Old 03-28-2014, 06:37 PM   #15
steve99
Drives: FT86
Originally Posted by chickencornsoup View Post
well done steve,
dumb question: will it cause any engine damage for the level of knock you have seen on OFT tune 1.5x ?
As I said in original post I'm not a tuner , however I think its unlikley that it would cause engine damage , the ECU manages knock in a couple of different ways. When the ECU manages knock it tends to pull way more timing than necessary. By removing about half the timing the ecu would remove you can stop or eliminate the knock. The ECU also tends to remove timing over the entire RPM/LOAD range (IAM Drop) even if the knock is just in the 2000-3000 rpm range . Even with the adjusted ROM the ECU is still able to manage knock in its usual way so if you put 95 in it it would still drop IAM and manage knock.
Old 03-28-2014, 06:48 PM   #16
w00t692
Drives: 2008 Civic Si
Most stock tunes base their knock tables around a known fuel value that the manufacturer tunes them for, and then they scale back ignition timing based around knock levels.
For instance, Honda knock maps are tuned around 95 octane fuel, and scale back based on knock level, which is tuned with a "knock ignition limit" table that tells it how much it can retard ignition based on fuel quality.
w00t692 is offline   Reply With Quote
Old 03-28-2014, 06:48 PM   #17
steve99
Drives: FT86
Originally Posted by AL008 View Post
I installed my overpipe and new Grimmspeed Headers gaskets because there were little leaks. This is my new datalog in 3rd gear:
http://www.datazap.me/u/toy-sooby/3r...e?log=0&data=1
What ROM and fuel are you on ? standard headers cat ??
Old 03-28-2014, 06:55 PM   #18
AL008
Drives: Celica 04
I had one modified from Shiv to pull about 1-2 degrees of timing throughout the range of loads. I think Load above 0.8 had 2 degrees timing pulled.
Here are the differences in Timing Pulled:
I am running Revworks UEL, 2.5" overpipe, Perrin catted front pipe, Perrin Resonated Catback and drop in filter. All on RON 98.
AL008 is offline   Reply With Quote
Old 03-28-2014, 07:06 PM   #19
steve99
Drives: FT86
Yes thought it looked very good and thats why , think it was money well spent
They have probably made other changes to fueling, MAF as well.
AL008 (03-28-2014)
Old 03-28-2014, 07:08 PM   #20
AL008
Drives: Celica 04
Do you think it's worthwhile for me to either try run the stock stage 2 UEL tune again to see if it is better, or just advance 0.5 degrees of timing in those cells to see if I can squeeze a little bit more out of it?
Thanks Steve.
Old 03-28-2014, 07:14 PM   #21
steve99
Drives: FT86
Thanks Steve.
Mate I would stick to what the Openflash Vishnu tuning guys gave you its a custom tune based on your mods and they have years of experience.
AL008 (03-28-2014)
Old 03-28-2014, 07:17 PM   #22
AL008
Drives: Celica 04
It wasn't really a custom tune, but just a conservative one that he said will solve the knock problems.
Old 03-28-2014, 07:22 PM   #23
steve99
Drives: FT86
The Stage 2 EL tune runs more timing advance than stage 1
Maybe if you run 100RON fuel it might be worth trying the original Stage 2 tune.
AL008 (03-28-2014)
Old 03-28-2014, 08:44 PM   #24
steve99
Drives: FT86
Basicly that our problem in Australia. Our 98 RON is not as good as your 93 AKI that the OFT maps are tuned for.
we also get knock on the stock tune as well even on 98/100 RON
Old 03-29-2014, 04:46 AM   #25
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks Steve.
If you're running a UEL manifold, you could always copy the AVCS maps from the stage 2 into the map you have and see how that runs. From memory the stg 1/stg 2 maps don't differ much apart from the can timing.
If you're willing to take time and log the car, you could always slowly increase timing and then drop it back when you see knock.
.: Stealth 86 :.
Kodename 47 DJ:
steve99 (03-29-2014)
Old 03-29-2014, 05:07 AM   #26
steve99
Drives: FT86
They add about 1-1.5 deg timing advance and a bit richer AFR target 0.3 aprox from memory as well at cam timing
see here for graphic illustration of how poorly our fuel performs.
http://www.datazap.me/u/toy-sooby/ca...-11-12&solo=11
http://www.datazap.me/u/toy-sooby/3r...=0&data=1-8-12
Old 03-30-2014, 05:52 PM   #27
uncivilised
Drives: 86 GT
good work with the tunes, ill keep a copy of this for the future.
uncivilised is offline   Reply With Quote
Old 03-30-2014, 08:15 PM   #28
keen as
keen as's Avatar
Drives: 86 GT MT
Thanks. I will give the 98 tune a go.
On the OFT, I can see IAM to monitor.
What is the other parameter to monitor? Is it KC?
Thanks again for sharing
keen as is offline   Reply With Quote
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
