Old 03-27-2014, 09:35 PM   #1
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Hankook RS-3 Version 2
I just saw these on tirerack.com Not sure if it's been posted yet. Here is their blurb:
"Beginning with 2014 production (DOT ending in "14"), Hankook Tire introduced a new updated tread compound for Ventus R-S3 tires. In order to help identify them, we've nicknamed Ventus R-S3 tires produced after the beginning of 2014 as "Version 2" (even though it will not be branded on the tire''s sidewall, nor printed on its label).
Ventus R-S3 (Version 2) (Z222) Extreme Performance Summer tires were developed for serious sports car, sports coupe and performance sedan enthusiasts looking for race-minded street tires that can also meet the demands of autocross, drifting and track events. Designed to further reduce the performance gap between street and track tires, the Ventus R-S3 (Version 2), like all summer tires, is not intended to be driven through snow, on ice or in near-freezing temperatures.
The new updated Racing Carbonblack Silica Compound (RCSC) technology allows the Ventus R-S3 (Version 2) to retain its 200 Treadwear UTQG rating, as well as reach favorable operating temperatures quicker produce more grip in damp/wet conditions.
The tire's directional tread design is comprised of large shoulder blocks, notched intermediate ribs and a wide center rib to deliver constant road contact and enhance the tire''s handling capabilities. While wide circumferential center grooves, narrower outboard grooves and multiple lateral grooves help evacuate water to promote wet traction, longitudinal and lateral hydroplaning resistance will be challenged if heavy rain or standing water is encountered. Drivers should drive cautiously at reduced speeds in these conditions.
The tire's internal structure includes two wide steel belts reinforced by nylon to provide strength and high-speed capability while two-ply polyester sidewalls help resist lateral direction to provide responsive handling and cornering stability."
I'm wondering if they are going to be any better than the old RS-3's. Of course I find this when I'm about to pull the trigger on some ZII's. >.<
Jaylyons1 is offline   Reply With Quote
Old 03-27-2014, 09:45 PM   #2
Dezoris
Dezoris's Avatar
RS3s were great as a street able track tire but horrible street only tire. Wonder what they really changed.
Old 03-28-2014, 02:05 AM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I assume the RS3 Version 2 is going to be a better daily street tire than before. If Hankook is saying better wet traction and a lower operating temp, I'm thinking heat tolerance may be sacrificed a bit, though.
G_Ride is offline   Reply With Quote
Old 03-28-2014, 03:01 AM   #4
CSG Mike
CSG Mike's Avatar
That's what I'm afraid of...
CSG Mike is online now   Reply With Quote
Old 03-28-2014, 08:24 AM   #5
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I was dead set that R-S3 was going to be my choice for this season before they announced the Version 2 compound change and all the version 1's were gone... I decided I was not going to be that guinea pig.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-28-2014, 08:33 AM   #6
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
They have changed the rubber compound so it warms up to optimum temperatures more quickly. That is what I have read anyway.
MTCRX is offline   Reply With Quote
Old 03-28-2014, 08:53 AM   #7
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I still have an almost new set of V1s, can't wait to get them out, I used to be a Direzza guy myself.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 03-28-2014, 09:54 AM   #8
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Yea but they aren't going to tell you what they sacrificed to accomplish that.
Old 03-28-2014, 12:49 PM   #9
Jaylyons1
Jaylyons1's Avatar
That would be disappointing. I picked up some wheels and had it narrowed to the Rivals, ZII's and RS-3's. It sounds like these will heat up faster which could be good, but I wonder what negative effects that will cause.
I may just end up going with the ZII's while they still have a $50 rebate.
Old 03-28-2014, 01:06 PM   #10
Biggins
Drives: Yes
All the top street tires are so close. The ZII is now discontinued, so you might want to pull the trigger before all the good sizes are gone. I'm taking a wait-and-see approach to the new Hankooks, but I'm definitely considering them.
Biggins is offline   Reply With Quote
Old 03-28-2014, 01:44 PM   #11
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I think i'm sticking with the zIIs until some IRWC reviews are done.
Old 03-28-2014, 01:51 PM   #12
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Z2 are discontinued? What are its' successor?
fooddude is offline   Reply With Quote
Old 03-28-2014, 01:53 PM   #13
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
ZII Star Spec, est. available Nov 2014.
Old 03-28-2014, 02:30 PM   #14
cactus
cactus's Avatar
Drives: 13 SWP BRZ
I did that last night.
cactus is offline   Reply With Quote
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 12:23 AM
Getting rid of 225/45/17 Hankook RS-3s Propaganda NY / NJ / CT / PA 5 12-05-2013 01:49 AM
FS: hankook rs3 215/45/r17 $350 thaiguy8904 Wheels and Tires 1 05-30-2013 05:51 PM
FS NJ: 255/35/18 hankook RS3 VSGTS14 Wheels and Tires 0 02-14-2013 05:14 PM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 06:59 AM
