DIY (Do-It-Yourself) Guides For all DIYs. |
02-21-2014, 01:14 PM | #43 |
Drives: 2014 Monogram FR-S White MT
so does this damage the led lights by giving them less juice?
and i want to avoid the soldering part. are there any places i can buy the resistor with the wires attached? also, the higher the resistor, the lower the brightness? i've heard some of you say you added more resistors so you could add and remove to adjust the brightness. This is not a plug and play adjustment, right? Technically, you would have to resolder the points if you added more resistors? |
02-27-2014, 07:01 PM | #44 |
what would happen if you connected wires 1 and 5 without a resistor in between?
would the leds light up 100% with headlights on? |
03-03-2014, 12:14 PM | #45 | ||
Run, Reach, Fly
Drives: Monogram Firestorm
I'm no expert and might not be 100% right but I’ll try to provide some info: If anybody with more expertise could chime in that would be great.
Yes the higher the resistor the lower the brightness. Imagine the resistor as a dam and the power as flow of water. The higher the resistor the more the dam is lowered (raised?). So less water is flowing. Soldering isn't that difficult. Youtube a few videos. I wouldn't just connect #5 and #1 with a wire without a resistor or diode. Limiting the power to the led will not harm it, but giving it more power then it can handle will. Placing a diode there will also stop the power from flowing back to the HID when your drl is on. |
03-25-2014, 01:24 AM | #46 | |
Drives: 10 Series FRS
03-26-2014, 09:47 AM | #47 |
Manual Noob
Drives: 2013 Scion FR-S MT Asphalt
Winjet Headlights
Will this set up work for winjet lights as well. I don't want to buy a $50 resistor from fteightysix if I don't have to.
05-24-2014, 01:52 AM | #48 |
♥カレー大好き !!
Drives: ♿
alright, i picked up a pack of the resistors off of amazon, but where can i get the diodes seen in the pic below to do the installation?
05-24-2014, 02:05 AM | #49 |
Run, Reach, Fly
^ radioshack
05-24-2014, 02:08 AM | #50 |
♥カレー大好き !!
Drives: ♿
there are no ratings for the diodes? i just get a pack of any diodes?
edit: i see 1amp, 3amp, etc... which one do i need for this DIY?
05-24-2014, 09:55 PM | #51 |
♥カレー大好き !!
Drives: ♿
so from the pic @Luis_GT posted, im going to guess this is the diode i need?
http://www.radioshack.com/product/in...lue=RadioShack please confirm, thanks.
05-24-2014, 10:29 PM | #52 | |
I used this one to be exact http://www.radioshack.com/product/in...ductId=2062579 |
The Following User Says Thank You to Luis_GT For This Useful Post: | zAnSh1n (05-24-2014) |
06-04-2014, 06:46 PM | #53 |
♥カレー大好き !!
Drives: ♿
alright, i am ready to put it together and install...
but before i do, please confirm that this is correct, thanks:
The Following User Says Thank You to zAnSh1n For This Useful Post: | LXXXV1 (06-24-2015) |
06-04-2014, 06:54 PM | #54 |
Run, Reach, Fly
Looks right. But if it doesn't work after install just flip the connecting wires around.
06-08-2014, 12:50 AM | #55 |
♥カレー大好き !!
Drives: ♿
ready to install... it's ok that i shrink wrapped the solder points, right ?
The Following User Says Thank You to zAnSh1n For This Useful Post: | tigermack (12-27-2014) |
06-08-2014, 01:17 AM | #56 |
Run, Reach, Fly
Yep that's fine
The Following User Says Thank You to Zen86 For This Useful Post: | zAnSh1n (06-08-2014) |
Similar Threads | ||||
Installed 10 Series Headlights Today | Calavera | Cosmetic Modification (Interior/Exterior/Lighting) | 58 | 02-15-2024 03:18 PM |
Scion 10 series headlights | gusbarragan | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 04-20-2014 11:26 PM |
86 Headlights (10 Series) $656 Each at www.onlinetoyotaparts.com YMMV | Calavera | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-21-2013 06:54 AM |
GT86 European headlights ? | rikdrt1 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-18-2012 04:32 AM |
European delivery date ? | Sylvain44 | BRZ First-Gen (2012+) -- General Topics | 6 | 06-04-2012 07:27 AM |
