Old 03-27-2014, 06:48 PM   #43
Griever423
Drives: 2020 BRZ PP
ONe of the biggeast appeals to me from some BBK's like the AP racing one is how cheaply you can get track pads for these. How much are good racing pads gonna cost for this setup? For instance, a carbotech XP 12?
Griever423 is offline   Reply With Quote
Old 03-27-2014, 07:39 PM   #44
gramicci101
Off Topic
Since it uses the OEM caliper, it'll use OEM replacement pads. Carbotech XP12 retails at $211 from CSG.
http://counterspacegarage.com/ct-xp1...frs-front.html
Compared to @Dave-ROR using CL RC6 pads, which run about $201 from Essex.
http://www.essexparts.com/shop/brake...-pads-275.html
Or his next pads, Project Mu 999 for the AP Racing CP8350 caliper at $348.
http://counterspacegarage.com/produc...0-caliper.html
Project Mu seems a bit expensive for my taste.
Also, you have to consider pad thickness for aftermarket vs OEM calipers.
The Following User Says Thank You to gramicci101 For This Useful Post:
DAEMANO (03-27-2014)
Old 03-27-2014, 11:17 PM   #45
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah the PMU 999's are definitely the most expensive of the pads I use. I suspect I will like them but will I like them more than the CLs for the price difference? I'll see Sunday.. err next sunday anyways. This weekend I'll throw them on the car and bed them in.. and bleed a bit of fluid out.. and change oil filter.. and check the car out.. I think I need an alignment too... I haven't driven the BRZ much lately lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2014, 11:30 PM   #46
gramicci101
Off Topic
Do you use your OEM rotors with your track pads, or do you have rotors that you swap in just for track pads and racing, then back to the street setup when you're done?
If you have track-specific rotors and pads, can you remove them after the pads are bedded in and have them still be good once your track day comes?
Old 03-28-2014, 12:01 AM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Me?
You could. I run track pads on all my cars all the time. :shrug:
Changing rotors on my setup is a pain in the arse (2 pc rotors and I don't want to but additional hats).
I used to do that. Then I decided it was easier to be lazy. I can admit it, that's why I am a member of Team Lazy. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-13-2014, 03:30 PM   #48
RB Performance Brakes
RB Performance Brakes's Avatar
Drives: BRZ/FRS
Our OE BBK does use the same brake pad, but our rotors are 25mm meaning 1 mm thicker than OE.
Different Thickness pads may vary in performance due the the added rotor thickness.
for those of you interested in keeping your favorite track pad, we recommend checking in with the manufacturer for the thickness.
RB Performance Brakes is offline   Reply With Quote
Old 05-13-2014, 05:06 PM   #49
Calum
That Guy
Drives: 2013 asphalt FRS MT
I used to do that. Then I decided it was easier to be lazy.:shrug:
Words to live by right there!
Old 05-15-2014, 11:04 AM   #50
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
Do you know how much leeway the OEM caliper has for increased pad/rotor thickness?
For example: Let's say the OEM caliper can accomodate a net pad+rotor thickness increase of 4mm (hypothetical at this point). If your rotor is +1mm and a track pad is +2mm for a net effect of +3mm then the OEM caliper should still work in this scenario, correct?
Telling your potential customers simply to check the thickness of their favorite track pad isn't enough info to make an informed decision on whether this kit will work for us.
AyJay is offline   Reply With Quote
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
