| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#183 |
Drives: 2014 Monogram FR-S White MT
for 5th and 6th you gotta shift the gears with some authority. she may be a bit tight getting it into the gate.
#184 | |||
Drives: 2014 BRZ Limited
I'm having a difficult time being convinced.
Why risk the wear when it's not that big a deal just to learn to do it correctly? |
#185 |
Drives: 2013 SWP BRZ Premium
Drive throughs are the anti-christ.
#186 | |||
What this accomplishes for starts in 1st gear, is that I let out the clutch quickly to the exact point of clutch bite consistently to the millimeter with my heel planted, engage the clutch and then lift my leg to fully release the clutch pedal and move to the dead pedal. Quote:
#187 |
Coffee Snob
Drives: '14 SWP BRZ Limited
@subiestyle, your description of using your heel to pivot the rest of the foot for precision footwork is precisely what my father taught me many, many years ago when I was learning how to drive manual.
I think the benefit of doing so is that I can nail the engagement spot every time - however, what am I to do after first gear? I believe I've maintained years of bad habit, without knowing so. After first do I need to be using my whole leg to press the clutch in and then all the way out after putting it into the next gear?
#188 | ||
SPACESHIP
Drives: BRZ Ltd 6MT WRB
#189 |
Coffee Snob
Great so I guess I'm not doing it all too wrong. Though obviously once I get going I'd want to avoid gassin' it while the clutch is still in (riding the clutch). Question is, when I let it in and out immediately, it's a lot less smooth and more jerky.
#190 | |
Drives: Attitude
I've considered a 1pc driveshaft not only for the performance benefit, but also because during moderately "crappy" shifting and clutch engagement/disengagement you can FEEL the 2pc driveshaft doing its sloppy thing. |
#191 | |
Coffee Snob
@mkivsoopra?
#192 | |
#193 | |
#194 | |||
So I'm still not convinced. but if it works for you and you're not burning up clutches, more power to you. |
#195 |
I think I just lugged my engine for the first time
I ended up going <5mph and <1k rmps in 3rd. Can you guys please tell me the appropriate action to do in the following situation:I was 45mph in the left hand lane in 5th gear, I down shifted into 4th and got into the turn lane. I was slowing down expecting to come to a complete stop, I pressed the clutch to the floor and shifted into neutral. Now I am going like 3mph in neutral and someone makes a right hand turn giving me an opportunity to make my turn. So shifted into 3rd and made my turn, bad idea it felt like I had ovals for wheels. Should I have skipped 3rd and gone into 1st or 2nd? Should I have gone through my gears all the way down to 1st? Should I have double clutched? |
#196 |
Drives: none
I don't know if it's the "appropriate" way, but if I'm going 7mph or so or slower, I'm shifting into first. Even second seems rough with going that slow. I don't usually downshift all the way. I downshift to third then put it in neutral unless it's really slow like 10-15mph then I go into second. I don't even double clutch, but let some of the other experienced guys chime in. I could be wrong too.
| Best place to learn how to drive my car | Pneub | Southern California | 1 | 06-07-2013 03:54 PM |
| what did you learn to drive on? | 7thgear | Off-Topic Lounge [WARNING: NO POLITICS] | 31 | 08-10-2012 10:39 PM |
| Where to learn how to drive manual.... | Saibot | CANADA | 12 | 03-13-2012 06:28 PM |
| Who needs to learn how to drive... | RRnold | Other Vehicles & General Automotive Discussions | 14 | 08-27-2011 12:15 AM |
| Learn to Drive | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 102 | 03-14-2010 08:46 AM |
