CANADA Canada
Old 03-25-2014, 08:49 AM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Got a dent underneath..
Here's the story..
I was chaning to summer tire yesterday and I jacked up my car on wrong spot.. and got a dent underneath (right behind the passenger side front wheel)
Fitment is slightly uneven.
is any local shop could fix this problem?
bhbnuckle is offline   Reply With Quote
Old 03-25-2014, 09:44 AM   #2
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=56977
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 03-25-2014, 10:42 AM   #3
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I would doubt that's structural. It has probably just damaged the fender.
I'd check www.car-part.com and see if you can find a matching colour fender with no damage and swap it. Or check with members on here. Aftermarket paint is never as good as OE.
The other option would be to see if a paintless dent shop could do the work. Try to avoid paint work though as it will never be the same.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 03-25-2014, 04:54 PM   #4
bhbnuckle
bhbnuckle's Avatar
Just too upset about how stupid I was.
Damn.
Old 03-30-2014, 01:12 PM   #5
TwinturboCamry
Drives: 4 wheels
Ugh. That's not a good one.. even the door gaps moved...
TwinturboCamry is offline   Reply With Quote
Old 03-30-2014, 05:56 PM   #6
that_guy
Dances with Cones
that_guy's Avatar
Because the fender is bent. Not because the door moved or the rocker is bent.
Old 03-31-2014, 10:57 AM   #7
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Damn... I am so paranoid about this happening whenever I jack my car up or its on a lift.
On another note... summer tires already? The temps are still below zero at night around the GTA. In fact, this morning, the roads coming off the escarpment had ice all over them from the melt/freeze overnight. Good luck man!
Migero86 is offline   Reply With Quote
The Following User Says Thank You to Migero86 For This Useful Post:
wparsons (03-31-2014)
Old 03-31-2014, 11:48 AM   #8
bhbnuckle
bhbnuckle's Avatar
Adjusting fender was just about $60 bucks, so I did. Rocker Pannel I don't mind because I'll put TRD side skirt, as well as Front lip..
this is really sad though.. watch out when you are jacking up the car.
Old 04-02-2014, 11:13 AM   #9
Hamza7
Drives: MiniVan
Next time PM me, I work with a Paintless Dent Removal guy. We can help you out.
Hamza7 is offline   Reply With Quote
The Following User Says Thank You to Hamza7 For This Useful Post:
FLYFISHR (04-05-2014)
Article: Toyota 86 viewed from underneath djmm Scion FR-S / Toyota 86 GT86 General Forum 1 01-20-2014 03:03 AM
Dent :( Will paintless dent removal be able to get this out? Greg_Di CANADA 22 08-31-2013 11:22 PM
What is this underneath the car? FRSHunter Scion FR-S / Toyota 86 GT86 General Forum 13 08-06-2013 10:32 AM
Whats underneath your Scion FRS?? *VIDEO* Push Engine, Exhaust, Transmission 18 09-17-2012 10:53 AM
