Old 03-25-2014, 01:02 PM   #4019
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by acro View Post
black doesnt radiate more heat it actually absorbs.
It does both
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-25-2014, 01:17 PM   #4020
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
By any chance have you logged IATs before and after install?
I should have logs of them before, and I should be able to get some after.
update:
Comparing logs from April of last year with the stock manifold my intake temperatures were around 33C tapering down to around ambient towards redline which was about 25C.
My logs I did yesterday, post install are almost identical. 34C tapering down to 24-25C towards redline.
Ranatsu is offline   Reply With Quote
The Following 3 Users Say Thank You to Ranatsu For This Useful Post:
FrsDuke (03-25-2014), OrbitalEllipses (03-25-2014), Slysdexia (03-25-2014)
Old 03-25-2014, 04:35 PM   #4021
w00t692
Drives: 2008 Civic Si
This doesn't look like a remotely fair comparison to any of the UEL's on the market. I'm not surprised, though.
w00t692 is offline   Reply With Quote
Old 03-25-2014, 04:42 PM   #4022
OrbitalEllipses
Drives: Attitude
Forty fucking pounds from a stock car...that's just
Old 03-25-2014, 04:44 PM   #4023
FrsDuke
Fanboy
FrsDuke's Avatar
update:
Do you recall off the top of your head the ballpark of the surface temps? Sounds like you were running 30f cooler on the outside surface of the intake which is a good indicator things in general are cooler. If other surface measurements were also cooler I have my answer. Thanks for actually taking measurements instead of a knee jerk reaction.
TL;DR:
-Duke
Old 03-25-2014, 04:46 PM   #4024
w00t692
Man, you guys are worrying about the wrong thing. Seriously, this thing isn't going to heat your shit up by any amount that will be detrimental, and even if it does, it would only do so when in heavy traffic.
The Following User Says Thank You to w00t692 For This Useful Post:
Old 03-25-2014, 04:50 PM   #4025
Ranatsu
Cone basher
I didn't actually test anything else, but I think I looked at my Perrin LWCP and it was right around 200 degrees after just sitting in my driveway idling for 10 minutes or so.
I'm sure its not a big deal when everything has air moving across it, but just sitting there everything is going to get hot.
Old 03-25-2014, 05:26 PM   #4026
FrsDuke
Fanboy
FrsDuke's Avatar
Indeed. Just the radiator fans at idle had like a 30 degree impact on the header tube temps. Side in the air flow was significantly cooler than the other side. The fans and air from movement should actually keep temps well in check in my opinion. I know I kicked a hornets nest by daring to question which type of ceramic coating was being used. I'm simply curious why folks with coated headers were expressing so much concern. Perhaps the reason they are more vocal is the very reason they opted for coating to begin with. Just made me wonder if the coating was intended purely for flow at the potential expense of more radiation. So I asked and took some measurements. I very much hope and expect it to be a proper thermal barrier. I just want to know for certain. I'd still like to see a surface temp reading on the actual header at its highest point nearest the intake. Hopefully it is well below 200F.
TL;DR:
-Duke
Old 03-25-2014, 06:09 PM   #4027
xjohnx
Grip>Slip
xjohnx's Avatar
I want to say it was around 190 on mine yesterday (uncoated). i'll test again this weekend.
Old 03-25-2014, 06:47 PM   #4028
FrsDuke
Fanboy
FrsDuke's Avatar
Just for clear comparison I let mine idle for 10 min with the hood shut after I'd driven for an hour. Ten minutes should be plenty of time for things to normalize from a cold start or a highway drive I would think. Opened the good and took a bunch of measurements as quickly as I could with it still running. It was in the high 60s to low 70s.
TL;DR:
-Duke
Old 03-25-2014, 08:49 PM   #4029
Sargy
Long Distance Driver
Sargy's Avatar
I wouldn't be concerned about anything temperature wise if you guys are coated. daily driving and sitting in traffic these headers are awesome, quick cool downs, intake box dosent get hot, etc. I am just concerned about back to back autocross/track runs that would require me to get some protection under the intake box to keep the IATs normal, thats all.
But I guess the numbers and data are good for references.
Sargy is offline   Reply With Quote
Old 03-25-2014, 10:40 PM   #4030
FrsDuke
Fanboy
FrsDuke's Avatar
If I were concerned I would have gone coated. I'm just curious
TL;DR:
-Duke
The Following User Says Thank You to FrsDuke For This Useful Post:
Sargy (03-26-2014)
Old 03-26-2014, 08:41 AM   #4031
mad_sb
Drives: 2013 Asphalt FR-S
Anyone know of a dynojet (actually since I'm starting with a baseline it does not have to be a dynojet) in or near Irvine Ca?
I need to baseline my current setup before installing and tuning the nameless header. I will also post in SoCal sub forum, but since this is related to the Nameless header....
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
FrsDuke (03-26-2014), xjohnx (03-26-2014)
Old 03-26-2014, 09:00 AM   #4032
xjohnx
Grip>Slip
xjohnx's Avatar
Thatta boy!
There's a bunch of locations listed on Dynojet's site: http://www.dynojet.com/dyno_centers/....aspx?state=CA
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
