| Software Tuning Discuss all software tuning topics. |
Drives: 2013 FRS Asphalt
Ecutek Ignition Correction?
There seems to be some new things being logged in the latest Racerom update. Question on the new parameters I'm not sure I know what these are doing.
Ignition correction course and Ignition correction fine. Pi duty? Cps voltage?
2013 Scion FR-S AT Picked up 5/30/2012
#2 | |
Drives: UK GT86
PI Duty - Duty cycle of the port injectors CPS Voltage - I think this is the carbon canister voltage, re-used for EBCS/O2 sensor etc. If you've not got any new external inputs, ignore/stop logging this. Course IC - The advance map - this will show advance map x IAM Fine IC - This is FLKC and will show you where timing is pulled or even, if your IAM is less than 1, you can see where it is putting timing back in. You can now stop logging Knock Correction Learn as the Fine and course replace them and are more accurate.
.: Stealth 86 :.
#3 | |
The Ignition Correction Course reports the requested dynamic ignition advance from the ignition advance map after any correction by the Advance Multiplier (ignition advance value x Advance Multiplier). The Ignition Correction Fine is a compensation to the Ignition Correction Course based on noise detected by the knock sensor, or lack of noise (Ignition Correction Course +/- Ignition Correction Fine = applied dynamic ignition advance). PI Duty indicates the duty cycle of the port injectors. This is an indicator of how hard the injectors are working to deliver the amount of fuel requested. The injectors reach a theoretical limit at 100% duty cycle, although you would never want to run your injectors at 100% duty. CPS voltage is the carbon canister purge voltage and is one of a few inputs you can repurpose for an ethanol content analyzer, wideband o2 sensor, etc. - Bob Last edited by Circuit Motorsports; 03-26-2014 at 08:31 AM. |
#4 |
Bob excellent response. The one you sent me in email was even more explained. You rock sir
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 10:09 PM |
| FRS Ignition Key | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 120 | 07-22-2014 09:23 PM |
| Ignition vs Argento? | Pacific Auto | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-17-2013 04:24 PM |
| Keyless ignition for my FRS | Gixxersixxerman | Electronics | Audio | NAV | Infotainment | 1 | 11-30-2012 11:09 PM |
| New test from Ignition. | zoomzoomers | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 04-30-2012 11:31 PM |
