Old 03-26-2014, 08:50 PM   #407
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by White64Goat View Post
You've lost me.........please explain......
Apparently corner exit is not a thing...
Because titanium.
Old 03-26-2014, 08:57 PM   #408
Slowbaru
Slowbaru's Avatar
Drives: 2013 WRB BRZ Limited
Im mad bc crawford didnt make this do exactly what I wanted it to.
Slowbaru is offline   Reply With Quote
Old 03-26-2014, 09:01 PM   #409
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
I'm form further fi research
Mathewgzlz is offline   Reply With Quote
Old 03-26-2014, 09:04 PM   #410
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
All your bases are b-long 2 us
jack43 is offline   Reply With Quote
Old 03-26-2014, 09:18 PM   #411
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
We are mad as well!! But the compromise worked out ok.
Crawford Performance is offline   Reply With Quote
Old 03-26-2014, 09:24 PM   #412
Slowbaru
Slowbaru's Avatar
Lol, I was being a wise a$$
Old 03-26-2014, 09:36 PM   #413
Thorpedo
The SquadWhisperer
I honestly don't understand what the confusion here is all about. (Or all the little boys crying to get some attention) A peak that is a little bit later will make it so that I don't have to short shift to get the most out of it, and keeps the power going at the top of second gear where I am commonly at during autocross. I don't mean to sound whiney, it just isn't optimal for my setup.
Am I wrong in saying that if the peak happened later so the drop off was moreso after the limiter kicks in it would be better for high RPM track performance? (awkward sentence, I know) This just seems logical to me, as for many tracks the dips down to 4500 aren't very frequent (at least with our course designers). I'm up for intelligent conversation here folks, but lots of you aren't adding anything. Stop filling the thread with useless posts.
Maybe @Crawford Performance can chime in and correct me if i'm wrong? (instead of feeding the trolls)
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 03-26-2014, 10:31 PM   #414
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
There isn't any confusion.
You believe more power at 7-7400 is better for you and everyone else believes more usable power everywhere else is better.
It obviously depends on what you're doing with your car... But the usable power everywhere else seems to win in most aspects.
Old 03-26-2014, 10:33 PM   #415
Drives: 2008 STI
The type of power band you are looking for is good for drag racing only. Think of the Audi's that have dominated Le Mans for many years now, Diesel powered with massive torque. It's acceleration that wins road races and autocross is the same. That said, you comments about gear ratios are spot on and avoiding a shift could gain you more than the extra power / torque. If you get a chance to drive a car with our BPB on it then you will see how much quicker the car actually is.
Old 03-26-2014, 10:35 PM   #416
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
In order to shift the peak to the right they would need to use a shorter spacer. By doing this they would simply move everything back toward the stock curve. The only way to keep the peak in the same location is to NOT install spacers at all. The compromise in this case is to enjoy gains by shifting the peak and they chose the shift that gave gains without costing much if anything up top. The reason people are giving you a hard time is because you do not understand how it works and are asking for the impossible (without a tune at least)
Give it a week for tuned results to show up and perhaps you will be happier.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-26-2014, 10:56 PM   #417
sw20kosh
Drives: 2013 Black FR-S
The problem is you do not understand the concept.
Study this some more:
Assume stock is "b '88 model". If you want higher rpm power you will have to settle for "a" which prolongs the power curve later but also lowers the peak power. What crawford has done is "c", "d" or "e" which shifts the power curve towards the lower rpms but also increases the peak power.
What you are asking for is "e" but shifted later in the rpm band. These power blocks cannot do that for you.
Old 03-26-2014, 11:02 PM   #418
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
For my autoX courses this would be excellent.... Assuming it stacks of top of headers and intakes.
I end up low in 2nd gear constantly because the courses are short. Having power earlier would help when shifting into first takes too long.
When tuned results with other parts come out I'll decide if it'll help my setup.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-26-2014, 11:13 PM   #419
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Its good to see Crawford back on the forum.
Also, seeing shiv get his paws on these runners.
I'm sure he'll make the most out of them.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 03-26-2014, 11:23 PM   #420
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
So we're only seeing a 9hp gain and not really the falsely advertised 20hp gain?? ....PASS ....F'ing liars. Sell your BS somewhere else.
fooddude is offline   Reply With Quote
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
