Old 03-30-2014, 03:23 PM   #575
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I have just tried and the trigger is not working for me either. I see this this in the logcfg.out which makes me think it's loading the conditions properly:
Code:
 action: start condition: defog,1.000000,==
trigger action: stop condition: defog,0.000000,==
My Config
Logcfg.out
A test log without the trigger to ensure defogger is working
It seems odd since others have been able to set theirs based on RPM just fine.
AdrianG is offline   Reply With Quote
Old 03-30-2014, 03:52 PM   #576
steve99
Drives: FT86
Code:
My Config
Logcfg.out
Looks same as mine
RPM works
I even tried
conditionrpn = Defogger,0.5,>
action = start
conditionrpn = Defogger,0.5,<
action = stop
still just runs all the time maybe were trying to compare different number types ??
RPM is float
Defogger is Binary
;-------------triggers--------------- ;
; note that parameters must be previously defined ; before defining triggers using them ;
; triggers allow you to control when logging starts and stops ; this example sets up triggers such that logging only occurs
; when the engine is running (RPM > 0) ;
; triggers consist of a condition (a RPN expression using comparison operators)
; and an action. the RPN comparison operators match those in the C language: ;
; if the condition evaluates to a non-zero value, that action is taken
Old 03-30-2014, 04:18 PM   #577
AdrianG
Funny, mine just wouldn't start logging when I hit the defogger. I will play with some different logic to see if that makes a difference next chance I get.
- AdrianG
Old 03-30-2014, 04:46 PM   #578
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Let me check the code again - maybe it's only using 1 bit out of the entire byte (i.e. masked), that was the case in the older roms.
Td-d is offline   Reply With Quote
Old 03-30-2014, 04:52 PM   #579
Td-d
Ok, looks like it is a bit, not the whole byte.
Define the defogger switch as follows, and see if it still triggers:
Code:
paramname = defogger_sw
paramid = 0xFFF89393
databits = 1
offsetbits = 5
If that doesn't work, try offsetbits at 6.
Old 03-30-2014, 05:43 PM   #580
AdrianG
Code:
databits = 1
offsetbits = 5
Instead of using the offset wouldn't it be easier to just log address FFF89398? Or am I batshit crazy with no concept of memory addressing practices?
- AdrianG
Old 03-30-2014, 05:54 PM   #581
Td-d
I guess that should work as well - the bit offset syntax comes from the P parameters actually, where the parameter is a set offset in a table.
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (03-30-2014)
Old 03-30-2014, 08:26 PM   #582
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
I've been experimenting with the logcfg.txt files that you guys have posted with my OP2 and am not having much luck getting any data that makes a lot of sense. I have the logcfg file on the main directory of my micro SD card and I'm able to get a successful logcfg out and logcfg csv file. However, many of the values don't make much sense. For instance, my IAM reads -4 for all rows and the RPM value ranges between .9 and 1.01. Many other values are really odd looking too. I have a C series ROM and am using the C series logcfg file that has been posted. Am I missing something else?
jprice130 is offline   Reply With Quote
Old 03-30-2014, 08:46 PM   #583
AdrianG
You probably have a different ROM, as different versions have different logging addresses. Mine is for ZA1JA01C, what's yours?
- AdrianG
Old 03-30-2014, 08:51 PM   #584
jprice130
AutoX Nut
Mine is B01C. I thought the C is what mattered for the logcfg addresses. Guess not?
Old 03-30-2014, 08:52 PM   #585
AdrianG
I guess not. I had 700C before and saw the same behavior.
- AdrianG
The Following User Says Thank You to AdrianG For This Useful Post:
jprice130 (03-30-2014)
Old 03-30-2014, 08:54 PM   #586
jprice130
AutoX Nut
Perhaps I'll try flashing a A01C rom and see how it goes. Thanks!
Old 03-30-2014, 11:30 PM   #587
steve99
Drives: FT86
Code:
databits = 1
offsetbits = 5
Thanks I'll try it out soon, the wife has "stolen" the car
Well might be a while ....
Old 03-31-2014, 02:58 AM   #588
steve99
Drives: FT86
Code:
databits = 1
offsetbits = 5
Hi,
Tried this with offset = 5 and 6 does not log defogger any more with this always "0" and obviously trigger no work. Suppose its got to be one of them will try1.2.3,4 ,7,8 and see
Not a big drama will go back to my RPM trigger.
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
