Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Hawaii
Hawaii Aloha!
Old 02-10-2014, 08:23 PM   #43
kailuaboy808
Drives: black scion frs
Selling brand new Cusco front and rear tow hooks. 150 for both.
kailuaboy808 is offline   Reply With Quote
Old 02-16-2014, 09:38 PM   #44
Shuichi Matsumoto
Drives: nothing yet
Wanted To Buy:
Looking for a clean FRS/BRZ. Has to be manual in silver or white.
Thanks.
Shuichi Matsumoto is offline   Reply With Quote
Old 02-17-2014, 01:50 AM   #45
rjuc
SM1L3
rjuc's Avatar
Drives: WRB Subaru BRZ
^^better off going to the dealership. All models are 6-speed btw unless I'm missing something
#86hawaii | IG: @rjuc
My Mod List
rjuc is offline   Reply With Quote
Old 02-25-2014, 06:24 PM   #46
REAV3R
Former Boost Junkie
REAV3R's Avatar
Drives: Ultramarine FR-S
I'm new to Oahu and WTB a catback but shipping from the states costs too much. Anybody have a catback exhaust they want to sell?
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." ~ J.Clarkson
REAV3R is offline   Reply With Quote
Old 02-25-2014, 08:35 PM   #47
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
you can get the flowmaster from oreilys for $383 they ship it in though. There's also exhaust systems Hawaii (Waipahu) with brand parts ready to install for around $600. Then there's Rad motor sports (Waipahu) that you can take you car to and they make their own for around $300
fantah is offline   Reply With Quote
The Following User Says Thank You to fantah For This Useful Post:
REAV3R (02-25-2014)
Old 03-01-2014, 03:07 AM   #48
Eightysexy
GBC [HI]
Drives: Haole FRS
Got a JDM goodie for sale:
BRAND NEW HKS EL CATLESS HEADERS frs/brz (duh)!
[pending!!!]
Eightysexy is offline   Reply With Quote
Old 03-10-2014, 04:10 PM   #49
Shipwreck
Fanboy
Shipwreck's Avatar
Drives: Firestorm FRS
SOLD!!!
Shipwreck is offline   Reply With Quote
Old 03-11-2014, 02:46 AM   #50
FRSHunter
Drives: Asphalt FRS
Not sure if anyone is interested, but might as well ask. I have a left side JDM HID headlight housing that's for sale. The lens is cracked and the top right corner is broken including the chrome reflector. I'm thinking maybe someone would use this thing for parts. Does not come with Ballast or Bulb. I'll post pictures later.
http://imgur.com/yT3p7MS,BtONieu#0
http://imgur.com/yT3p7MS,BtONieu#1
FRSHunter is offline   Reply With Quote
Old 03-26-2014, 10:16 PM   #51
086A
086A's Avatar
Drives: Whiteout FR-S MT
F/S Front fog bezels. Brand new! $40firm
I also still have a K&N intake hardly used. $200 SOLD
"Built by Passion!"
086A is offline   Reply With Quote
Old 03-27-2014, 03:47 AM   #52
FR-FKN S!
Drives: Raven FRS
Attachment 72094
Attachment 72095
is the fog bezel oem??
FR-FKN S! is offline   Reply With Quote
Old 03-27-2014, 03:52 AM   #53
086A
086A's Avatar
Yes, Both are OEM. One ordered from Toyota and the other from Nigel JDM. I am losing out on this price so your gain. Both are unopened also….
"Built by Passion!"
Old 04-10-2014, 05:30 PM   #54
fantah
fantah's Avatar
Selling my BRZ stock air box $70. Comes with the KN Drop in filter!
Old 04-28-2014, 12:54 AM   #55
FR-FKN S!
Drives: Raven FRS
scion frs/ subaru brz - SET OF RED RALLY ARMOR MUD GUARDS $80 obo or trade for black set lmk (808) 208-4579
Old 05-02-2014, 06:35 AM   #56
teamxplizt
teamxplizt's Avatar
Drives: Seibon Style BRZ
Eagle Ind. plate carrier w/ molle gear $180
PC 680 Odyssey drycell battery w battery tender $120
Apexi 120mm EL Tachometer - This 120mm EL Tachometer features real-time 30-second needle playback, peak-hold, two-stage adjustable warning, and seven-way dimmer adjustments. A'PEX engineers incorporated a 16-bit CPU to provide fast and accurate readings in 1000 step increments. The unit has the capacity to measure up to 12,700 RPM on engines with 1 to 10 cylinders. A'PEX engineers also designed the unit to be thin and compact for installation in tight spaces. I am asking $150 for this tach.
JDM B-Series Valve Cover - This is a JDM valve cover with laser moon cuts for adjustable cam gears. It's used and can be refurbished to perfection. This valve cover with come with everything you see in the picture, valve cover, breather, rubber gasket, plastic piece for adjustable cam gears. I'm asking $210 firm.
GlowShift Air / Fuel Ratio Gauge - GlowShift’s Tinted 7 Color Series Narrowband Air/Fuel Ratio Gauge monitors your engine's air to fuel mixture, ensuring it is at optimal levels that result in reduced emissions and better fuel economy. This gauge will give you accurate readings of your air/fuel mixture. This narrowband air to fuel ratio gauge is easily installed with the included color coded wire harness that lets you connect the gauge directly to your vehicle's existing narrowband oxygen sensor. GlowShift’s narrowband air/fuel gauge includes some incredible features like stepper motor technology, 7 color through dial lighting, a low profile tinted lens, as well as an illuminated red needle that will sweep 270 degrees. The included stepper motor gives this gauge the perfect combination of smooth needle movement along with incredibly accurate readings, and GlowShift’s 7 Color through dial lighting allows you to select from 7 different solid color modes or 2 color cycle modes, letting you to match your factory dash lights or add a custom look to the interior of your vehicle. This air/fuel ratio gauge will also dim 30% for easier night time driving by simply connecting it to your factory headlight switch, and with the color memory recall feature you don’t need to worry about adjusting the color of your gauge every time you turn your vehicle on. I'm asking $60 firm.
  • 2 1/16 Inch (52mm) Black Face Gauge with a Magnified Tinted Lens
  • Displays Lean, Rich, and Optimal Air/Fuel Mixtures
  • Color Coded Wire Harness Connects to Your Vehicle's Narrowband O2 Sensor
  • Stepper Motor Technology
  • 7 Color LED Through Dial Lighting with Color Recall Ability
  • 7 Solid Color Settings and Two Color Cycle Modes
  • Dimmer Wire Allows the Gauge to Dim 30%
  • Mounting Hardware
  • Installation Instructions
  • Free Lifetime Technical Support
http://66.230.196.147/*teamxplizt.org/httpdocs/images/TXP_BRZ.jpg
teamxplizt is offline   Reply With Quote
Official Formula 1 thread ATL BRZ Off-Topic Lounge [WARNING: NO POLITICS] 3810 Today 12:18 AM
Official Hawaii Pictures Thread touge-n00b Hawaii 172 08-24-2014 11:15 PM
Official Southeast 86 Thread L3P47 Southeast 61 06-18-2014 04:20 PM
Official Norwegian Thread atledreier EUROPE 190 01-19-2014 01:38 PM
