Old 03-31-2014, 08:06 AM   #4145
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by TOY 86 View Post
Hey guys just finish installed my cusco supercharger did you guys ever encounter hard start when you installed your supercharger? Change my fuel injector to 700cc...
dont need to change anything with this kit!!!
check with your tuner.
I found leaving stock map sensor and OEM map file, starting up first time and letting it idle for 10 min while taking readings via OBD ELM, worked 100%. just gave me comfort car was running fine.
If you get any CEL come on, read your codes and advise your tuner.
once happy load your tune if you then have issue you know its your tune needs to be reviewed.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
TOY 86 (04-01-2014)
Old 03-31-2014, 08:43 AM   #4146
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by Kodename47 View Post
@moto-mike just for you.....
Wire type IAT sensor and MAP sat in the manifold. The manifold had to be modified (drilled) to allow the sensor to fit.
Any update on this?
Dustin is offline   Reply With Quote
Old 03-31-2014, 09:03 AM   #4147
xxscaxx
Drives: 2013 SWP BRZ
Just an update on the squeak - I started my car this morning, went inside to get the rest of my crap together and by the time I came back out it was gone. So its not going away in like 30 seconds or so but more like a few minutes.
I'm still waiting for a stupid intake to come to market. I've asked Mike about his like 10 times but never get a response so i'm assuming its just not finished or still working on a release.
I'm going to have a buddy fab up a new intake pipe for me though.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
TemeCal (03-31-2014)
Old 03-31-2014, 10:53 AM   #4148
Dustin
Twin Screw You
Dustin's Avatar
What exactly are you looking for? Something to replace the plastic tube that runs to the throttle body?
Old 03-31-2014, 10:58 AM   #4149
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It is the injectors/tune. Who did you ge the 700cc injector tune from?
Old 03-31-2014, 11:18 AM   #4150
xxscaxx
no, I am going to have that made by my friend. Looking for an intake replacement, that doesn't look like crap lol.
Old 03-31-2014, 11:38 AM   #4151
xjohnx
Grip>Slip
xjohnx's Avatar
Not a fan of the Perrin? I've been considering giving it a try. It sounded great on @DriftEm's video. Wonder if he noticed any power gains.
Old 03-31-2014, 11:55 AM   #4152
xxscaxx
I almost bought one, but I don't like how it just elongates the already long ass charge piping. It looks like a giant snake in the car haha.
The best solution i've seen is the use of the Airaid box, but that thing is HUGE and it is an eyesore. I'm picky
Old 03-31-2014, 05:41 PM   #4153
xjohnx
Grip>Slip
xjohnx's Avatar
Better late than never. Finally got around to installing my flex fuel kit from @moto-mike
Xero-Limit (03-31-2014)
Old 03-31-2014, 05:57 PM   #4154
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Not trying to dodge it, but we just haven't had the time to take it off the car and make the fixture. For locals I can just do it right on the car so it isn't a big deal, but I'd hate to send one out and have it not fit. Once we have the car back on the dyno now that we have the mapping squared away with that MAP issue, it should hopefully break 300 proper (though I'd be content with the 285 we did last year on e85) and then we will tear down the intake and exhaust and make fixtures for everything. This winter absolutely kicked our butts with the cold.
Xero-Limit is offline   Reply With Quote
Old 03-31-2014, 06:08 PM   #4155
evan
Drives: fr-s
Are you on winter blend or was the fuel E reading still settling down?
evan is offline   Reply With Quote
Old 03-31-2014, 06:10 PM   #4156
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
If that's winter blend for them I'm jealous - we are lucky to see e70 around here in the winter.
mikalem is offline   Reply With Quote
Old 03-31-2014, 06:11 PM   #4157
xjohnx
Grip>Slip
xjohnx's Avatar
My station doesn't seem to go on winter blend. This is actually with about 1 gallon of 93 in the tank at my last fillup. Whenever I test it manually it comes up at e82-87ish. I will be interested to see what it reads after a couple consecutive fillups on e85 to flush the rest of the 93 out.
Old 03-31-2014, 06:16 PM   #4158
Calum
That Guy
Drives: 2013 asphalt FRS MT
On what fuel are you expecting to make those numbers?
Are there any details on the exhaust?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
