#1079 | |
Drives: 2013 Scion FR-S - Argento
So if you had the ground tilted 1 degree away from the car, and the wheel came out at 3 degrees in, subtract one to get roughly 2 degrees negative camber. This seems like it would at least be ballpark. I haven't tried it yet and compared against the alignment numbers I have from recently. Edit: I realized that the phone's level is accurate to within 1 degree. In order to be more accurate, for both the level-ness of the ground and the camber of the wheel, put the phone so it is at 0 degrees and then measure the distance to the ground or wheel as accurately as possible. Convert the distance into degrees using trig (I don't have the formula in my head, but it isn't hard.) Last edited by cycleboy; 03-21-2014 at 09:55 PM. Reason: Accuracy of numbers |
#1080 |
Drives: FR-S Whiteout
I actually tried using a level app on my phone (iMetal Box) and it seem to be at least within half a degree possibly less. It lets you zero the level. Although, half a degree is quite a bit when you're talking about camber not to mention 1 entire degree.
#1081 |
Because compromise ®
Drives: Red Herring
@Andy RaceComp,
Is it possible to make any roll center correction at the rear? When I say "possible" I mean in a relatively inexpensive/easy sort of way.
#1082 |
i'm sorry, what?
Drives: Canada
found this while digging through the internets...
seems like a cool concept..
#1083 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Captain Snooze (03-25-2014) |
#1084 | |
A strut + spring set-up is just a non-height adjustable coilover. In the case of Konis they are damping adjustable. For a fun DD and monthly autox car, a set of quality springs and shocks + a good alignment is a good easy way to go. No muss, no fuss...good choice if you're new to suspension tuning. It will hold up at the track just fine when you start doing that in the future and be easy to drive fast and learn on (with the right combination). But if you're running r-comp tires and really pushing for fast laptimes, a quality coilover is the way to go. - Andy |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#1085 |
Junior
Drives: a car
@Racecomp Engineering
Im curious to know a suspension vendors opinion on these thingys... http://www.cambertire.com/ and how it would effect any sort of alignment?
#1086 | |
![]() We had a sponsored driver that was also sponsored by them. At first he was in love, but it didn't take long for him to jump ship and move to a regular r-comp and pick up some speed.. I haven't touched them and I probably won't. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | wparsons (03-28-2014) |
#1087 | |
Junior
Drives: a car
#1088 |
Drives: Red Herring
Mike@CSG and Andy@RaceComp
This is just for curiosities' sake. From all the trawling I have done about Tein SRCs it would seem they are not pressurised. Does this mean that gassed dampers are a bit of marketing fluff? I like the theory that pressurised dampers are less prone to cavitation but does this actually make a difference in reality? Is it a case of diminishing returns for added cost and complexity? Thanks.
#1089 |
So I have a newbie question since I got my KW V3's on this past weekend. I stole Myles suggestion on settings for street:
Full stiff settings then: Front compression 7 clicks back Front rebound 10 clicks back Rear compression 8 clicks back Rear rebound 7 clicks back My silly question is can you adjust this while the car is on the ground pre-loaded or do these adjustments need to be made while it is in the air? I just don't want to damage anything. Thanks guys! |
#1090 | |
driving smoother faster
Drives: Sold
Either is fine |
| The Following User Says Thank You to dp1 For This Useful Post: | FR-S Matt (03-26-2014) |
#1091 |
i'm sorry, what?
Drives: Canada
where can i find some literature on the effects of wheel and tire sizes on performance and the necessary considerations.
Ie, what IS the benefit of going to 18's with 35-40 aspect ratio tires and what modifications would be necessary to extract an improvement. with such a stiff tire, does it become absolutelty necessary to control dynamic alignment, so more anti-roll, caster, etc. i keep finding bits and peices of random forum discussion but no papers or articles (other than the crap you find in tuner mags)
#1092 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
I'll be receiving my suspension tomorrow / Friday depending on how late my apartment office decides to stay open or if brown Santa leaves my presents at my door. My question is if I swap my shocks by myself (the most likely scenario), what is the safest way to remove the old and mount the new? I will try to get some help, but it is unlikely any would be available when I plan to swap. Thanks in advance!
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
