kidgogeta
Old 03-26-2014, 02:36 AM   #1695
manualmotive
manualmotive's Avatar
Drives: '14 BRZ Todoroki/OriginLabo
Hey all, looking to run 245 or 255 wide tires on the 527's with Eibach Sportlines (1.4" drop) without rubbing (functional driving). What would be my best bet to be as flush with the fenders as possible, with minimal (if any) poke and no rub?
I was originally looking at the 18x8.75 but I'm now thinking 17's. Would a 17x8.25 +35 wrapped in 245 or 255 be flush with the front fender? I figure I can always throw a spacer on the rear, but can't unpoke the front if the offset is too aggressive. I don't have any camber bolts yet; will I need any?
Thanks.
manualmotive is offline   Reply With Quote
Old 03-26-2014, 10:37 AM   #1696
STV3
Señor Member
STV3's Avatar
While researching these wheels I read on a forum that on the 527 and 530 going from a +35 to a +25 will not add any more of a concave look and will only add poke. Can anyone confirm this? XXR's website has like tech specs on their wheels nor do they list an email address to contact them.
STV3 is offline   Reply With Quote
Old 03-26-2014, 11:56 AM   #1697
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Here's a pic for anyone contemplating hyper silver Name:  ImageUploadedByTapatalk1395849390.042218.jpg
Old 03-26-2014, 02:56 PM   #1698
FR-S89
anyone have pics of the wasabi color yet? (on a car)
FR-S89 is offline   Reply With Quote
Old 03-26-2014, 03:25 PM   #1699
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Would love to see that color!
TwoFourFive is offline   Reply With Quote
Old 03-26-2014, 03:33 PM   #1700
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
That is correct.
With XXR 527/530 offset doesn't affect concavity, only wheel width does. XXR controls offset with the hub depth portion of the wheel.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
STV3 (03-26-2014)
Old 03-26-2014, 03:42 PM   #1701
STV3
Señor Member
STV3's Avatar
Originally Posted by mwjcyber View Post
That is correct.
Perfect! thanks for clearing that up for me
Old 03-26-2014, 03:45 PM   #1702
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
That is true it won't add concave, but it will look noticeable deeper because the hub is moved further in giving the illusion of a larger concave wheel.
ericvanderwoodsen is offline   Reply With Quote
Old 03-26-2014, 03:55 PM   #1703
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Not quite, the thickness of the hub is altered based on the offset, not the depth. The face of a et25 and et35 will be identical, the difference will only be with the amount of material on the back of the hub.
At least that's how it was explained to me and I've compared 530 et25 and 35 in person, they are identical.
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
STV3 (03-26-2014)
Old 03-26-2014, 08:37 PM   #1704
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Really liking the look of the 530. I might have to get some of these. You just can't beat that price.
Nevermore is offline   Reply With Quote
The Following User Says Thank You to Nevermore For This Useful Post:
ericvanderwoodsen (03-26-2014)
Old 03-26-2014, 09:11 PM   #1705
ericvanderwoodsen
No way et25 and et35 can be identical with the same wheel width so someone has their pants on fire . In your theory, if you keep adding material to the back of the hub the offset would never change that's like saying adding a spacer changes the offset to a wheel.
Notice how the hub never changes in thickness but the hub is moved deeper into the wheel with a lower offset creating a more concave look.
Old 03-26-2014, 09:34 PM   #1706
headlikeahole
Yes way. they can be identical and what you're saying doesn't disprove that. The offset is determined by where the back of the hub is, regardless concavity. Also you're showing me example of hugely different offsets. Since the choices of offsets with cheap wheels are rarely more then 10/15 mm apart, there's no point in designing a whole different wheel with more/less concave face.Its common for cheapo wheel companies to do this, this way they only need to design one face for each wheel width. From there the offset is determined by the depth at which they machine the back of the hub.
I don't know if XXR does this for sure but it's pretty common and they are very cheap, so its likely. Also having seen the two in person I could not see a difference in concavity.
Old 03-27-2014, 10:06 AM   #1707
FR-S89
Can you still get that stance look with a 8.75 wheel? not full out fender grazing lip stanced but a nice little tuck.
I was thinking of getting 18x8.75+35 with ST coilovers or FA500s... first time dropping a car though so i'm not sure how to do it exactly.
Old 03-27-2014, 10:26 AM   #1708
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
That will poke ever so slightly in the front. Rear will be tucked just fine
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
