Old 03-27-2014, 03:26 PM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by cjsporl1996 View Post
Ok will do. So with this setup how much of an improvement will I see in handling? 255 seems pretty beefy to put up front... Wouldn't it require more steering input?
Also, these wheels only allow either a 35 or a 45. Which would be better? I believe a 35 wheel would have too much poke.
+45 with 5mm spacer = +40 net offset
Get ARP extended studs to go with that, and open ended lug nuts, so you have a safe amount of thread engagement.
You'll see a lot of cornering grip. The JRZ RS will take care of the handling.
If you want to make a purchase, let us know.
CSG Mike is offline
Old 03-27-2014, 03:58 PM   #30
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I was always certain this guy was a troll...I still think he is.
"How about those sportline lines with Koni inserts or the kW v3?" - Troll
"You're comparing a Jetta to a Cayman." - CSG Mike
"So the kW are not as good. Will 245 all around work with stock suspension for now?" - Troll
$4-5k budget, wants street style Enkeis, eibach springs and Koni shocks....
SkAsphalt is offline
Old 03-27-2014, 04:17 PM   #31
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Would negative camber improve handling? If so, How many degrees?
cjsporl1996 is offline
Old 03-27-2014, 04:18 PM   #32
cjsporl1996
why would you consider me a troll? Honestly I'm a noob when it comes to tires so mikes support is very much appreciated.
Old 03-27-2014, 04:20 PM   #33
CSG Mike
CSG Mike's Avatar
You'll need to determine that via pyrometer. -3 front and -2.5 rear is a good starting point for a serious setup.
CSG Mike is offline
Old 03-27-2014, 04:26 PM   #34
cjsporl1996
Ok sounds good. Does that affect straight line handling/grip? Also, Would you recommend any other wheels that don't go over 1,100-1,500 bucks. trying to conserve my money for other suspension mods like the coilovers.
Old 03-27-2014, 04:30 PM   #35
CSG Mike
CSG Mike's Avatar
If you're willing to spend more, the WedsSport TC105N is AWESOME for the price.
Yes, you'll lose some straightline grip (particularly braking), but it's more than made up for by cornering gains.
CSG Mike is offline
Old 03-27-2014, 04:34 PM   #36
cjsporl1996
mmmm not really my style.
Old 03-27-2014, 05:03 PM   #37
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Ok sounds good.
Note: You need a probe pyrometer, not a laser pyrometer. This one is worth considering: http://www.longacreracing.com/produc...15&prodid=7339 and it's cheaper here: http://www.longacreracing.com/Userfi...BC_catalog.pdf All my Longacre tools came out of their refurb catalog.
Be aware that to use a pyrometer properly, you need someone to operate it for you in the hot pits. In a street car, you can get out of the car fast enough to do it for yourself. Understand that the faster you collect the data after you exit the track, the more useful it will be.
dradernh is offline
Old 03-27-2014, 08:17 PM   #38
cjsporl1996
question: whats the disadvantage with running 245 I'm worried that with wider tires the car is going to want to move with the grooves of the road. Also with a offset of 45 on 245 tires would that require a 5mm spacer?
Old 03-27-2014, 10:51 PM   #39
CSG Mike
CSG Mike's Avatar
To be safe, yes.
Less MPG is the disadvantage.
Tramlining (sticking to grooves) is the penalty you pay for having stickier tires.
CSG Mike is offline
Old 03-28-2014, 10:02 AM   #40
cjsporl1996
To be safe, yes.
So basically if I went with a tire with a 40 or 35 offset I wouldn't need spacers
Old 03-28-2014, 11:40 AM   #41
CSG Mike
CSG Mike's Avatar
correct.
CSG Mike is offline
forced induction, ssr, tires, vortech, wheels
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
CA FS:OEM BRZ WHEELS + TIRES midnight23 Wheels and Tires 5 07-25-2013 01:00 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
