#561 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Nice! I hadn't seen it if you had. Are these 8 bit too?
- AdrianG |
#562 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Nope - float values, x-50
#563 |
Would you mind helping me out with putting this to use?
Please?
#564 |
Sure
![]() Code:
paramname = Intake_VVT_Advance_Angle_Right(degrees) paramid = 0xFF8C0E8 isfloat = 1 scalingrpn = x,50,- paramname = Intake_VVT_Advance_Angle_Left(degrees) paramid = 0xFF8C0EC isfloat = 1 scalingrpn = x,50,- paramname = Exhaust_VVT_Advance_Angle_Right(degrees) paramid = 0xFF8C130 isfloat = 1 scalingrpn = x,50,- paramname = Exhaust_VVT_Advance_Angle_Left(degrees) paramid = 0xFF8C134 isfloat = 1 scalingrpn = x,50,- |
#565 |
If shipping to South Africa didn't cost as much as a turbo kit, I'd buy you a case of beer. Let me know if you're ever in continent
![]() In case anyone cares, my logcfg.txt on dropbox has been updated with the AVCS parameters, but I haven't been able to test them personally yet. |
#566 |
Drives: FT86
#567 | |
Drives: FT86
I got a few off @ztan for G rom which was great. Have you managed to find gefogger for "G" ROM ?? thanks Maybe a branch on Github would be useful ?? Last edited by steve99; 03-29-2014 at 07:52 PM. |
#568 |
There's a list or two from Td-d in this thread actually. I started a separate thread just for logging parameters thinking it would help but it didn't get much traction, the conversation stayed in this thread.
| The Following User Says Thank You to AdrianG For This Useful Post: | steve99 (03-29-2014) |
#569 | |
Bit of a chicken and egg situation - the easiest way of generating the logcfg files is using logcfg.exe with the Romraider logger.xml file - which currently has no BRZ parameters, since logging for the BRZ in Romraider (using OBD) is still being developed by DSchultz. That being said, doesn't prevent me from creating an Alpha branch of the logger xml that can be substituted - I'll just need to create a whole set of new parameter definitions, since you don't have P parameters anymore (e.g. before, AVCS would be logged using a P parameter, not direct logging - will now need to create a new AVCS set of direct parameters). Once I have that set up, it's very quick to generate the logger xml files for all the roms - I define the ram locations as I go along in any case. |
| The Following User Says Thank You to Td-d For This Useful Post: | steve99 (03-30-2014) |
#570 |
#571 |
Drives: FT86
Just tried it works fine can see defogger toggle 0 to 1 in log.
Only drama is trigger does not seem to work runs as soon as ignition on and toggling defogger does not start stop log. @AdrianG did your trigger work ?? ; Defogger switch for logging start/stop paramname = Defogger paramid = 0xFFF89393 databits = 8 conditionrpn = Defogger,1,== action = start conditionrpn = Defogger,0,== action = stop Last edited by steve99; 03-30-2014 at 12:12 PM. |
#572 |
I haven't been able to test yet, but I will update when I do.
- AdrianG |
| The Following User Says Thank You to AdrianG For This Useful Post: | steve99 (03-30-2014) |
#573 |
Maybe put the defogger parameter up higher in the list, not sure why it's not being used as the trigger...
#574 | |
Drives: FT86
I'll go back to my RPM trigger for now, might try commenting out some parameters in case theirs a limit or something. Thanks |
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 08:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 02:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 01:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 09:40 AM |
