#15 | ||
ProCrastinationConsultant
they didn't leave much of an impression on me, i remember demoing them i had higher hopes that i wouldn't run into the same issues i ran into with other drivers, but still found the issues-- ie. issues being absolutely needing to run a 80hz x-over or higher to compensate for poor bass extension, and (personal preference) overly bright tweeters.. but to be fair, i've never found a set of automotive-spec tweeters that i liked-- all of them sound too bright to me..
#16 | |
Drives: 2014 Scion FRS
Sounds like a nice setup.. I am starting to lean towards the C5s over the Hertz mainly for the price and because if they sound like the C3s or better than Im sure they will do the job. I have an alpine 4 channel amp that will be pushing them. Plus my sub is a JL sub so I might as well stay all JL. |
#17 |
DADA
Drives: 2013
Always go components if you are running amps.. No reason to be powering stocks , I have focals up front and they are deafening , i shut off my jl's i tossed in the back just for shits and giggles ..
Also if you can invest in some sound deadening .. do it now. I didnt do it in the beginning because i was in a rush to put my system together , I will be soon pulling it all apart and deadening everything |
#18 | |
Is is that much of a difference maker? |
#19 |
DADA
Drives: 2013
i was running at 12w6 in the trunk and vibrations were annoying, dropped to an 8w7 and the lower frequency were making the trunk rattly, dropped a little bit dynamat in there and now its good. but i will definitely be doing a bit more
#20 | |
Ok well I got my hands on some JL C5-650s. Ill be getting them installed in a couple days. I will be getting the doors sound deadened as well just to get it out of the way. I am going to wait out on deadening the trunk until I have a little more money to spend. Will deadening the doors make a difference with the sound of my sub? or will the subs bass not even be affected by the deadening until I do the trunk? |
#21 |
DADA
Drives: 2013
Door deadening do much for your sub. But it kills a lot of road noise and depending on how much you push those 6's in the doors, you will appreciate the deadening.
Trunk is easy to do, do doors first time .. That way you Dont ever touch it again. I have most of mine dine, now just getting to the Netty gretty , going around tapping panels for more noise. |
#22 |
Sounds good. Im anxious to get everything finished and finally be done with my system.. almost there
#23 |
DADA
Drives: 2013
you better post some pictures
#24 |
#25 |
#26 |
Sorry I took so long. But here are some pics.
As you can see I have a JL Audio 13.5 W7 in a sealed box built to spec and custom shaped to fit in the trunk and line up with the back seat. I still wanted a little bit of trunk space so I had an amp rack installed in place of the spare tire. I have a Kicker ZX1500.1 amp powering the sub and an Alpine Vpower powering my JL audio C5 components. I also have the Audison bit ten Processor and an 8 farad capacitor behind it all. I have the C5 tweeters in the stock location in the dash and fully sound deadened the doors. |
| Tags |
| car audio, electronics, hertz, jl audio |
| Who is running 3 way components | SHIFTER | Electronics | Audio | NAV | Infotainment | 0 | 03-07-2014 10:36 PM |
| Koni Suspension Components | dale.m | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 76 | 06-20-2013 09:00 PM |
| 2 way possible in BRZ?? - JBL MS-62C 2 way components | stevan | Electronics | Audio | NAV | Infotainment | 0 | 09-27-2012 05:35 AM |
