Old 03-29-2014, 07:51 PM   #169
Raceseng
Raceseng's Avatar
Originally Posted by Carlitoz3 View Post
I need some help.
Had a hard time taking off crank pulley, so started searching on the forums for other alternative. Read it would be best to take off the serpentine belt first. Eventually got it off, but now I'm having a hard time loosening the alternator pulley. I put the belt back on, but the the alternator screw moves as I try to loosenit.
Any advice?
Thanks.
Do you have access to an impact gun?
Jarrett Seng
Raceseng | Owner
610.336.0206
Raceseng is offline   Reply With Quote
Old 03-29-2014, 08:16 PM   #170
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Jarrett Seng
Raceseng | Owner
610.336.0206
Negative
Carlitoz3 is offline   Reply With Quote
Old 03-29-2014, 08:31 PM   #171
xjohnx
Grip>Slip
xjohnx's Avatar
@Raceseng - when do you guys plan on doing another batch of cam cover plates?
Old 03-29-2014, 08:48 PM   #172
Raceseng
Raceseng's Avatar
They are back in stock. We just finished machining them on Friday. Thanks!
The Following User Says Thank You to Raceseng For This Useful Post:
xjohnx (03-29-2014)
Old 03-29-2014, 08:51 PM   #173
Raceseng
Raceseng's Avatar
Negative
An impact will work the easiest.
Worst case scenario, hold the pulley with an adjustable pliers. The serrated teeth in the pliers will dig into the grooves and ruin the pulley but it is the best way to keep it from slipping while trying to break the nut loose.
Old 03-30-2014, 10:29 AM   #174
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
^^ this took me 5min
#TrackDayBro
Kuri is offline   Reply With Quote
Old 07-24-2014, 12:24 AM   #175
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Can't wait my S2 kit will ship next week
Jmonty is offline   Reply With Quote
engine pulleys, raceseng
SRP Billet Aluminum Door Sills pedalpusher Interior Parts (Incl. Lighting) 2 09-20-2012 10:25 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
