda converted from a WRX/STi
I bought my BRZ in August when I still had my STi, but finally sold the STi in the beginning of this year. After I bought the BRZ the STi became my 3rd car and I only put 785 miles on it between August and January.. I don't really miss it like I thought I would, the BRZ is more fun to drive pics of the sti and it's eventual replacement. ![]()
i don't cry about crickets
#80 | |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
#81 |
Drives: Fire Storm Red Slush box gt86/frs
As a rhode islander and former new yorker we got one hell of a snowy winter here, like mentioned above me investing in a snow tire will get you through daily driving during the winter ( i drove to new york during a blizzard this febuary) and my Bridgestone Bliztek were amazing you might skid every once in a while but they provide enough grip to get you from point A to B, test drive both to see what you think suites you best, both are great cars but IMO The Gt86 clones are one of the best driving and feeling cars on the market and the best in their price range. Youll have endless amounts of fun in it, and you can always add a little extra power with a perrin crank pulley intake and a simple tune and that can be done for less than $1000 also some better tires will increase your acceleration by a bit
#82 | |
#83 |
CHECK ENGINE
Drives: 2004 STi
Nov 2003 production
#84 | |
Drives: Scion FR-S/Toyota Yaris
Yea but the turbo gave the older WRX's much more torwue and a broader power band. I think the biggest thing to help decide between BRZ and WRX is geography. If I lived in a flat straight roaded area I would have never bought the twin over the WRX. But I live in an area with hairpin turns, hills, crazy curvy roads, so the FRS was/is the car for me. If I still lived in the flat Midwest the WRX is a great value.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| The Following User Says Thank You to regal For This Useful Post: | newports (04-03-2014) |
| New OEM BRZ Gauge Cluster. Zero Miles! Convert your FR-S | bambbrose | Interior Parts (Incl. Lighting) | 17 | 03-22-2014 04:23 PM |
| is it possible to convert metric to imperial? | chenshuo | BRZ First-Gen (2012+) — General Topics | 26 | 01-07-2014 11:41 AM |
| New owner here, convert from House of Honda! | WolfpackS2k | BRZ First-Gen (2012+) — General Topics | 42 | 03-04-2013 03:41 PM |
| Any way to convert from 5x100 to a more common size? | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-04-2012 01:59 PM |
| convert drum to disk brakes | DIG1992 | Other Vehicles & General Automotive Discussions | 2 | 11-09-2011 05:04 PM |
