Old 03-26-2014, 06:03 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
OpenFlash Tablet Wideband O2 Kit
Also posted in Engine forum. But I think may be of some interest to boost heads too
http://www.ft86club.com/forums/showthread.php?t=61724
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Luckrider (03-26-2014)
Old 03-26-2014, 07:31 PM   #2
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Is this more confirmation that this is prepwork for a turbo shop car?
Luckrider is offline   Reply With Quote
Old 03-26-2014, 07:57 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Will this support any wideband O2, I don't want a Bosch LSU? Also, which controller are you using as this is a big factor in how well the sensor works and lasts?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-27-2014, 08:40 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
@shiv@vishnu - any chance you'll be selling just the harnesses sans sensor? I'd like a way to tidy up my existing wideband install.
Old 03-27-2014, 02:08 PM   #5
Shiv@Openflash
Drives: 2013 FRS
It will be functional with any wideband o2/controller that has a programable 0-5v analog output.
Shiv
Old 03-27-2014, 02:09 PM   #6
Shiv@Openflash
Drives: 2013 FRS
We will be only selling the whole kit because just the harness is hard to get unfortunately. Worse case scenario, you will have an extra o2 sensor to keep handy.
Shiv
Old 03-27-2014, 02:38 PM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
Shiv
Odd, figured it'd be a pretty standard connector. Wonder if this will work http://www.casperselectronics.com/st...oducts_id=1395
Old 03-27-2014, 03:14 PM   #8
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
That certainly looks correct to me, at least for the OEM sensor. I don't know how it connects to the wideband controller though. I believe if you wanted to move the primary sensor to the secondary bung this would do the trick.
AdrianG is offline   Reply With Quote
Old 03-27-2014, 03:17 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
basically one could use this to wire their AEM wideband 5v output and ground wires into the rear o2 input without having to cut the stock harness so that the ECU (ecutek, anyway) can use a true wideband sensor.
Old 03-27-2014, 06:35 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
Just ordered one. If it fits I'll take pics and put together a DIY.
AdrianG (03-27-2014)
Old 03-27-2014, 08:14 PM   #11
Shiv@Openflash
Drives: 2013 FRS
That will work! That's for the primary o2 sensor though. The secondary sensor connection housing is keyed differently. So you'll just need to modify (dremel) the connector a bit to make it work. But it's easy
xjohnx (03-27-2014)
Old 03-27-2014, 10:35 PM   #12
xjohnx
Grip>Slip
xjohnx's Avatar
Looks like the Toyota harness sold by the same place matches the pattern for the secondary sensor. I've got one of each on the way anyway, so time will tell.
http://www.casperselectronics.com/st...oducts_id=1306
Here's the stock secondary connector, for comparison.
Old 03-27-2014, 10:54 PM   #13
Shiv@Openflash
Drives: 2013 FRS
Awesome. Please let us know if that works. If so, we will just use that to put our wideband kit together
xjohnx (03-27-2014)
Old 08-13-2014, 10:29 AM   #14
Thorpedo
The SquadWhisperer
Any update on this?
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
OpenFlash Tablet Wideband O2 Kit Shiv@Openflash Software Tuning 43 11-05-2023 01:32 PM
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
