Old 03-25-2014, 07:51 PM   #57
lp87
Drives: 2013 swp brz
any idea on when a prototype will be made? Looks pretty good
lp87 is offline   Reply With Quote
Old 03-25-2014, 08:05 PM   #58
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
hey guys thanks for all the encouraging words. trust me, i want it right here right now, but it`s going to be a slow process. I am going to run it through some aero testing as I have the CAD. I think there will be a few runs of this to make minor adjustments and then I will start fabricating.
will keep you guys posted.
thanks!
mokinbird87 is offline   Reply With Quote
The Following User Says Thank You to mokinbird87 For This Useful Post:
plucas (03-26-2014)
Old 03-26-2014, 12:34 AM   #59
cslntuee
Drives: Subaru BRZ Limited
I just saw this on the Facebook.
It looks pretty cool for me.
https://www.facebook.com/utmotor/pho...type=1&theater
cslntuee is offline   Reply With Quote
Old 03-27-2014, 01:33 AM   #60
mokinbird87
BOXER FR
so, I think I have a donor rear bumper coming soon. As soon as I get a oem rear bumper I`m gonna hack away and start the foam + clay process.
Old 03-27-2014, 09:38 AM   #61
STS-V
Thats funny. I have an FRS and want to get rid of the triangle. I even bought an 86-R rear bumper.
STS-V is offline   Reply With Quote
Old 03-27-2014, 09:39 AM   #62
pete39sp
pete39sp's Avatar
Custom made rear diffuser
My custom made rear diffuser. Hope to get some better pics this weekend.
Keep it safe but always have fun.
pete39sp is offline   Reply With Quote
The Following 3 Users Say Thank You to pete39sp For This Useful Post:
BatStig (03-27-2014), FR-Slide (03-27-2014), Gunman (03-27-2014)
Old 03-27-2014, 09:56 AM   #63
FR-Slide
Drives: 13 Whiteout 6MT
Not bad, Pete. How far under does it go? Looks a lot like DWL's project; what are the materials?
FR-Slide is offline   Reply With Quote
Old 03-27-2014, 10:11 AM   #64
pete39sp
pete39sp's Avatar
It goes all the way to the sway bar. It's .060 aluminum and the parts with the air holes and under the exhaust tips is 3/4" plastic.
Old 03-27-2014, 05:58 PM   #65
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@pete39sp Nicely done! Can't wait to see more pics.
BatStig is offline   Reply With Quote
Old 03-27-2014, 06:12 PM   #66
mokinbird87
BOXER FR
updated!
Old 03-27-2014, 08:40 PM   #67
mokinbird87
BOXER FR
hmm... i may have to get rid of the two holes as it makes it very difficult to pull out of the mold...
Old 03-27-2014, 09:46 PM   #68
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I need your cad skills. That looks good. I've got an abs place around the corner from my house. I could go and try to help you out on this.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following User Says Thank You to Wonderbar For This Useful Post:
mokinbird87 (03-28-2014)
Old 03-28-2014, 01:51 PM   #69
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Add more draft to the pins that make the holes, or post create then by drilling / machining. You could make the pins slide in / out of the mold too, then when you remove the part you first pull the pins then the part will come out easier.
If you use nut inserts in the mold the pins could be threaded and you would "un-bolt" them to remove.....but make sure there is draft on them (taper) so they will be easy to remove.
Judging from your renders your having problems with the two "boxed" notches, looks like you need at least 5 degrees of draft on those and a sliding mate to the front opening.
My day job is mechanical engineer (SolidWorks CAD), if you need help I can
IceFyre13th is offline   Reply With Quote
The Following 2 Users Say Thank You to IceFyre13th For This Useful Post:
mokinbird87 (03-28-2014), Wonderbar (03-28-2014)
Old 03-28-2014, 02:04 PM   #70
Boxer486
Drives: small
Cool stuff, let me know if you need any help as I'm local to you.
I do like the triangle on my FRS.
Boxer486 is offline   Reply With Quote
The Following User Says Thank You to Boxer486 For This Useful Post:
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 12:42 PM
Random thought, custom painted rear diffuser SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 8 03-21-2013 12:42 PM
HT Autos / KORU rear spats - BRZ and FRS - works with OEM diffuser Koru Exterior Parts - The Rest 9 01-25-2013 09:05 PM
Does anybody make a custom diffuser for the FR-S? Grateful Dave Cosmetic Modification (Interior/Exterior/Lighting) 19 12-10-2012 12:19 AM
OEM FRS with KORU Works Rear Diffuser pics _hollywood FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 10-18-2012 11:49 PM
