#575 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I have just tried and the trigger is not working for me either. I see this this in the logcfg.out which makes me think it's loading the conditions properly:
Code:
action: start condition: defog,1.000000,== trigger action: stop condition: defog,0.000000,== Logcfg.out A test log without the trigger to ensure defogger is working It seems odd since others have been able to set theirs based on RPM just fine. |
#576 | |
Drives: FT86
![]() RPM works I even tried conditionrpn = Defogger,0.5,> action = start conditionrpn = Defogger,0.5,< action = stop still just runs all the time maybe were trying to compare different number types ?? RPM is float Defogger is Binary ;-------------triggers--------------- ; ; note that parameters must be previously defined ; before defining triggers using them ; ; triggers allow you to control when logging starts and stops ; this example sets up triggers such that logging only occurs ; when the engine is running (RPM > 0) ; ; triggers consist of a condition (a RPN expression using comparison operators) ; and an action. the RPN comparison operators match those in the C language: ; ; > < >= <= == != && || ; ; if the condition evaluates to a non-zero value, that action is taken Last edited by steve99; 03-30-2014 at 03:08 PM. |
#577 |
Funny, mine just wouldn't start logging when I hit the defogger. I will play with some different logic to see if that makes a difference next chance I get.
- AdrianG |
#578 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Let me check the code again - maybe it's only using 1 bit out of the entire byte (i.e. masked), that was the case in the older roms.
#579 |
Ok, looks like it is a bit, not the whole byte.
Define the defogger switch as follows, and see if it still triggers: Code:
paramname = defogger_sw paramid = 0xFFF89393 databits = 1 offsetbits = 5 |
#580 | |
- AdrianG |
#581 |
I guess that should work as well - the bit offset syntax comes from the P parameters actually, where the parameter is a set offset in a table.
| The Following User Says Thank You to Td-d For This Useful Post: | steve99 (03-30-2014) |
#582 |
AutoX Nut
Drives: 2020 Toyota Supra
I've been experimenting with the logcfg.txt files that you guys have posted with my OP2 and am not having much luck getting any data that makes a lot of sense. I have the logcfg file on the main directory of my micro SD card and I'm able to get a successful logcfg out and logcfg csv file. However, many of the values don't make much sense. For instance, my IAM reads -4 for all rows and the RPM value ranges between .9 and 1.01. Many other values are really odd looking too. I have a C series ROM and am using the C series logcfg file that has been posted. Am I missing something else?
#583 |
You probably have a different ROM, as different versions have different logging addresses. Mine is for ZA1JA01C, what's yours?
- AdrianG |
#584 |
AutoX Nut
Mine is B01C. I thought the C is what mattered for the logcfg addresses. Guess not?
#585 |
I guess not. I had 700C before and saw the same behavior.
- AdrianG |
| The Following User Says Thank You to AdrianG For This Useful Post: | jprice130 (03-30-2014) |
#586 |
AutoX Nut
Perhaps I'll try flashing a A01C rom and see how it goes. Thanks!
#587 | |
Drives: FT86
Well might be a while ....
#588 | |
Drives: FT86
Tried this with offset = 5 and 6 does not log defogger any more with this always "0" and obviously trigger no work. Suppose its got to be one of them will try1.2.3,4 ,7,8 and see Not a big drama will go back to my RPM trigger. |
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 08:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 02:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 01:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 09:40 AM |
