Old 03-23-2014, 09:07 PM   #883
Wepeel
Drives: '13 BRZ Ltd
So if you do the math for total wheel rates in roll for the BRZ, and reduce it to natural frequencies, in completely stock form the BRZ has a front:rear natural frequency bias of 1.24 (Front Roll NF / Rear Roll NF). Adding a Strano front bar shifts that to 1.55 (more understeer). Keeping everything stock and removing the rear bar shifts it to 1.60, so a little more under-steery than the stock with the Strano bar but not too much so. Balance wise I would think it would be pretty similar but obviously the chassis will be moving around more.
Removing the rear bar will remove about 79 lb/in of rate from the rear wheels in roll and reduces overall roll stiffness by about 13%.
Wepeel is offline   Reply With Quote
Old 03-23-2014, 09:33 PM   #884
dsgerbc
Drives: BRZ(sold), STI
Not sure what's minimal, but anyway.
On a really bumpy road it could help - sure. But I'd rather not drive on those lots where disconnecting RSB helps. In the rain? You mean for putting down power? Maybe (I'm not sure it's gonna help much short of standing water or 1st gear in this car), but you're still better off with a larger FSB and disconnected RSB if you want minimal load transfer in the rear.
I just don't see the point of lowering overall grip to take care of mild oversteer. Just mess with tire pressures to give rear a bit more grip relative to the front.
Old 03-24-2014, 12:38 PM   #885
mrazny
Drives: BMW 135i, soon to BRZ
Bolded the part that's not allowed in Street class for the skimmers that might not have read the whole conversation.
mrazny is offline   Reply With Quote
The Following User Says Thank You to mrazny For This Useful Post:
Kido1986 (03-24-2014)
Old 03-24-2014, 01:27 PM   #886
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
because physics?
weight transfer is dictated by center of gravity, track width, and weight.
nothing else
during roll, the center of gravity shifts slightly but not enough to really impact the general state of things.
control of roll in production cars is primarily there to reduce dynamic alignment changes and keep the tire in perfect angle to the road.
http://www.motoiq.com/MagazineArticl...-transfer.aspx
Old 03-24-2014, 02:17 PM   #887
itzmik3
DBC Racing
itzmik3's Avatar
[ame="https://www.youtube.com/watch?v=pivMquF2Sqw&list=UUfrcGo4iul6xqAvyWGlLR4w"]CSCC - Championship 3/23/14 - YouTube[/ame]
video from this weekend's racing.
this was the closest I have been able to get to Jeff Stuart in the 370z (.478)
i had a couple sections that i definitely could be cleaned up, but overall very happy with the result
#194 SM
itzmik3 is offline   Reply With Quote
Old 03-24-2014, 02:49 PM   #888
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Thanx for spanking me by over 4 secs, otherwise, an awesome drive!
You were actually faster than Jeff after run#2...
brz7400 is offline   Reply With Quote
Old 03-24-2014, 03:36 PM   #889
JB86'd
JB86'd's Avatar
Drives: JAWS
Hey don't feel bad, @itzmik3 spanked me by 10 seconds! Nice run Mike. In my defense it was my first autocross and fully stock tires and suspension hahah. El Toro was a blast, I think I've been bitten.
75.093. I need to work on my hand position, and a lot of other things!
[ame]http://youtu.be/_ygZFemsEyU[/ame]
JB86'd is offline   Reply With Quote
Old 03-24-2014, 03:53 PM   #890
itzmik3
DBC Racing
itzmik3's Avatar
hahhaa thanks thanks.
yeah i spoke with jeff after all the runs were over and he said he was actually a little worried after my 2nd run. sadly from there i was left in the dust.
#194 SM
Old 03-24-2014, 03:54 PM   #891
itzmik3
DBC Racing
itzmik3's Avatar
sorry i couldn't give you a ride on saturday.
it was super hectic dialing in the C-Street car and doing shakedown runs in Max's STX BRZ
maybe at the next practice
#194 SM
Old 03-24-2014, 04:00 PM   #892
JB86'd
JB86'd's Avatar
Drives: JAWS
No worries at all man! That'd be great. I think I'll try and run in the next Saturday practice also.
Old 03-24-2014, 05:25 PM   #893
dsgerbc
Originally Posted by 7thgear View Post
because physics?
nothing else
Weight transfer is roughly fixed (but does change a bit due to roll). Total weight transfer can be split (in other words which parts of the car react to more of Earth's reaction force) into one part where higher suspension compression counteracts part of the higher weight on that corner, and a second part due to suspension links' tension. Neither is minimal.
But that's off-topic basically. Like I said, I see not point in reducing total roll stiffness of the car for regular autox.
Old 03-25-2014, 04:39 AM   #894
3essess
Drives: frs
the main reason autoxers unhook the rsb is to help keep the inside rear wheel planted when applying power out of turns - helps the torsen work
3essess is offline   Reply With Quote
Old 03-25-2014, 12:54 PM   #895
dsgerbc
Fat FSB does the exact same thing. Like I said, if you're lifting inside rear with the fattest FSB, then I can see the point.
I might be wrong, but I don't believe the rear inside lift is a problem in this car in C Street. It probably is in STX.
Old 03-25-2014, 12:57 PM   #896
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
making one end stiffer vs completly unhooking something are entirely different things
no swaybar = 100% independence, the inside tire can droop all it wants without any interference from the loaded tire
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
